Old 04-14-2011, 04:51 PM   #1
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
You can set the psi to be 0 and yes there is a difference in tq over stock. Not by much tho. Is it worth the time? No. Why have a turbo to run 0 psi?
Yoda is offline   Reply With Quote
Old 04-16-2011, 11:46 AM   #2
Is anyone going to answer post 25?
Old 04-23-2011, 06:25 PM   #3
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Blue vitz, it is possible to do as you have suggested, I can think of numerous ways to do it. Restrictors on the inlet to limit air flow and boost, soft wastegate springs as you have suggested, pressure activated solenoids to bleed excess boost (may cause emissions problems though). All though have down sides and require more thought so that you could obtain a very low boost turbo setup with minimal losses at high revs.
rob323 is offline   Reply With Quote
Old 05-23-2011, 11:08 PM   #4
...I like Ovaltine
Oil Pressure problem... Suspecting Turbo issue Parmas DIY / Maintenance / Service 16 12-13-2010 04:23 AM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
