Old 02-06-2013, 02:28 AM   #1
Driftw00d
Clueless
Drives: 2008 Toyota Yaris "Bayou Blue"
Does it come off easy if you want to take off the bolts underneath there?
Driftw00d is offline   Reply With Quote
Old 02-06-2013, 06:58 AM   #2
It really doesn't come off, but bolts break loose without a problem.
Old 02-07-2013, 10:23 PM   #3
enviri
enviri's Avatar
Drives: 2010 Yaris
i dont even want to think about what's under my car...even with the virgin rear disc brake beam...
Old 02-19-2013, 03:03 PM   #4
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
How well this structure keeps on metal?
Whether will be with corrosion time under it?
I like very much travel
MickZEL is offline   Reply With Quote
Old 02-19-2013, 03:06 PM   #5
It bonds very well to the painted metal. It is made for coating the bed of a truck to protect the paint and prevent corrosion from abrasion.
Old 02-19-2013, 03:27 PM   #6
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
The body should be washed from a dust before drawing?
Old 02-19-2013, 04:07 PM   #7
Yes. Washed very well to remove any dirt, salt and oils and dried completely before applying.
Old 04-18-2013, 03:35 PM   #8
yougojay
25, 550 MILES!
Drives: Yaris L Coupe
THANK You
This is a great idea - I thought about getting some kind of undercoating to do the rear wheel wells as part of them were missed (bare metal) from the factory.
Autozone has a smaller 2.5 pound can of the same stuff for $29.99, in case folks want a smaller can to do just the wheel wells. Will give it a go one day and try a 2'' or 3'' throw-away brush. - Again, this is a great idea, thanks Scott
File Type: jpg 2.5 LB Can Of Herculiner From Autozone 29.99 A Can.jpg (127.3 KB, 93 views)
yougojay is offline   Reply With Quote
Old 04-18-2013, 04:37 PM   #9
The little can is probably enough to do a couple of coats on the wheel wells and a full single coat of the bottom. Just make sure you either apply it outside or wear a respirator. The fumes during application are nasty and dangerous.
Old 04-21-2013, 09:40 AM   #10
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
I did this using roof asphalt coating paint. I only painted the half of the wheel wells that is on the passenger cabin side (the car was undercoated from the dealer).
I also attached patches of rubber insulation foam before coating.
It doesn't reduce the road noise that much, but it does noticeably shift the noise's frequency lower.
I also have done soundproofing using weatherstrip rubber on the B-pillars, and rubber insulation foam in the cavities in front of the doors, and underside of the doors.
The noise became less irritating and I can have a conversation in car clearly up to 80 MPH -- where wind noise is starting to have more effect.
Mittelklasse is offline   Reply With Quote
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
Sound dampening rear hatch area? m911gt DIY / Maintenance / Service 28 10-10-2013 03:39 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
Just ordered some sound dampening stuff Brad D General Yaris / Vitz Discussion 8 06-10-2009 08:09 PM
Any non-Dynamat sound dampening? vodkalush In Car Entertainment + Electronics (audio / video / alarm) 12 11-18-2006 02:32 AM
