Old 06-16-2011, 04:15 PM   #1
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
how much was the kit and did it come with everything you needed? i have seen kits for roughly $1600 but it says it does not come with management so i figure the cost to be significantly higher after you get everything you need.
I know you said you were going to wait and get all the details before you say what you paid but was just curious what your "kit" cost and if it came with at least most of the stuff.
I spent way too much time at work looking at your photo gallery. it is a good clean install. looks really nice.
Old 06-16-2011, 04:37 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
^ Carlos would be the one to ask about the price of the kit. I did some upgrades so I honestly cannot recall what the base price was. Additional stuff done was the FIC, powder and ceramic coating, gauges, boomslang, exhaust...I think that was over and above the kit however the kit comes with everything else really. The piping, turbo, hoses, high quality clamps, BOV, injectors, fittings, high flow downpipe, etc were all in the kit. His kit is similar to the Zage in that it gives you what would be the essentials and you pick up the "custom" stuff that you would want to go with it al a carte.
In regards to the install, thanks. Carlos did most of the work with assists from myself and my buddy John. He was professional and knowledgeable.
Old 09-14-2011, 09:20 AM   #3
fnkngrv
fnkngrv's Avatar
Well for those of you that don't know I have had issues since the install when attempting to use the FIC. I was finally able to get down to visit with CTScott and leave my car with him for the week. He has found a couple possible issues with my Boomslang harness which he is going to address so I am keeping my fingers crossed that I will actually be able to use the setup as it should be used. Since install I have been bypassing the FIC and using the stock ECU 100%. As long as boosting with WOT it has been great and dumping fuel as it should however if feathering the throttle the car will run lean. Not super lean, but lean nonetheless. I still have no regrets buying the custom kit from Carlos (Turbo_Yaris) as it has been solid and pretty much been able to leave it to run. I am not sure what the folks over at Boomslang are doing or whether or not there have been others that have had messed up harnesses? If this doesn't resolve my issue then the next step will be to approach AEM about replacing the FIC.
Old 09-14-2011, 10:29 AM   #4
Has it been determined with 100% certainty that the harness is defective? I can't tell from your post, especially this last part.
Old 09-14-2011, 10:32 AM   #5
fnkngrv
fnkngrv's Avatar
The answer to that would be no at this time however with the modifications that Scott will be making I am hoping for an answer in the next 24-48 hrs. We did shoot Brian an email to have him look at his harness since his was built and purchased at the same time as mine. I am awaiting a response from his as well.
Old 09-14-2011, 10:33 AM   #6
That will be very helpful. I have two on the shelf and need to know if they should go back to Boomslang for modification.
Old 09-14-2011, 10:37 AM   #7
fnkngrv
fnkngrv's Avatar
Will let you know for sure. I could have shipped mine back to Boomslang, but then the car would be off the road and I can't afford that. Also I have no issue with trusting Scott. He has been an immense help with all of my electrical questions over the last year.
Old 09-14-2011, 11:32 AM   #8
Tonight I will be modifying the harness, so we'll have the answer. The issue that I found with it last night is that the MAF (VG) signal and the Crank position sensor (NE-) signal are supposed to be "intercepts" rather than "taps" as they are wired on the boomslang. As-is. the F/IC can only read, and not override the MAF and Crank signals to the ECM.
Old 09-14-2011, 11:36 AM   #9
Brian
Brian's Avatar
I'm hoping to get my F/IC back from AEM this week. Everything was working perfectly with my Boomslang and F/IC except for the starting issue. Did Carlos modify your Boomslang at all?
Old 09-14-2011, 12:09 PM   #10
fnkngrv
fnkngrv's Avatar
If I recall correctly he only removed a couple resistors because the harness was designed for the 1nz for the scions and not the Yaris...but I could be recollecting wrong.
Old 09-14-2011, 12:12 PM   #11
I didn't see any signs that it has been modified.
Old 09-14-2011, 01:08 PM   #12
^ interesting. I remember Carlos posting that these harnesses were made for the Yaris, but maybe that was after that first one was made. My memory isn't that good.
Old 09-14-2011, 01:11 PM   #13
fnkngrv
fnkngrv's Avatar
I am trying to tecall conversations he said he had with boomslang but we discussed so much it is foggy.
Old 09-14-2011, 01:36 PM   #14
Brian
Brian's Avatar
I contacted Boomslang before I bought the harness and they said it was made for the Yaris. Is there anyone else besides the 3 or 4 known users that are actually using the harness?
Old 09-14-2011, 01:45 PM   #15
CTScott, Boomslang's answer:
Hello,
We intercept the MAF and CKP signals.
MAF is light green output--white input.
CKP is orange/white output—orange/black input.
Sounds like he’s reading the harness wrong.
Old 09-14-2011, 02:20 PM   #16
Hello,
My answer to them - Maybe they should try to get their act together...
On Adrien's Boomslang:
CPS (NE+) is orange/black input, orange/white output
MAF (VG) is white input, no output.
CPS (NE-) is yellow/black input, no output.
Both of these signals should be intercepts, per AEM.
Old 09-14-2011, 03:41 PM   #17
got pics? otherwise, it's a word game.
Further, Adrian's harness may not be the production piece they make now. That is still in question.
Old 09-14-2011, 04:24 PM   #18
Focus_Sh1ft
Focus_Sh1ft's Avatar
CTScott, just so you know - my crank signal is tapped. I tried to intercept it and the car wouldn't start. This make sense - the FIC only needs to see the crank signal, not manipulate it.
As for the MAF - that definitely is a problem (although I'm sure I don't need to be the one to tell you that lol).
On a side note: I'm bummed you didn't come down to Jersey for help Adrian. You could have delivered that kit I'm still hoping to buy from you
HKS turbo for mk1 yaris 1 litre 1SZ-FE nuttallacpw Items for Sale by private party 10 01-26-2011 05:03 PM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
