Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 08-22-2012, 05:15 PM   #1
macky
Drives: yaris
mga bro. paano ba mag palit head light bulb . dito kasi maabot masikip
macky is offline   Reply With Quote
Old 08-23-2012, 02:24 AM   #2
syntax
syntax's Avatar
Drives: Yaris Sedan 2010 "shadow"
@ duke pasooookkkkkk
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
syntax is offline   Reply With Quote
Old 08-23-2012, 09:55 AM   #3
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
@macky, if that's the case kailangan mong tanggalin yung buong headlight(housing) para mas komportable kang maalis ang headlight bulb, pero normally nadudukot yan ng iba.
jonimac is offline   Reply With Quote
Old 08-25-2012, 12:15 PM   #4
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
bakit masikip? head light bulb yata ang pinakamadaling palitan sa lahat ng bulb, hehe.. pagnahugot mo na ung rubber sealed cap angat mo lang ang clip ng bulb matatanggal na kusa un
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 08-26-2012, 01:57 AM   #5
bongskitamtam
bongski
Drives: yaris homeboyz
Mga pre konting katanungan lang about dun sa CAI nagtanung kase ako sa ghurabi nung pipe kay (Ford) kaya lng may sinasabi pa sila na may kailangan pa daw i modify para sa lagayan nung sensor parang magdadagdag ng elbow daw, panu n san ba idudugtong yun?
thanks..
bongskitamtam is offline   Reply With Quote
Old 08-26-2012, 05:56 AM   #6
jonimac
jonimac's Avatar
thanks..
@bongskitamtam, eto yung nilalagyan ng MAF sensor. Dati kasi pinuputol namin yung STOCK, makuha lang yung mounting ng MAF, pero ngayon may nabibili ng ready made. Pumunta ka sa AL AQSA may kabayan dun ROY ang pangalan, nandun din sa kanila yung mga tube extenders kung gusto mo ng CAI. Location? ....going out from Jolibee st., intersection yun diba? Pag kaliwa mo nasa kanan mo kagad yun AL AQSA na, daming anik-anik sa oto dun. enjoy!
Old 08-26-2012, 08:36 AM   #7
bongskitamtam
bongski
@jonimac , salamat pre cge punta ko dun, sya nga pala baka pede ako maging member ng yaris dito sa riyadh naririnig n nakikita ko kc ung mga kita kits nyo dito. salamat.:)
Old 08-30-2012, 06:27 PM   #8
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Pao nice to hear you are still here, musta na tol
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 09-01-2012, 08:07 AM   #9
bongskitamtam
bongski
mga pre magandang bukang liwayway sa inyong lahat! anu bang oil ang magandang gamitin? castrol 5w/30 or bili na lng sa toyota nung mismong oil na ginagamit nila? and ilang kilometers ba bago mag palit ulit 3,000 or 5,000?
thanks.
Old 09-01-2012, 11:42 AM   #10
duke_afterdeath
thanks.
sir bong, ito yung thread for changing engine oil http://www.yarisworld.com/forums/showthread.php?t=38393
Old 09-01-2012, 02:39 PM   #11
rickyml
rickyml's Avatar
Drives: Yaris 2008
sino nkapag differential oil na dito at nagchange na ng break fluid at transmission fluid? 80k na ako e kaya required na ito. mga magkano kaya ito?
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 09-16-2012, 09:26 AM   #12
bongskitamtam
bongski
Mga sir, ung simota ba na filter ok lng ba yun kesa sa k&N? para sa SRI lng. medyo mahal kc ung k&N.
thanks
Old 09-16-2012, 11:33 AM   #13
duke_afterdeath
thanks
ok din yun sir tested na yan,, yung ibang tropa nga generic lang gamit
Old 09-22-2012, 06:24 AM   #14
rickyml
rickyml's Avatar
Drives: Yaris 2008
magkano na ngayon ang market value ng angel eye headlight para sa yaris natin? yan ang next project ko eh.
Old 09-25-2012, 10:26 AM   #15
kaemong
Drives: yaris 2008
mga kayaris, ok lang ba ang FBK brake pads? nagpalit kasi ako ng brake pad sa harap, nagtaka ako bakit dun sa toyota ang presyo nila 200 SAR, nagtanung ako dun sa kabila pwesto sa old sinaya 45 SAR lang bigay nila sa akin. di ko alam kung nagkamali ung nagtinda o mahinang klase ung binigay. thanks sa inputs.
kaemong is offline   Reply With Quote
Old 09-29-2012, 08:56 AM   #16
syntax
syntax's Avatar
kaemong go for the original brake pads, importante ang brake pads.
Old 09-30-2012, 01:07 AM   #17
kaemong
Drives: yaris 2008
sabi naman ng mechaniko, maganda daw ung brake pads na yon. hindi kaya ngkamali lang ng pag presyo ung binilhan ko?
Old 10-15-2012, 01:53 AM   #18
syntax
syntax's Avatar
@ mcjeri... welcome po sa YWME, antay na lang natin ung response ni extremist
