Old 04-18-2011, 03:04 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
wow toyota canada seem to switch to denso no more ngk sparks plug on toyota system friend just checked it..
Old 04-18-2011, 03:09 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Wonder how the difference would be noticed if at all on a boosted motor...
Old 04-18-2011, 03:53 PM   #3
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
looks like plug change at 43,000 miles is coming up....
Old 04-18-2011, 08:37 PM   #4
auxmike
auxmike's Avatar
I stuck with the OEM plugs since I figure the Toyota engineers used Iridium for a good reason besides service intervals...
Old 04-18-2011, 10:45 PM   #5
Hershey
Point is , the iridium is not a miracle plug , needs to be replaced sooner than 100,000 miles . Replace at what mileage you feel comfortable with by doing it yourself or a trusty mechanic . Have used N.G.K. in past TOYOTAs with good results . Like posted before , had the DENSO iridium in a 2000 COROLLA changed with NGK iridium ( bought at A.A.P. ) by a service center at around 75,000 miles ( give or take ) and the car ran better . Little more pep and small gain in gas mileage . Even the other 1/2 noticed it .
Old 04-19-2011, 12:07 PM   #6
RedRide
RedRide's Avatar
Toyota owns most of Denso and that's the reason why they use Denso plugs and other denso parts.
FWIW, My '02 Celica came stock with NGK plugs and they were perfectly fine.
I assume that Toyta used the NGK plugs whenerver there was a supply plroblem with the Denso plugs.
Personally, I do not know if they still use them.
Old 04-19-2011, 12:42 PM   #7
"G"
Drives: 2007 Yaris Hatch
Dude they have not been a part of toyota for 62 years >> http://www.globaldenso.com/en/aboutd...ory/index.html Denso and NGK both bid on contracts to supply all automakers with their product from the factory. Denso happened to win the yaris contract. Nothing to do with ownership but rather dollars and cents. Denso and NGk also private label their products for toyota and numerous other auto companies. That is why if you buy from the dealer some will have denso on the plug but a different part # which is usually the toyota part #. Denso will also assign a different part # to signify that it is a toyota private label plug.
"G" is offline   Reply With Quote
Old 04-19-2011, 01:15 PM   #8
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
The difference is whether or not you're going to have misfires under load. Gap is very important on an NA to FI engine. You can't just run the same gap spark plug.
Focus_Sh1ft is offline   Reply With Quote
Old 04-19-2011, 10:15 PM   #9
RedRide
RedRide's Avatar
Yes, they are an independent company and they must bid for Toyota contracts just like NGK, etc.
However, as I understand it, Toyota owns a large portion of Denso stock so, yes, Toyota owns part of Denso.
Old 04-21-2011, 12:44 AM   #10
special_k_828
Drives: 2006 Yaris CE 2-Door Hatchback
What are the torque values for the plugs?
special_k_828 is offline   Reply With Quote
Old 04-21-2011, 08:04 AM   #11
marcus
toyota
marcus's Avatar
13 lbs but some says 15 lbs
Old 04-25-2011, 12:16 PM   #12
marcus
toyota
marcus's Avatar
just an update on denso iridium gap from my research.
bigger gap vs stock which is normal and the iridium part of it will compensate for bigger gap..no need to adjust but you can..
Old 04-26-2011, 04:44 AM   #13
rl67pinoy
Drives: 2007 Ghetto VITZ
HERE YA GO 120K ON 2007 YARIS H/B AUTO
OIL CHANGED EVERY 5K MILES
LUCAS F/I CLEANER EVERY 5K MILES
CHEVRON 92 OCTANE ONLY
rl67pinoy is offline   Reply With Quote
Old 04-26-2011, 09:16 AM   #14
"G"
OIL CHANGED EVERY 5K MILES Not long enough per toyota.
LUCAS F/I CLEANER EVERY 5K MILES Not necessary.
CHEVRON 92 OCTANE ONLY Waste of money.
Old 05-04-2011, 04:54 PM   #15
SKurj
Drives: 09 Yaris 3dr HB, BRZ
Eh? Here in Canada oil change interval is 8000kms... close enough to 5k miles...
On the echo i always left it to 10,000kms and used synthetics, no issues.
In 258,000kms on the echo I changed plugs twice, always worked lovely, and I used iridiums. New Yaris with only 32k on it, likely has OEM plugs in it, I may change them up soon just for the hell of it.
SKurj is offline   Reply With Quote
Old 04-26-2011, 11:23 AM   #16
Hershey
Lookin' good .
Old 04-26-2011, 01:23 PM   #17
yaris2010RS
yaris2010RS's Avatar
what the hell happened to this thread? lol, it started out so nice......
very nice plugs at 120k, those can almost be put back in and used for a while longer.
on my moms camry which is at just shy of 300,000km its only on its second set of plugs, firs set wernt changed untill almost 190,000km. the random plugs i put in still look very good.
my way of thinking are, plugs are plugs, trolls are trolls :)
Old 05-02-2011, 07:51 AM   #18
BLAZINBLUEVITZ
maybe its me BUt at 43k with a plug change car feels smoother throughout the gears and start up in the morning went from a 5-6 second crank to 2-3 seconds.....
Pics Pics Pics Jahbs Australia 4 06-30-2010 12:06 PM
HELLAFLUSH III pics contraband831 Photo-Video-Media Gallery 37 01-10-2010 12:11 AM
Oh I am so mad my dealership had the wrong gap on my plugs joeharth Fuel Economy Forum 10 03-25-2009 05:26 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Extra parts? (Or where do these plugs go) jah General Yaris / Vitz Discussion 6 05-01-2006 10:33 PM
