My Yaris is a "racecar"
Drives: 2007 Yaris hatchback Join Date: Jul 2016
The switch in question replaces the pedal up stop bolt. Look where the clutch pedal sits when you're not pressing it.
-Karl the Uber/Lyft Driver |
![]() ![]() ![]() Join Date: Sep 2014
can i use this https://www.aliexpress.com/item/High...e-b2f5a6af3066
![]() Drives: yaris sedan 2011 Join Date: Oct 2016
Dear Friends!
Tell me known yaris sedan 2011with 1.3 /2NZFE engine, also Yaris sedan 2014 with 1.5 engine can be to installed CCS ? Thanks a lot! |
Dear CTScott.
I m looking for pin ccs from ECM for vios\yaris sedan 2014-2015. Tell me pls |
![]() ![]() Drives: Yaris MK3 1.33L Dual VVT-i CVT Join Date: Jun 2014
Hi I have yaris 2013 multidrive. Is it possible to add cruise control on it?
![]() Sent from my SM-G935F using Tapatalk |
Installed cruise control and its working perfect. Along with cruise controlinstalled speed limitter but dont think that is working, may be im doing it wrong.
![]() Drives: YARIS TOUCH Join Date: Feb 2016
Hi guys,
this is my first post inhere I just fit the cc switch to my french made Yaris 2012 NSP130L 1.33L gasoline with 1NR-FE engine and 6 manual transmission, but the cruise light won't come on when switched ON. has the radio touch system with the bluetooth call buttons on the right of the steering wheel aswell. any advices please ? |
#8 | |
Not need light on when ccs work.
![]() ![]() ![]() Drives: 2016 Yaris 3 Dr Super White Join Date: Mar 2016
I have a US 2016 Yaris L. I popped the airbag off and to my suprise, no wire to connect to the switch and no screws to secure the switch. Do any of you know what the deal is? I thought these things are prewired for cruise control. Also does amyone know the screw size to secure the switch? Thanks!
#10 | |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
yeah im not finding a diagram on my GSIC ![]() looks like a trade secret thing. just like how the lane departure etc have no diagrams online for spare parts. |
Thanks for checking. Hopefully someone will have knowledge of my situation.
Installed cruise control stalk and it is working perfect. Along with that installed ASL switch in the steering wheel. But it is not working. Checked the connection in the back side of steering wheel and found a light green cable is there and both from ASL and this one are connected eachother (verified using multimeter).
![]() ![]() ![]() Sent from my SM-G935F using Tapatalk |
![]() Drives: 2012 Yaris L, 2017 Yaris L Join Date: Mar 2012
i just picked up a 2017 Yaris L, US model made in France, need to add cruise.
#14 | |
1) On/Off Switch/Stalk - 84632-08021 2) Clutch Switch - 88280-42010 (For a manual transmission) 3) Stalk Cover - 45186-0D150-C0 I found a decent price online at parts.conicellitoyotaofconshohocken.com. I plan on adding fog lamps later on and I only want to take off my steering wheel cover and airbag once so I am also ordering the headlamp switch which is: 84140-47161. Let me know how it goes for you. I’m planning on watching youtube to get my bearings on the install before attempting. |
#15 | |
Dear. If you have diagram connection ccs for manual transmit yaris 2016-2017. Share p
#16 |
![]() ![]() Drives: 2012 Toyota Yaris 1.3 -3rd Gen Join Date: Aug 2017
Hi all, I too would like to add cruise control to my 2012 1.33 six speed manual French built yaris.
What are the exact toyota part numbers that I will need, and when purchasing the stalk and cover, does it come with the small wiring loom for connecting it. And would anyone be able to tell me if I need the clutch switch for my car. Also would anyone have a video of them installing it or a link to one? Thanks. Sent from my SM-N910F using Tapatalk |
#17 |
Got it figured out, and now it’s alive!!!!!!!!!! I had to swap a wire that was just a plug with a ground with a different wire that included the ground and connection to the cruise control unit. A special thanks to DarkShadowFox for hyperlinking that video of the Rostra install. It gave me the idea to pursue the correct wire from Toyota. Thanks for the help.
Part numbers to install on US Spec 2016 Yaris L are as follows: Cruise Control Switch (84632-08021) Clutch Switch; for cars with manual trans. (8820-42010) Steering Wheel Switch Cover (45186-0D150-C0) Cruise Switch Wire (84633-02020) Cruise Control Switch Screws; need 2 of these. (90159-50199) |
#18 | |
| Tags |
| cruise control. 2012 |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
