@syntax, FYI, 8,882km pa lang.
![]() Advice naman jan kung ano iapapa-note ko sa technician before ipasok para no worries after. TIA!
![]() ![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan 2010 "shadow" Join Date: Mar 2010
@rye ilang months na sayo si mica? bakit 8.8K pa lang?
nu advice na ipapanote? kapag pinasok mo sa 10K check up? it depends sayo pre kung ano ung naffeel mo na nag iba kay mica since nakuha mo |
@Syntax, tol mag- 1 year na sa January.
Ok lang ba kung ipapalinis ko brake pads? What about the wheels?? |
pre' sa pagkakaalam ko sa 25K pa ang check up at lilinisin ang brake pads, IMHO pa check mo lang ung clutch parang hindi smooth ung pag apak mo sa pedal at ung pag 1st gear mo, kasi napansin ko un nung nagpunta tayo ng etari ba un?at pa synthetic oil ka na pre' mas smooth ang takbo ni mica.
@ rye HTH.
Mga magkano ba pag synthetic? Naka-synthetic na rin ba si shadow? Cge I'll take note pati na rin about sa clutch. Pwede rin pahigpitan brakes?
![]() ![]() ![]() ![]() ![]() ![]() Drives: yaris Y 2010 A.K.A. "sky" Join Date: Jul 2010
@rye, nagtanong ako sa toyota at quote ay around 200SR kc papalitan din daw ung filter, check m ndin lng kng magkano dyan, d nman gnoon kamahal, kaunti lng depernsya sa ordinary.
Ciao !!! Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter) Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way |
#8 | |
@xtremist, ok thanks bro. Synthetic na rin ba gamit mo??
![]() ![]() ![]() Drives: Flint Mica 2010 Join Date: Jul 2010
Do you have recommended mechanic for our yaris maintenance? name, number and location?
#13 | |
ay oo nga pala nakita ko na ito, makakalimutan na talaga ako.
#14 |
BlessedYaris now for 50k service ( change oil/synthetic ) sar 450 initial quote...
God Bless !!! BlessedYaris ![]() 0552829596 |
#15 |
#16 |
syntax, akala kb may sakit k? bat wlang (uboh, uboh, uboh)...hahahaha
#17 |
medyo malayo po kase travel ko everyday... pero mas tumatatag naman po c blessed sa takbuhan... actual cost po 395.00sar
#18 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris YX Join Date: Jun 2010
Anong latest????
| how much does the first maintenance service cost | hans_fh | DIY / Maintenance / Service | 25 | 07-05-2007 10:01 AM |
