Old 07-28-2010, 03:43 PM   #1
Hershey
would think a glob that size would take many miles / months to form . Thus , if it's a slow internal head gasket leak many wouldn't be aware of it . The coolant resorvior level probably wouldn't move all that much and could be easily overlooked . Would think that the moisture from the slow internal leak would be burned off , so wouldn't affect the oil level to make for any concern . Last , I remember other members complaining of a rough idle . Hopefully it's not due to the head gasket for cylinder no. 1 or others . This is mentioned here , http://www.etimago.com/yaris/repairm...Mechanical.pdf under EM 4 .
Old 07-28-2010, 03:52 PM   #2
Hershey
probably won't make a difference if it's dino or syn as long as there's a slow internal coolant leak that's not detected . I wonder if using the synthethic so early just sped up the leak for a faulty cylinder head gasket . . This shoudn't be happening with 2 new cars . All I know is that we're p*ssed off at TOYOTA . Don't think we'll buy any more . They're probably aware of this issue and haven't gone public yet until there's more complaints . We may have to get a used oil analysis for both . That's if we don't trade them in .
Old 07-29-2010, 02:12 PM   #3
2007tRD
CERTIFIED ASE/SUBARU TECH
2007tRD's Avatar
Drives: 2007 VIOS S
You are absolutely correct about starting on synthetic too early,the engine requires the factory filled high detergent oil for break-in.I extensively reserched the sluge issue,and every source points back to my first post,...change your oil every time the maintenance minder light comes on.pay no attention to what anyone says regaurding changing your oil at 3000 or 5000 miles,as those are just industry standards...not Toyotas.The maintenance minder system caculates by its own milage interval.sludge is caused by water in the oil,it gets in there via condensation everytime you engine is shut down and the oil temp drops below 212 degrees farenheit.the longer the same oil is used the more water accumulates,this is while oil shoud be changed once a year even if the engine is never started.
2007tRD is offline   Reply With Quote
Old 07-29-2010, 02:18 PM   #4
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
Originally Posted by 2007tRD View Post
You are absolutely correct about starting on synthetic too early,the engine requires the factory filled high detergent oil for break-in.I extensively reserched the sluge issue,and every source points back to my first post,...change your oil every time the maintenance minder light comes on.pay no attention to what anyone says regaurding changing your oil at 3000 or 5000 miles,as those are just industry standards...not Toyotas.the maintenance minder system caculates every variable possible[idle time,miles driven,engine loads,average speed]and decides by that data when you should change the oil.sludge is caused by water in the oil,it gets in there via condensation everytime you engine is shut down and the oil temp drops below 212 degrees farenheit.the longer the same oil is used the more water accumulates,this is while oil shoud be changed once a year even if the engine is never started.
I thought that the maintenance light pops up close to a 5,000 mile oil change interval which is what the manual states. It does this on mine.
KrazyDawg is offline   Reply With Quote
Old 07-29-2010, 02:33 PM   #5
2007tRD
2007tRD's Avatar
Drives: 2007 VIOS S
close to 5000?
close to 5000miles...not exactly 5000.
Old 07-29-2010, 03:12 PM   #6
kou
Drives: 08 lb
Toyota uses ENEOS NIPPON 0-20w or 0-50w syn in there cars. which is what they come from the factory.This comes from the window sticker from my 07 yaris.
Old 07-29-2010, 03:39 PM   #7
2007tRD
2007tRD's Avatar
Drives: 2007 VIOS S
eneos
Extremely good oil.
Old 07-29-2010, 11:25 PM   #8
Hershey
Where does it state the oil installed from the factory on the window sticker ? New to us . . Do know they use a different oil filter from the factory for the break in period which is the 90915-10003 made by DENSO . Wonder if the factory installed 90915-10003 oil filter has better filtration than the TOYOTA ( Denso ) 90915-YZZF2 to catch metals , sealant residue , etc. ?
Old 07-30-2010, 08:55 AM   #9
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
no, on the Yaris it is programmed by miles driven. no other factors afaik
127.0.0.1 is offline   Reply With Quote
Old 07-30-2010, 09:55 AM   #10
2007tRD
2007tRD's Avatar
Drives: 2007 VIOS S
read your owners/service manual...I just looked over mine, and it says it comes on "about" 4500 miles from the last reset.
Old 07-31-2010, 07:25 PM   #11
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
I believe synthetic oil has better "cleaning" characteristics than dino!...and,modern multi grade oils are detergent!.
Just change your oil and filter.
frog13 is offline   Reply With Quote
Old 07-29-2010, 02:23 PM   #12
2007tRD
2007tRD's Avatar
Drives: 2007 VIOS S
I will also give you guys some PCV info:Every engine has piston ring blow-by,even a brand new one.this is why that break-in period is so vital,to properly seat all moving engine components.the pcv system removes the ring blow-by,oil mist,and the water vapors from the crankcase and returns it to the intake to be burned durring combustion.when the oil is not changed regularly,the sludge makes its way into the pcv system and clogs it.as a result,many oil leaks and an increased amount of sludge formation will occur.
Old 07-29-2010, 02:31 PM   #13
2007tRD
2007tRD's Avatar
Drives: 2007 VIOS S
Now...Synthetic oil.too many peole have no faith in the refined petroleum.this oil is resistant to oxidization,thermal breakdown AND sludge problems.the unstable molecules in conventional oil easily vaporize and oxidize in extreme heat,and will not pump below -34 degrees.extreme conditions is where synthetics shine,they pump from -58 to degees and gains of up to 10hp have been noted by carcraft dyno's.synthetics flow better at low temperatures durring start-up and in the lowe rpm range due to less initial drag for the engine to overcome.
Old 07-29-2010, 03:10 PM   #14
2007tRD
2007tRD's Avatar
Drives: 2007 VIOS S
The engine tear down was due to oil consumption,rough idle,and the head gasket was leaking oil. they got their oil changes done at wal-mart,jiffy-lube,penzoil,ect...this was their first visit to a dealer.im assuming they use a bul generic oil at those places, dont know what grade.
Old 07-29-2010, 03:21 PM   #15
Mad Goon
New To The Import Thing..
Mad Goon's Avatar
Drives: 07 Yaris 71 Comet 69 Maverick
Send a message via AIM to Mad Goon
Huh... I thought it was at a preset mileage... I changed my oil at 3,000 before the light came on and around 2000 more miles, BAM there goes the light..
What about the driver's habits? Frequent, short trips without allowing the car to reach operating temp could cause sludge buildup as well.. I know that a head gasket leak would answer a lot of this, but wouldn't the tops of those pistons also be clean with a slow amount of liquid(water) passing through(head gasket?) Carbon buildup there could also be answered with my statement as well...
This is pretty interesting though.. Who knows what the "lube technicians" did during those oil changes ... So many variables! x.x
Mad Goon is offline   Reply With Quote
Old 07-29-2010, 11:32 PM   #16
Hershey
If it's a very fine internal leak most moisture probably would get burned off ( evaporate ) . So , could take a long time for it to accumulate internally . The only thing to most likely detect it early would be with a U.O.A. ( Used Oil Analysis ) . We may have to go that route .
Old 07-30-2010, 08:57 AM   #17
127.0.0.1
to detect a headgasket leak, you do a compression test on the
cylinders and a pressure test on the cooling system.
and use a block tester on the coolant to detect exhaust gasses
uoa is overkill, don't need one
Old 08-01-2010, 10:57 PM   #18
Mad Goon
Mad Goon's Avatar
Thumbs up
Ah good point! Best of luck, would love to get to the bottom of this... Makes me a little wary of the old lady's car..
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
