Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 11-02-2011, 01:50 AM   #1
Yaross
Yaross's Avatar
Drives: 2006 Yaris HB 5DR
Originally Posted by rickyml View Post
15US$ free shipping na po yan kaya dalawa kami ni yaross kumuha.
Mga tol, order na!
OK sya lalo na sa mahilig mag-tune ng kanilang mga sasakyan. Dalawang klase yan, isang via USB (with cable) at yung isa via bluetooth (wireless).
USB cable kinuha namin, mas matibay daw (yet to be proven). advantage ng bluetooth, wireless kaya kahit saan ka daw pumesto.
Yun nga lang made in China so buy at your own risk.
Yaross is offline   Reply With Quote
Old 11-02-2011, 02:28 AM   #2
ronan4210
"Fast & Furious"
Drives: 2008 Yaris Sedan - Fleet
Originally Posted by Yaross View Post
Mga tol, order na!
ayos ang endorsement ah... si yaross na ang bagong endorser ng ELM/327 1.4a CAN BUS OBDII OBD2 Car Diagnostic Interface Scanner USB Code Lead.
ronan4210 is offline   Reply With Quote
Old 11-02-2011, 05:47 PM   #3
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
ELM/327 1.4a CAN BUS OBDII OBD2 Car Diagnostic Interface Scanner USB Code Lead arrived...
OK na ito for day to day use..Mas maganda sana kung makuha nya yung extended dignostics ng toyota like EPS tourqe at transponder registration
ricepower is offline   Reply With Quote
Old 11-02-2011, 04:00 PM   #4
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Idiot question: ano po yung code scanner na yan ano advantage? puwede pasabay mag order?
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 11-05-2011, 05:59 AM   #5
Yaross
Yaross's Avatar
OBD2 scanner - On Board Diagnostics, version 2. Ito yung ginagamit para malaman ang status ng sasakyan, may problema man o wala. Kumokunekta siya sa ECU/ECM ng sasakyan.
Pag may problema - pwede mo malaman ang cause ng problema at pwede mo rin ma-reset yung error code at CEL (check engine light)
Pag walang problema - pwede mo magamit para malaman mo ang maraming bagay na pumapasok sa ECU gaya ng intake air temp, ignition timing, MAF, O2 sensor, rpm, etc... Ginagamit ito kung mahilig kang mag-tuning ng sasakyan.
Old 11-05-2011, 08:52 AM   #6
marble_bearing
marble_bearing's Avatar
Drives: 2008 yaris y silver
the much awaited cliffords bodykit product...
have just arrived...
GT front chin...
GT rear skirt...
now in the shop... can't wait for the outcome!
marble_bearing is offline   Reply With Quote
Old 11-05-2011, 09:01 AM   #7
marble_bearing
testing... :)
Old 11-05-2011, 11:45 AM   #8
marble_bearing
goodbye chin chin...
Old 11-19-2011, 01:10 AM   #9
rickyml
rickyml's Avatar
Drives: Yaris 2008
DIY Washable cabin air filter
success and tested...
materials, finish product, tested...
yaross!!! tapos na yong pinagawa mo...
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 11-19-2011, 03:09 AM   #10
Yaross
Yaross's Avatar
Maraming Salamat Bro!!!
Old 11-19-2011, 01:22 AM   #11
syntax
syntax's Avatar
@ insan ayus yan, tanong lang ano ung parang aluminum? angled bar ba na aluminum? at tsaka ung plastic na nasa corners ng filter san nakakascore nun?
Old 11-19-2011, 01:55 AM   #12
rickyml
rickyml's Avatar
Drives: Yaris 2008
d2 sa jubail marami... 9sr (aluminum bar + plastic corner)
white board actually yon... ni-recycle ko lang. hehehe
Old 11-19-2011, 03:12 AM   #13
syntax
syntax's Avatar
insan ...
ano size nito? i mean dimensions ng cabin air filter?
Old 11-19-2011, 03:32 AM   #14
rickyml
rickyml's Avatar
Drives: Yaris 2008
Originally Posted by syntax View Post
insan ...
21.5cm X 19.5cm
Old 11-19-2011, 06:00 AM   #15
syntax
syntax's Avatar
salamat sa DIY insan, kakahuyin ko na ung whiteboard namin para dun sa gilid gilid an aluminum at ung corners hehehehehe
Old 11-19-2011, 06:38 AM   #16
rickyml
rickyml's Avatar
Drives: Yaris 2008
madali lang insan... gusto mo gawa na lang kita.
Old 11-19-2011, 12:03 PM   #17
charlieXX
Corporate Slave
charlieXX's Avatar
Uy mga bro ako rin ha......one please....pasabit
Old 11-19-2011, 12:11 PM   #18
duke_afterdeath
duke_afterdeath's Avatar
astig ang DIY tol riki ang linis
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
New White Yaris Commercial WasabiAngel Photo-Video-Media Gallery 3 11-13-2014 01:59 PM
Simply Beautiful TS Commercial TheRealEnth Yaris TS Talk 12 10-25-2009 02:54 PM
Simota intake commercial Red Horse General Yaris / Vitz Discussion 10 10-15-2009 08:38 PM
New Yaris Commercial? weeze-dog Photo-Video-Media Gallery 16 08-18-2006 09:43 PM
Need LA Yaris liftback Owners for Yaris Commercial weinsteins General Yaris / Vitz Discussion 10 05-04-2006 05:42 PM
