Old 02-12-2012, 09:11 AM   #1
Originally Posted by scene View Post
since the yaris is front wheel drive how come the brakes in the rear are more worn down than the front? Are the rear brakes less thick than the front?
They are not more worn down. The rear shoes do indeed start out thinner than the front pads.
Old 02-11-2012, 08:57 PM   #2
swidd
Drives: Yaris HB
The rear star wheel adjusters may stop working after a while, leaving the rear brake shoes too wide a gap to brake first and strong. So they wear less than the front brakes.
I'm at 97k and haven't *needed* to change the pads/shoes, but keep adjusting the rear star wheel adjuster to keep it tight.
Manual.
Old 02-12-2012, 12:55 AM   #3
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
Auto or not 16k is way too short of a life. But if several people say it's the case it makes you think. Easy enough to take the wheel off and measure the pad thickness though.
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
Old 02-12-2012, 09:47 AM   #4
41magmag41
Drives: Loaded 2007 mica silver sedan
Before I totaled my 2007 yaris sedan 2 months ago I had 140000 miles on the car and still had 60 percent of my ORGINAL brakes on the car. This was verfied by my dealer at my yearly inspection that month. Unless you have a caliper sticking or some other mechanical problem you shouldn't need brakes.
41magmag41 is offline   Reply With Quote
Old 02-12-2012, 07:53 PM   #5
yaris2010RS
yaris2010RS's Avatar
the rear pad starts off alot thinner then the front
Old 02-12-2012, 10:03 PM   #6
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Unles you have a mechanical problem like a sticky caliper or you two foot drive with your foot on the brake pedal there just could not be any way they are bad at 16000.
took mine off auto HB at 40000 and they are still like new,both the pads and the rotors.
Get another opinion at another place,but do not tell them there is anything wrong or that you were told they needed replaced,just let them take a look and have them show you the brakes as well as the measurements on them and the specs for needing replaced.
general service of brakes TriumphAnt DIY / Maintenance / Service 10 08-07-2010 02:20 PM
Rear Drum brakes bankrobber DIY / Maintenance / Service 0 04-17-2010 11:39 PM
Metal scratching from brakes alt_k1ll3r DIY / Maintenance / Service 16 02-11-2010 12:04 AM
