Free Mustache Rides
what do you guys think of sunpro gauges? just as bad as glowshift?
a cheap gauge is a cheap gauge. It's below my tolerance for quality and reliability. Someone else might like them just fine, though.
I run Faze Gauges. It's an off brand of sunpro. Mechanical water temp and oil, and 5" tach with shift light. Only problem with them is the indiglow backlight is blue and VERY bright at night unless you run resistors on the power supplies. Also one of the power supplies is hit and miss whether the gauge lights up or not.
Edit: forgot to mention they're very accurate too. |
#4 | |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Ptuning.com |
HAHA, well, 6 years and never so much as a drop has leaked. But even that said, I'm going to switch to electronic gauges in the future. My only issue with the mechanical ones is that I can't take them out if I need to because they're connected to the engine. LOL
Is the exhaust manifold in the "brand new turbo kit for a Yaris" going to fit your car? You might want to do some measuring and a test fit it to see if you are going to have to buy one of those as well. Since it's obviously not a Yaris kit, just a generic incomplete kit that the seller figured out wouldn't work on a Yaris, you may want to double check. Hate to see you get that far and find out you have one more part to buy.
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
I am running Auto Meter Phantom gauges. I tried some POS tachometer from EBay for 60$, and it now sits on a shelf. It was unreadable during the day and inaccurate. It also had a stepper motor that was very noisy. Auto meter and good quality and they been around forever in the muscle car crowd. Cost only half as much as Defi guages.
C'est la vie
This is the intercooler I am using now. It fits perfect with the crash bar, and is the perfect size for a yaris with 10psi or less. To big a cooler will just add a lot of lag at low psi. I could not find the exact kit I bought with the pipes and BOV. They are all available separately though. U will still need Two 2"-2.25" silicone reducers, and a 2.25" intercooler pipe kit with bov. Make sure the pipe kit has at least 2, 180 degree bends. U will need them at both ends of the intercooler.
http://www.ebay.com/itm/Universal-28...#ht_4355wt_780 |
Free Mustache Rides
there is a guy with 3 autometer gauges and a pillar in texas that wants 100 for it, may consider that.
stove, i didn't even think about that, but that makes a lot of sense. a bit nervous now. thanks for the intercooler page, and the advice on the 180 bends. i was thinking about sending my piping over the the engine like i had seen someone else do on here, cause i studied your pictures a million times and cant figure out where you sent you piping.
I have silicone tubing and reducers in a number of sizes in stock, once you know exactly what you need. I carry Flex Technologies, it's a bulletproof brand a lot of racing teams use.
#11 | |
![]() Drives: Toyota Yaris 1.5 M/T '06 Join Date: Oct 2009
just knew
really!...) when at full boost condition. all stock...
Free Mustache Rides
who will be shooting at me? haha. so should i get an idea with my current tubing and measure a bit, then shoot you a pm?
You should have your piping sized and placed so you know how many joints you have and what angle (0, 45. 90, 180 etc.). Or buy what you know you need and fill in as you go if you don't have clear picture of how all the pieces are going to go yet.
C'est la vie
If U check my profile, "turbo project pics" there are more pics of some pipe routings.
#15 | |
Free Mustache Rides
you guys are fantastic and i have greatly appreciated all advice, but due to my wife getting cut back on hours and a decrease of tips at my job, the turbo kit is going on the back burner. ill mod in other, cheap ways like normal, but i'd rather do something this big when i had money to do it right the first time. at least i'll know what to do different next time, and i've learned a lot. thanks guys.
^ hadn't thought of that. Yet another good reason.
| Dash destroyed in electrical fire. | purpleminx | General Yaris / Vitz Discussion | 79 | 06-12-2009 03:53 PM |
