#1 | |
You have everything installed in the proper place, but according to the wiring diagrams the 1ND-TV Yaris does not support cruise control. Check the connector on the other end of the spiral cable, which is located under the cover for the lower part of the steering column. The question is if the two wires are present there that would connect to the cruise control stalk wires under the airbag.
![]() ![]() Drives: Yaris MY2012 - 1ND-TV Join Date: Jun 2013
I understand the need to loosen the screw from the one in picture 1 and picture 2, but do not know exactly what wires need to see, you have a picture of what should I see there?
#3 | |
#4 | |
This is my car connector, (1ND-TV), has beige and brown is, but cruise control does not work. :-) |
Is it worth trying to move to Terminal 1 and 2 of the 4-pin connector at position 1 and 2 of the 10-pin connector? or is in vain? still will not go anything? The blue wire is the ground wire and do not know where to put it if put in place the terminal 1 of the 4-pin plug.
#6 | |
Connector 1? or two, or three ...... ? I think the connector one you mean but I want to call you. Right?
You do not have the wiring diagram for 1.4 d4d? Although I know that the same engine Auris 1.4 D4D has cruise control, I hope someone will hear us and we may find a solution in the future, I just have to have patience.
It is connector 1 that we need to look at. I do have the D4D wiring diagrams, where the "engine control" one does not show cruise control, whereby the wiring diagrams for the 1.33L gas engine does. I don't have the wiring diagrams for the Auris, but I do see in the parts catalog that it uses a different ECM.
Thanks a lot for your help CTScott.
Drives: 2012 Yaris Join Date: Aug 2013
CTScott,
I am new to this forum. My daughter in Indiana just purchased a 2012 Yaris Sedan without cruise control. I noticed from the pictures she sent, that the cluster is mounted in the center of the dash vs behing the steering wheel as I am seeing in the pictures in this thread. I am guessing that Toyota did a mid-year refresh of the vehicle in 2012 and that she has the older version. I have two questions... 1) Can I add OEM cruise to her car using your instructions? 2) If so, which directions do I use. The ones for 2009-2011 or the ones for 2012? I have added OEM cruise to another daughters 2010 Cobalt. This looks much easier than that. Thanks, Fred |
#12 | |
Hi Fred, Sedans did not get an update in 2012 as liftbacks did, so for your daughter's car the my 2009-2011 directions are the ones you will follow.
#13 | |
![]() Drives: MR2 GT Turbo Join Date: Oct 2012
Nic MR2 GT Turbo Supra GT35R 6spd. |
#14 |
The pin that goes into the spring clips has a groove in it that the spring clip latches onto, so you are trying to open the legs on the clip to release it from the groove.
#15 |
![]() Drives: 13 yaris Join Date: Oct 2013
How do you do, it is called takumu. It has ridden on Japanese use of 12 models. There is no cruise control in vitz of Japanese use, and I am troubled by it. It did not operate, even if it post-installed the cruise control switch. If it investigates, there is no wiring of a spiral cable to the point. Who has a wiring diagram of the cruise control of yaris of 12 models? Or please let me know wiring to a computer. Thank you for your consideration.
#16 | |
On the ones that do have it, Pin 60 of ECM connector A72 is where one wire of the stalk connects to and the other wire connects to chassis ground.
#17 |
Mr. CTScott, thank you. My car is 1 KR-FE engine. Somehow, the form of the connector of A70 was different. It was connector-shaped [ of the same engine computer as yaris(es) from 2006 to 2011 ]. The wiring which is already different is stuck in the wiring place of the cruise control of 2011 models. It was troubled.
#18 |
hi CTScott,
Are you still selling anymore of your kits? I've brought a rostra kit from amazon and the instructions are confusing. I've followed everything up to the ECM part of the instruction. I have a 2012 Yaris 5D LE. How do i determine whether my car has "CLUTCH ECM HARNESS" or not? Where the heck is the "ENGINE COMPARTMENT ON THE PASSENGER SIDE FIREWALL" Any help would be greatly appreciated |
| Tags |
| cruise control. 2012 |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
