Old 11-06-2017, 05:35 PM   #1
mr_robot
Drives: Yaris
I fixed mine over the weekend. Just loosened both the top and bottom bolts, used a prybar wiith one hand and re-tightened with the other pulling it as hard I could and done.
No more squeaky belt.
mr_robot is offline   Reply With Quote
Old 11-07-2017, 09:32 AM   #2
dogsridewith
Drives: 2007 2-door hatchback
Serpentine belt tension adjustment Toyota Yaris
Overtightening a serpentine belt destroys driven components and idler bearings.
Old 11-08-2017, 11:39 AM   #3
mr_robot
Drives: Yaris
Mine has been quite since.
Old 11-08-2017, 11:55 AM   #4
white89gt
Drives: 07 Yaris Hatch
As soon as I went to the Scion 100 amp alternator, mine has quit squealing. The Scion alternator uses a de-coupler pulley, so I think that has something to do with it.
white89gt is offline   Reply With Quote
Old 11-08-2017, 05:26 PM   #5
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Check out this 'interesting' video...
https://www.youtube.com/watch?v=HRrVMtyIqIY
When I first got my car, it squealed badly, partially because the previous owner put belt dressing on it. I can confirm that delaying ignition does work, at least for belts that squeak when the engine is first started. It did on mine anyway.
Old 05-23-2025, 06:40 PM   #6
drunix
Drives: 2010 Yaris 3D LB
The smooth side of the belt on mine was shiny probably from slipping. Increasing tension would not fix it. I took the belt out, lightly sanded it (probably 320 grit emory cloth) on the non-ribbed side to take the shine off, and also sanded the smooth pulley to clean it up. It's now completely totally silent for the first time in years.
drunix is offline   Reply With Quote
Old 06-04-2025, 10:22 AM   #7
esse10
Drives: 2009 yaris 2 door
mine hasn't squeek for yrs now. Just use a good quality belt and tighten it correctly, not too lose cause it'll squeal or not too tight cause it degrades it and wears out pre-mature.
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Squealing Belt rossman DIY / Maintenance / Service 8 01-31-2012 01:58 PM
Supercharger Belt Slip Possible fix quemoto Forced Induction Forum 20 03-04-2011 02:55 PM
2010 Prius brake problems easy fix. best video ever! dinamix Off-topic / Other Cars / Everything else Discussions 6 03-14-2010 11:00 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
