der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
After you clean the haze I would recommend getting them sprayed with an automotive clear that has UV protection. This will prevent them from getting hazed again
Joe (right?)!? When did you get an A4? Still got the Rav4?
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
OK, back on topic, I've got two questions...
1) Is there any eBay seller recommended/to be avoided? I'd prefer someone in the States, just in case there are any issues. 2) Are these "plug-and-play" in the sense that I can simply remove my old lights and install these new ones? I'm leaning towards these... Cheers! M2
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
They are literally plug and play as far as the main bulbs are concerned. The peripheral LEDs are definitely not plug and play and require some splicing.
Id take them to a shop just to be safe
My yaris build! http://www.yarisworld.com/forums/showthread.php?t=36908 Please feel free to leave your oppinions! I would love to have them to see what I can improve on! |
![]() Drives: Yaris HB 07 Join Date: Jul 2009
Hey, i have the same lights:
But i have had a problem when i was installing. I have seen that when i change to high beams the low ones turn off, i would like to know what i should do in order to keep both low and high beams on at the same time, that means, to keep the low beams on when change to high beams. I want to install 4300K HID in the low beams and i don't expect that they turn off when i change to high beams: for HID time response reason and the high beams are not so good in this projectors. anyone have idea how can i fix that issue? |
Well it really depends on your HID kit, if you have them installed in projector housing headlights like those you need an H4 kit which have a separate high and low beam. In an HID set-up they specifically don't have the high and low come on at the same time for one reason, so you don't burn peoples eyes out! Trust me I had HIDs in my last yaris and the low beams is all you need. Plus in an H4 set-up the high beam will not be the HID color it'll almost look like a stock bulb so you really want them both on anyway. Hope this helped!
The Beautification of Car
i had bad problems with anything aftermarket headlights or taillight on ebay
anyone know that most of headlight and taillights on ebay are known for leaking problems?
The Beautification Of Car Enthusiast |
#9 | ||
I would never buy from eBay most of the time it's just people that buy large quantities of those parts from legitimate web sites or manufactures and then sell them cheaper. The thing is you can't be sure what kind of handling they've been through and if they've been stored properly. I've bought aftermarket parts for my last yaris but I always bought straight from the website. They're always in better condition and more times then not they either have warranties or return policies. Something you'll unlikely find on eBay
#11 | |
![]() Secondly, I think if you buy from an established vendor on eBay (easily determined by the number of sales they've had), the risks involved diminish significantly. It's the same as buying from a forum from someone with a lot of posts, they are usually less likely to be a scam. Dotcomracing has almost 74000 transactions with a 98.8% Positive feedback rating. They've also been an eBay vendor since July 2000, so 11+ years is pretty established in my book. They also offer a offer a 30 day money back guarantee and have a customer service section to address any problems that may arise. I think it's safe to deal with them... Still, I am looking for firsthand experiences with these projector headlights on eBay. I am very close to pulling the trigger on a set, they are having a 5% off sale for the weekend and that may be enough to get me to give them a try... Cheers! M2
Not quite a noob
I could'v sworn I've already put my input forward but they are of decent to good quality. Mine haven't leaked- the halos are dim so I don't use them. The Cutoff is annoying, but at least you don't blind oncoming traffic. I dunno what more you can want in terms of opinion. ;)
Also, make sure you get a set with reflectors on the side if they're required in your state/province. They don't work very well, but it looks like you have reflectorss which won't be as noticeable as having nothin at all. |
#13 | ||
And I was just researching the side reflector issue, as I was going to get a set with clear ones but found that Texas law requires amber ones... Quote:
Cheers! M2
#14 |
I guess I could've stated my point of view a little better. You are completely correct, there are good reliable vendors on eBay, but then again dotcomracing is an actual company itself that just took its business to ebay. My main point was that people who don't do their research on eBay like you do don't know if they're buying from a legitimate website like dotcomracing which is in fact an actual company itself and not some third party vendor like I described earlier, and more often then not those people who don't take their time to do the research get screwed. Trust me I had first hand experience with that. I went through two pairs of halos for my grand prix when I had it. Cuase I bought from the same guy twice one pair already had a crack in the lense when I got it then the second time around as soon as I was bolting one of them down the whole back of the light snapped in half and rendered those useless as well. But I think in correlation with both of our ideas we can both better people's bad eBay buying habits! Lol
#15 |
Not quite a noob
And it realyl doesn't look bad. In fact I'm so used to an amber reflector (or yellow) on cars in the headlights that I think cars without them look ugly.
#16 |
Yeah, it barely makes any difference in terms of looks...
...but since they're required by law, I'll get these. Honestly, when I had to replace the amber corner reflectors on my old car (a VR6 Passat GLX) with clear ones, I didn't like them as much as the originals. Cheers! M2
#17 |
Not quite a noob
Those actually look way better than mine. Mine are the same shape/size as the OEM ones.
#18 |
Well, I pulled the trigger and got a set just like those in my last post. I think they'll look good, I'm waiting on a new grill from MicroImage and I need to put some replacement fog lights in; so I'll probably wait until I have everything and do it all in one major surgery...
Pics to follow... Cheers! M2
| eBay Issue - Your help needed | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 02-04-2011 09:18 PM |
| Cheap eBay LED Strip vs V-LED Strip | Kaotic Lazagna | Cosmetic Modifications (Exterior/Interior) | 1 | 03-18-2010 08:06 PM |
| Pre Hack Revival: Megan Racing Header vs Ebay Header | Sabretooth | Performance Modifications | 15 | 08-19-2009 05:26 PM |
| ebay intake: would you? | thebarber | Performance Modifications | 7 | 12-03-2008 12:44 AM |
