Old 06-02-2011, 10:44 PM   #1
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Hatchback Trunk Cylinders
Anybody find theirs doesn't lift the trunk all the way up anymore? And if you did what did you do to fix it short of buying a new one? They seem to be well over a hundred dollars EACH.
Old 06-02-2011, 11:26 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
try car quest or crappy tire
Old 06-02-2011, 11:31 PM   #3
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
For.. what? New ones?
Old 06-02-2011, 11:54 PM   #4
Bluevitz-rs
yeah... but is it that the won't hold the hatch up, or just that they don't lift it on their own anymore. Cuz mine never really lifted the hatch much past half way unless it's really hot out, but the never dropped once pushed up.
Old 06-03-2011, 11:20 AM   #5
The Yaris spring shocks are 6" stroke, 17" extended mounting center line, 80 lb (359N) gas shocks with ball socket ends. Doing a quick web search based on those measurements, I've seen generic replacements for as little as $15 each.
I am tempted to upgrade to 100 lb or 150 lb ones (which are common ratings) too see if it helps with the winter sag. One evening this past Winter In a dark parking lot I whacked my head so hard that I drew blood.
Old 06-03-2011, 11:46 AM   #6
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I did the same thing in my garage the other day because the damned hatch was sitting a little lower than normal(I didn't help it up the last little bit). I didn't draw blood, but it hurt enough that I had to stop what I was doing for a minutes and curse the heavens. Now that I've sound deadened the hatch it's a little heavier, which in turn has made it open even less...
I'd be interested in a part number if you decide to swap in something more powerful, and it works.
-Type 07 FFL-
My odometer 03/11
Old 06-03-2011, 12:56 PM   #7
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
LOL I thought I was the only one that would do something like this! Gave myself a nice little goose egg a while back doing the same thing. I felt a little sheepish... heh
Old 06-03-2011, 01:23 PM   #8
ya, mine suck in winter, too
had the same issue in my matrix....though i had them replaced under warranty once...
Old 06-03-2011, 01:42 PM   #9
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
my experience with aftermarket hatch struts has gotten me no where. i had 2 different auto supply stores order me these things with a toyota part number as reference and they were wrong both times.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 06-03-2011, 01:52 PM   #10
I believe that the AP Products 010-170 would be a direct replacement.
This place sells the 010-170 for $18 each:
https://www.makariosrv.com/products/...-Products.html
Here's a pair of 120 lb ones for $30 (and the same vendor also carries 101 and 110 lb ones for the same price):
http://cgi.ebay.com/ebaymotors/ws/eB...em=#vi-content
Old 06-03-2011, 02:01 PM   #11
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
^^someone should buy these and see if it works.....
Old 06-03-2011, 02:23 PM   #12
I just ordered a pair of the 101 lb ones.
Old 06-03-2011, 02:33 PM   #13
mazilla
advocatus diaboli
mazilla's Avatar
Sweet.
-Type 07 FFL-
My odometer 03/11
Old 06-03-2011, 04:07 PM   #14
Shinare
Shinare's Avatar
two 120 pounders... would that be pretty difficult to close once the hatch was opened?
Old 06-03-2011, 10:10 PM   #15
The pair of 120s might be too much, that's why I ordered the pair of 101s to test. They shipped today by USPS from New York, so they should be in my hands tomorrow or Monday.
I have a spare set of OEM ones from Crashy. I did a test today where I measured the compression force at ambient (72F) and then again after putting one in the freezer for an hour (20F). At 72F the compression force was 80 lbs. At 20F it decreased to 72 lbs.
Old 06-04-2011, 01:20 PM   #16
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Holy awesomesauce CT. I've been busy the last couple days so I haven't been able to check but I'm eagerly anticipating your results!
Old 06-04-2011, 07:04 PM   #17
auxmike
auxmike's Avatar
Yeah, I have to push mine up so it opens all the way. Looking forward to the results!
Old 06-04-2011, 09:21 PM   #18
thepartsmancometh
Drives: '08 LB, '07 WRX
Luckily me wife primarily uses the yaris, because I bang my head off the damned thing every time I open it! I have some spare Sienna struts laying around I might try (they were warranty scrap)
thepartsmancometh is offline   Reply With Quote
Where can i get a Hatchback trunk cover for cheap? Syroyizhka Cosmetic Modifications (Exterior/Interior) 19 10-29-2013 12:59 PM
3 Door Hatchback Questions Dorkinheimer General Yaris / Vitz Discussion 12 01-16-2012 05:30 PM
Hatchback Trunk Cover KrazyDawg General Yaris / Vitz Discussion 24 11-08-2010 02:00 AM
is this trunk kit ok for our hatchback ?? vten DIY / Maintenance / Service 3 10-31-2009 02:49 AM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
