Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
sounds like a great product...i'm still a little weary...i really like how stock feels in both cars
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
malibu,
you are a racer right? get the extender and the short shifter and you get the feel of stock but it is closer to the steering wheel. I did this just because I am used to trucks vs small cars. it is a good feeling. that is just my 2 cents. |
#3 | |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
well, i had some more time today and went out to try to put the bracket on again. there were a few times trying to get the retainer clips off that i thought about quitting again, but i finally got it, ended up using pliers on the passenger side clip. after the clips came off, everything else was a breeze. haven't gone driving yet with the new bracket, but i'm heading out this afternoon and i'll see how it feels then :)
thanks for everyone's help with the install. |
#5 | |
![]() ![]() ![]() ![]() Drives: 2007 Yaris manual dark silver Join Date: May 2006
having problems with retainer clips how do i get them off??? please help
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
use a really big flat head screwdriver, place it inbetween the bent lip at the top of the retaining clip and the top of the cable (which happens to be metal) and turn the screw driver. this should wedge the retainer clip up. readjust the screw driver a few times and it should losten it enough to get it off. it helps if the tip of the screw driver is 1/2 to 3/4" wide. also depending on your screwdriver design, you can put a wrench around the handle and get even more torque in your twisting.
this may not be the BEST way to do it but it worked for me. |
^ That works, and so do channel lock pliers from the top.
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
just installed today..2 hours of frustration.
I love the new feeling, even shorter shifts than before (full NST ssk kit). Pics show the difference in height the cables sit. Without the bracket, there was damage to the engine bay short shifter. The bearing bit into the side.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
^now we have your finger prints. I'm going to rob some banks.
p.s. finally go the bracket installed
#11 | |
Shouldn't there be one on your new MI bracket? I drew one in where it ought to be (in blue above the cable clips)... I notice that you have an '07. Did they not have the bracket for that model year? Or did you skip putting it back in?
#12 | |
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
Must have just not put it back on. The SSK bracket doesn't come with a new wiring bracket, but it does have a place to screw the old wiring bracket back on.
#14 |
Finally Got mine Yesterday
thank You Garm ![]() ![]() ![]()
#15 |
Crap, that's where the Micro Image decal goes!? Why didn't Garm tell me? Now I have to pull everything back out to put the decal on...
#16 |
![]() ![]() Drives: 2007 LB Join Date: Jan 2009
Garm, I got my bracket today, installed it and I like it! I followed the pdf that was posted and had no problems with the removal or new install. Total time was right at an hour and I'm an old slow guy. The only hard part is the silver wire harness holder is annoying and the 14mm bolts needed convincing with the 18" breaker bar and all was golden.
I've only driven it around the block to test so far and the difference between with and without the bracket is subtle but noticeable with my old piggies ssk. It's smoother, feels more solid between shifts and takes less wrist effort. Thanks |
#17 |
![]() ![]() ![]() Drives: Black '08 Yaris Hatch S Join Date: Aug 2011
Coooooooooooooooooooooooooool.
-Will- |
#18 |
Excellent, nice to hear of a relatively problem-free install!
| TWM Shift Knob SALE Until July 15th! | TWM Performance | Sponsors Classifieds Area | 6 | 10-30-2009 12:46 PM |
| NEW GROUP BUY: NST Short Shift Kit (NonStopTuning) | NonStopTuning | NonStopTuning | 245 | 08-28-2007 03:53 PM |
| short shift: NST or TRD? | cali yaris | Performance Modifications | 21 | 07-07-2007 03:38 PM |
| Feb Shift Knob Sale From TWM! | TWM Performance | Sponsors Classifieds Area | 2 | 02-18-2007 10:15 PM |
| Having Trouble with TWM Short Shift Install. Need Help | xfatefailsx07 | Performance Modifications | 3 | 10-10-2006 01:38 AM |
