Old 06-11-2012, 10:09 AM   #1
pimp and his friend did it themselves. I had my bottom end built by someone else.
Old 06-13-2012, 10:35 AM   #2
djgab101
djgab101's Avatar
Drives: toyota yaris
Finally got my car from the tow company Sunday I shall start stripping down my car! Find out wat actually happened to my engine!
Would everyone agree that my engine has been damaged from a bad tune? If it's only on 8psi with engine damaged tune seems to be the problem!
djgab101 is offline   Reply With Quote
Old 06-13-2012, 11:50 AM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I know this is kinda far fetched.. but If it you had the money, when ever a check engine light comes on, the ecu will take snap shots of (correct me if im wrong) 10 seconds before the CEL came on and after. So you can see what ALL the sensors was reading when your engine blew up. Ex, oil pressure drop, fuel mixtures, knocks/pings.
only reason i say this is pure curiousity.. At lexus, we could see what happend and what RPM, engine temp, etc. the CEL took place and try to duplicate it.
Like I said. It's a long shot and would prob have to pay for a tow truck and pay a diag fee.. They can use thier laptop TechStream tool and print out a copy for you
-Derrick-
Old 06-13-2012, 05:48 PM   #4
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
May need to go to a Toyota dealer to get scanned with the oem scanner to get that freeze frame info.
pimp my yaris is offline   Reply With Quote
Old 06-13-2012, 06:04 PM   #5
pimp my yaris
C'est la vie
Building the engine yourself is certainly possible, but I wouldn't call it easy. I was lucky to have a friend with some experience with a few engine builds under his belt to help out with checking piston ring end gaps and assembling crank main caps just right. I also worked as a dealer mechanic for about 12 years. Although I installed many engines in that time and also removed many cylinder heads, I never rebuilt a lower end or short block. I am pretty sure I could pull it off this build by myself now but if I didnt have the helpful tips I got I may have just dropped the short block off at a "known good" engine builder.
Good luck whatever path U choose
Old 06-14-2012, 09:52 AM   #6
djgab101
djgab101's Avatar
I know wat you talking about and yes that is a great idea but how much it would be is another thing cause toyota by me where not even interested in doing a basic service on my car cause it was modified i had to sign papers so they are liable!
thanks for ur advice! greatly apprepicated looking around and thinking all options avaliable
Old 06-14-2012, 11:37 AM   #7
ilikerice
ilikerice's Avatar
yea, completly understand. I still have small connections with toyota, until everyone I used to work with finally quit or retire, so I can get access to techstream tool. Again, if no connections its basicly if you have money to throw away.
Anywho.. good luck on your build.
-Derrick-
Old 06-13-2012, 06:38 PM   #8
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
speaking of a good know engine builder, is Ptuning the only company that offers a bottom end build for the 1NZ-FE?
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 06-13-2012, 08:34 PM   #9
^ Nope. We can get that done for you. My car is a great example of a reliable, well-built result.
Ptuning has a great rep as well, and might be geographically more desirable.
Old 06-13-2012, 09:09 PM   #10
Golddeenoh
Golddeenoh's Avatar
yea but if I send it to Cali to get done then I get to bug you more :D ;) don't worry wont be soon but I'm starting to plan it more and more, now to give the wife some money for her down payment on a new 5.0 then I can reinvest money into another Yaris+build
Old 06-24-2012, 11:09 AM   #11
djgab101
djgab101's Avatar
Okay started pulling it apart haven't got the engine out but found a huge crack under the 4 cylinder smashed so bad hit my turbo piping made dents and small hole! Also have a major crack near the starter motor! Hopefully have the engine out and disassembled soon!! I will post photos tomorrow of the progress
Still umsure about my rebuild tho
Old 06-24-2012, 08:43 PM   #12
pimp my yaris
C'est la vie
Everybody loves pictures!
Old 06-24-2012, 09:03 PM   #13
+infinity
Old 06-26-2012, 02:19 PM   #14
thefalls
Drives: Axio GT
As above,pictures will be a boost for us.
thefalls is offline   Reply With Quote
Old 06-30-2012, 06:55 AM   #15
djgab101
djgab101's Avatar
Who can spot the Problem!? ahah
well i have finally got time for my car just need a engine hoist to take it out then ordered nesscairy parts to put it all back together again! my 4th cylinder was the problem seems rod broke made holes everywhere front bottom and back has holes! not sure about the top! i am sure u can see it in the pictures!
Old 06-30-2012, 03:12 PM   #16
whoa. OUCH
Old 06-30-2012, 03:58 PM   #17
Golddeenoh
Golddeenoh's Avatar
looks like you may have spilled some oil a tad bit there.
:D
Old 07-01-2012, 12:06 AM   #18
djgab101
djgab101's Avatar
Well engine is ready to be hauled out just need to buy an engine jack! Gram u will be hearing from me about parts
My plan is I am not gonna forged my internals I am going to get a stock engine change my clutch to the clutch master get new injectors I feel my cars injectors are maxing out and leaning out which bad if I can eliminate as many possibilities as possible hopefully I find where in my tune is the problem! Planning on get a boost controller so during the week I will run very low psi around 4! So I can take some stress of the engine! Running a car at extremely low psi or no psi is that sufficient air flow into the engine?
Someone said they had to retard their timing map so they could get the car to go Redline! Btw just some fuked up news the company who tuned my car has closed down and being auctioned off!!
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Boosted Yaris Quarter Mile Times 1.5 Forced Induction Forum 0 01-03-2010 05:49 PM
Yari Boosted, Enge lite... N3misiS Forced Induction Forum 14 11-20-2009 07:22 AM
Going Boosted FryGuy Forced Induction Forum 53 03-01-2009 10:01 PM
PE Boosted Yaris Video jinxor Forced Induction Forum 16 02-06-2009 02:33 AM
