Has anyone tried with the viewsonic view pad 7??
iSRA |
Any updates on Tablet installs?
Apps to use? I just use Power Amp and Torque. I hope to be able to run at least honeycomb so there is an easy way to multitask and change between those 2 apps. Plus dragging to see notifications does suck...compared to Honeycomb tap.
I've found the screen is very unresponsive in cold temps - sort of anticipated this.
So to solve it I bought a motorcycle grip warmer kit, cut a piece of aluminum the same size as my mounting block, slapped one of the warmers on the aluminum panel and screwed it to the mounting block. I've got it installed but haven't wired it up yet. It gets so warm I'm just going to use to rapidly warm the unit up when I need it. When I have the time I'll probably build some sort of temp control circuit and add that on. I've been using PlayerPro as the music player. Mostly because it has a volume control slider vs. the difficult to use fake knob style that Power Amp has. It made me realize that a lot of apps don't account for units without physical volume controls or in this case without access to them. You would think that every type of media player would have a volume control always on or available from the player screen. Not so. And it's annoying. |
B-B-B-B-Bump!
Since I got the car back, finally time to move on with my own implementation :D My idea was to brace the tablet against the bezel by way of epoxied bolts and metal straps across the back: ![]() ![]() ![]() But now that I have it in front of me, this solution does seem far too complicated, and may not even fit... So I'll probably follow Altitude's example. This tablet does not have a flat back, and is also a bit wide (the top edge will hit the AC swivel thing), so it may not be the best choice... Might have to try a Nexus 7
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
I was just thinking, at the price, a Nexus 7 would be perfect, especially on the size as I'm already running a 7" DVD player.
Keep up posted Thomas!
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
One thing to be aware of .. is that in some places (like in Alberta where I live), it is illegal to have a aftermarket video / computer screen in view of the driver. So .. just be aware that you could get a ticket from the police with such a setup.
taking shape nicely:
![]() No need for bracing, it's just sandwiched in there quite snugly... But I can't fit the AC vents, might just put some mesh behind the holes :) Screen is bright enough for daylight use, and I have a matte screen protector on it so it's better than I feared... Only problem is the screen automatically dims after a little while, I think I can remedy this with Tasker, though!
screen gap seems huge on yours. i know mine is not perfect fit, but seems less visibile
![]() so we got 3 peeps with tablets in.
yeah i', looking to put some pieces of plastic on the sides to cover the gap, eventually...
The next problem I have is that my "2.1A" charger seems to not be putting out enough amps to charge the damn thing in use...
#1 Lemming
32 GB Nexus 7 is rumoured to be announced soon...at the same $250 price tag as the 16 GB...
good to know... I've already bought two slightly cheaper tablets and returned them for defects... Should've just gone for the real thing from the start and save me all the trouble.
Totally getting a used 8gb nexus 7 once the 32gb model comes out. Considering that the n7 has a usb port, the extra storage space isn't really worth the extra cash IMO.
#12 | ||
#1 Lemming
If you have other information (admittedly, I haven't researched a TON when it comes to hacks/rooting the N7) on how to use external storage, please link!
^^ You're right. The USB ports on tablets are just for charging when a separate power jack isn't included and for connecting to a PC. They do not act as USB Hosts which would be required to use USB storage such as flash drives.
Look for tablets with a MicroSD card slot for external storage. |
#14 | |
#15 | |
#1 Lemming
Just pulled the trigger on a barely used 8gb n7 for $175. I'm sure I would've gotten one for even less, but I grew a bit impatient.
![]() Drives: 2 & 4 wheels Join Date: Nov 2012
Cool. Does it have Jelly Bean? Jelly Bean (v4.1) enables usb-audio. This allows the use of an external USB-DAC and thus much better sound quality (assuming you rip at something better than 96kbps).
| Dash lights won't work after installing new head unit? | blh4645 | General Yaris / Vitz Discussion | 10 | 04-06-2010 06:17 AM |
| Need help with installing head unit Pioneer AVH-P6850DVD | JCMoon | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 08-31-2007 10:27 AM |
| Req: Head unit suggestions. | xed | In Car Entertainment + Electronics (audio / video / alarm) | 21 | 08-09-2007 07:38 PM |
