Old 02-02-2007, 07:23 PM   #1
Biggie™
Biggie™'s Avatar
Drives: '07 3 Door Yaris of Doom!
ok now if u throw a short throw shifter and the way i see it each short throw per gear will save you about 1/2 sec.. out of 3 gear shifting will save u approx 1.5 sec.. from 9 sec down to 7.5 might be possible.. dont you think guys...i think i think.....
1. Because of inertia you wont de-accelerate during shifts, the momentum you already generated will continue to push you during fast shifts.
2. If a short shifter saves you 0.5 seconds per shift... And it still takes time to shift even though you now have up to a 30% reduction in throw, how long does it take you to shift with a short shifter? 1.2 seconds... Wow!
3. I'm pretty sure you can hit 60 mph in 2nd gear with a Yaris 5 speed... But I'm not 100%. I know for a fact you wont have to shift 3 times.
A short throw MIGHT save you about 0.25 of a second from your 0-60!
Biggie™ is offline   Reply With Quote
Old 02-03-2007, 04:54 AM   #2
Pars
Drives: 07 Yaris Liftback
When shifting from 1st to 2nd, the stock tires will cherp when doing it quickly. So, there's tiny bit of lost time from the tires braking loose.
Personally, I don't see how the short shifter will help since you'd still need to go down on the clutch faster then you could shift and the clutch travel doesn't get shorten with a short-shift kit. But if you've got really fast feet .25sec seems reasonable.
Pars is offline   Reply With Quote
Old 02-06-2007, 12:35 PM   #3
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i see gee thanks..
Old 02-02-2007, 08:56 PM   #4
spkrman
Drives: 1
2nd gear on the auto goes to 65, perhaps 63 or so... im lookin at teh tach at that point, not the speedometer lol
on that note, manually shifting the auto makes a very big difference 0-60... its basically the difference between landing nicely in the powerband and taking a second or so to get any power back... the shift from 2nd to 3rd is even more noticeable since the auto shifts itself even sooner.
Old 02-04-2007, 01:58 PM   #5
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
I have measured mine, at about 10.5 secs.
Old 02-05-2007, 07:05 PM   #6
Pars
The bigger 1.5L should be able to shave off 1.5sec off that time.
Old 02-06-2007, 03:36 AM   #7
Katana
Katana's Avatar
Yes, clearly!
Old 02-13-2007, 01:07 PM   #8
Katana
Katana's Avatar
Do u think that a short shifter really helps?
Old 02-13-2007, 07:31 PM   #9
leowhy
leowhy's Avatar
Drives: Yaris 1.5G
Hi, just being very curious...
we are now in an era where we are concious about FC, is the 0-60km/h or 0-100km/h still that important?
to me, if the delay is just merely a few seconds of difference, then that is negligable...
added:
also read from some of above posts... IMHO, generally, why objects with same weight fall at different rate because it also due to air friction.. :)
finally i found this forum!!!
leowhy is offline   Reply With Quote
Old 02-13-2007, 07:35 PM   #10
ChinoCharles
Drives: LB
No, see, I don't give a damn about fuel consumption... well at least not since I got a Yaris.
Old 02-13-2007, 07:44 PM   #11
leowhy
leowhy's Avatar
Drives: Yaris 1.5G
then may i assume u are a "need for speed" fan? salute:
Old 02-13-2007, 11:48 PM   #12
Pars
There's so many factor effecting the 0-60, it's not a reliable gage to judge a car's performance ability. All it seems good for, is bragging rights (and I do love to brag ).
Otherwise, max torque and it's flatness through the rev, combined with many gears (like six) that are nicely spaced out, would be a better judge of car's true ability. Oh yeah, also got to take curb weight into consideration.
Initial or under 2000rpm torque doesn't seem to be given due credit (probably because it has very little effect on the performance stats), but when you're not racing or doing high speeds, most of the engine's time will be spent in the low rpm range. Since N.A. tends to be more slow paced then Europe, the under 2000rpm range should be given more priority.
Old 02-14-2007, 02:54 PM   #13
Katana
Katana's Avatar
Αlways!
Old 02-19-2007, 11:02 AM   #14
marcus
toyota
marcus's Avatar
ill just add a nitro on it and that will take care of its 0-60 discussions..hehehe..
Old 02-20-2007, 03:42 PM   #15
Katana
Katana's Avatar
That sounds nice!
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
