![]() Drives: Yaris 2 Join Date: Sep 2010
you realize this is A COMPACT VEHICLE not a rig, learn to drive that way you wont need a nanny
![]() ![]() Drives: 2012 Yaris XR 3DR Join Date: Feb 2012
![]() ![]() Drives: Gen3 Yaris ZR Manual Join Date: Jan 2012
That's not the point. It's designed to have the functionality. ^_^
It's a 6 pin connector with only three wires, brown, blue and black, but they run to pins 10,11 and 12 on the larger connector next to it (OK1 or OP1), whereas the camera wires are supposed to be on 14,15,16, and 17. There aren't any wires in those positions. I have one of these cameras which will fit with a bit of encouragement. Running a video lead to the head unit won't be overly difficult, but I still would have liked the cables to have already been fitted from factory.
#5 | |
) on the monitor.
Yeah, it won't be flush with the flat face of the plastic insert, but instead angled up and then epoxied in place.
Gotta remove the head unit and test that it'll work first, though. I hope there's no tricks to this other than hooking up the video signal and being in reverse. :)
#8 | |
ALWAYS best to check for yourself though. Can't believe everything you read on the internets and we are dealing with different region specs\builts here. Please report back, if you (or anyone else) do get this working. This will pretty much determine if I go ahead with my project or not. I'm not too comfortable with wiring and I certainly don't want to blow anything up or mess with the warranty in any way.. I retrofitted PDC on one of my previous cars and was on the brink of heart failure the whole time... |
@SineWave
Have you installed the camera you mentioned earlier in the thread yet? You don't by any chance have the measurements of what the OEM camera (or the insert that currently fills the gap) should be? I want to figure out if this Crown one will fit. I'm still keen on doing this. |
I removed my head unit last night, and the connector that is supposed to have the camera signal only has one wire going into it. See the attached image, it's pin 6, park brake sense. This wasn't plugged into the back of the unit, which explains why my system functionality test never showed park brake being on. I tried placing bare wires down the back of the connector, but couldn't get the screen to change to video mode. Video signal went in pin 8, +V went in pin 7 (will check if there is any voltage there or not today) and GND went in pin 16. Video - is supposed to be on pin 15, don't know if I need to short this to GND/pin 16. Will check for continuity.
Does anyone know where to get the pin sockets to populate this connector? |
Ouch, and here it thought this would be an easy retrofit...
Perhaps I'll muster up the courage some time this week to take my head unit (mine is different to yours) out and have a look. |
The pins actually look like the IDC headers on the backs of IDE hard drives and CD drives. I have a whole bunch of single pin socket leads like these:
![]() Will try again soon. |
Drives: Yaris 3rd Generation Join Date: May 2012
Hi,
Could you please tell us if you installed the oem camera succefully ? Thanks a lot for feedback Regards |
-YaRiS OwNeR-
Drives: YRS Sedan Join Date: Oct 2008
Hi guys, just wondering if someone had installed a rear camera for Yaris Sedan? Did some research in ebay and still not sure what model of camera that fits in Yaris Sedan.
Hi Every body, I have read your comments, and i want to setup a reverse cam in my car, i just want to add this feature!
![]() Drives: Yaris 2012 Luna 1.0 L Join Date: Mar 2011
Up!
Is any one who made this work? I have one conector but orginal camera has diferent plug... |
#17 | |
The wires on the connector are red (power), white (video ground), black (video output), and brown (power ground).
![]() ![]() ![]() Drives: 2010 Toyota Yaris Join Date: Nov 2012
The only camera connections I've seen are an RCA female from the camera and a power wire. You connect the power wire to the reverse lights in the back of the car.
You run a supplied cable to the front of the inside of the car. Either buy a review mirror monitor or a dash mount. Each take 12 volts. |
| Temp guage and compass in Rear view mirror | Chaad32 | Cosmetic Modifications (Exterior/Interior) | 10 | 10-30-2020 07:47 PM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 12:57 PM |
