Old 12-29-2010, 04:36 PM   #1
Judas Iscariot
Drives: 2008 Yaris HB
ok the picture is the wires and locations
Driver Side
----- White green Brown
off - 14 -- 14 -- 14
low 5 -- .4 -- 9
hi -- 4 -- 9 -- .5
Pass Side
----- Black Blue Brown
off - 14 -- 12 -- 12
low - 14 -- .3 - .3
hi -- 14 -- 8.77 -- .67
hoipe the chart is useful, Thanks for helping. i can't say that enough CT
Judas Iscariot is offline   Reply With Quote
Old 12-29-2010, 05:20 PM   #2
Judas Iscariot
I forgot o load the picture. Sorry
Old 12-30-2010, 03:26 PM   #3
Judas Iscariot
these are the numbers taken with the opposite side detached. sorry it took all day.
Driver Side
off - 11.2 -- 11.2 -- 11.2
low .22 -- .22 -- .22
hi -- .02 -- .02 -- .02
Pass Side
off - 13.8 -- 13.8 -- 13.8
low - 13.7 -- 13.7 - 13.7
hi -- 13.4 -- 13.3 -- .47
Old 12-29-2010, 05:56 PM   #4
No problem. Try pulling just the passenger bulb and then turning on the headlights to see what the driver's side bulb does in the three states with the other removed.
Old 12-30-2010, 09:55 AM   #5
Judas Iscariot
gonna do that on my lunch break...
here is the picture
Old 12-30-2010, 03:27 PM   #6
Judas Iscariot
oh and the white wire is actually grey
Old 12-30-2010, 05:16 PM   #7
Hmmmmmm. I am still reallllly thinking that the H-LP/AMT Relay might be the culprit.
With the bulbs both in, the charts should look like the following:
Driver Side
----- Grey Green Brown
off - 12 -- 12 -- 12
low 12 -- 12 -- .4
hi -- 12 -- .7 -- 12
Pass Side
low - 12 -- .4 - 12
hi -- 12 -- 12 -- .7
On yours, the low beam power is not being properly switched. On a working car, if you pull the relay, the high beams will work, but the low beams will not turn on at all (which is basically what you are seeing).
One last thing to try before replacing the relay is to unplug the DRL module's connector.
Old 12-30-2010, 06:44 PM   #8
Judas Iscariot
I disconnected the drl box and nothing. If Toyota is open tomorrow I will go get a relay. Or auto zOne. Some place like that hopefully has it
Old 12-30-2010, 07:12 PM   #9
If you can find a way to jump the two large blade slots together, while the headlights are on, and on low beam, you can do a final check to make sure that that relay is truly bad (since it is a $30+ relay).
Old 12-30-2010, 08:07 PM   #10
Judas Iscariot
Wow. Sparks! Lol I'm ok. But the headlight stalk was in off position and when I connected the two the lights came on. That was suprising! But it didn't fix it. Every time I think it will work It doesnt. Oh well. What's next?
Old 12-30-2010, 10:51 PM   #11
I meant to say ONLY connect the jumper with the headlight stalk on and in low beams. In that state, did the lights come on?
Old 12-30-2010, 08:16 PM   #12
Judas Iscariot
Another thing. I went put and pulled the relay. And the high beams do still come on, but the driver side lamp is still turning on both filaments. And they are still dim, really dim.
Old 12-30-2010, 08:25 PM   #13
Judas Iscariot
ugly....
Old 01-05-2011, 12:20 PM   #14
Judas Iscariot
i fixed it! lol, Thanks CT.... all i had to do was total it. problem solved.
Old 01-05-2011, 12:26 PM   #15
No way! There seems to be way too much of that going around lately.
Old 01-10-2011, 07:29 AM   #16
Kwakwaversal
Drives: Yaris 2005
I have exactly the same problem with my car. One minute everything was fine, next minute the low beams no longer work.
May I ask how you fixed it? I don't understand what 'total it' means in your summing up sentence "Thanks CT.... all i had to do was total it" :/ :)
Cheers.
Kwakwaversal is offline   Reply With Quote
Old 01-10-2011, 08:01 AM   #17
Cheers.
Unfortunately, by "total it" he means that he got in an accident and completely wrecked the car.
With your, have you checked the bulbs? The most common reason for no low beams is that both bulbs have burned out their low beam filament.
Old 01-10-2011, 08:31 AM   #18
Kwakwaversal
Drives: Yaris 2005
Oh wow, sorry to hear it. I am, however, hoping to have a better resolution. :o
I was thinking that the fact they both stopped working at the same time was too much of a coincidence, but the cost of new bulbs makes the most sense to test first.
Cheers.
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
aftermarket headlights be_ha Cosmetic Modifications (Exterior/Interior) 0 10-03-2010 03:06 AM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
Angel Eyes headlights Danish Yaris Cosmetic Modifications (Exterior/Interior) 9 02-13-2009 09:15 AM
JDM headlights yrsdrgn Cosmetic Modifications (Exterior/Interior) 6 02-13-2007 10:52 AM
