![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
No spoiler. Best place to mount reverse camera?
I want to install a reverse / rear-view camera. Problem is, I don't know where to install it. I do not like those license plate frame cameras or cameras that mount down there. It's too low.
I'd like to mount the camera up high, but I don't have a spoiler to hide the camera in. Anyone have suggestions / advice / recommendations? |
![]() Drives: yaris d4d 2007 Join Date: Oct 2010
I already see in the rear bumper...
#3 | |
That's still too low.
The cleanest way would probably be to remove the trunk keyhole assembly and use that hole for the camera. The obvious downside of that approach is that one would need an alternate way to open the trunk, such as with a door popper. This is what I am planning to do myself.
OTOH the rear camera kit that I got came with a drill bit that will let you make a hole pretty much anywhere, so that opens up a few other install options.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
Thanks tk. That's cool that it comes with a drill bit, but I'd be scared to drill a hole on the outside if my Yaris.
That's a really cheap camera. Does it work well? I see some comments about condensation getting into the lens. |
I would try mounting it to the side of the middle brake light, with the lens right against the glass.
I haven't installed the camera yet, but I did hook it up to a video capture card and it works pretty well indoors, both with light and in the dark.
I am 99% sure that the condensation issue (if it even happens) can be avoided by adding an extra sealant such as gasket maker before installing it. I personally think it was worth the extra risk, but as always YMMV.
SuperCircuits sells some very tiny cameras with pin hole lenses. With rear tint, you could cut a 1/16" pin hole in the tint, for the camera lens:
http://www.supercircuits.com/Securit...Video-Cameras/
I guess if I get tint I can ask the tint shop to cut a hole in the tint just for the camera before they put the tint on.
I'm actually interested in the Kenwood CMOS-300 because of its really wide viewing angles. I'm still looking though. I want a wide angle camera that also does night vision.
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2008
You need a reverse camera on a Yaris?!
If you can't back that up.....LOL! |
I don't need one. Just seems like a waste to have a unit like the Z130BT and not utilize all of its features (one being compatibility with reverse cameras).
#14 |
![]() ![]() Drives: 2008 yaris hb Join Date: Mar 2011
rear view camera location
I cut a hole under the hatch release it is perfect for watching the load on the trailer. Not so good for traffic, fine for backing up.
#15 |
So after all these months, I'm still contemplating a revers camera. I like CTScott's idea, but an issue I thought of with that location is glare from the reverse light. Anyone have any other ideas on mounting locations?
#16 |
On the Roof !!!! you could be a storm chaser..J/k..How about doing something where the rear Toyota Emblem is ?
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
#17 |
Only Happy When it Rains
How about removing the rear window wiper and mounting it in there?
Colin Chapman disciple |
#18 |
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
I mounted mine behind the hatch glass on the plastic brake light housing. It sits up nice and high, and is inside the car so it stays out of harms way...I never use it, but I thought it would be fun to have.
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
| Rockland Toyota's Scion Revolution 4.0 | phyre76 | NY / NJ/ CT / PA | 70 | 08-11-2010 05:20 AM |
| DIY Camera Mount -- No Cost Version | KCALB SIRAY | DIY / Maintenance / Service | 20 | 06-08-2009 03:12 PM |
| Camera mount in action | m911gt | Photo-Video-Media Gallery | 43 | 02-04-2009 03:50 PM |
