Old 04-28-2012, 01:33 PM   #1
09sedan
Drives: 2009 yaris sedan
Big 3 question
Do i have to put a inline fuse for the 0 gauge run from the alternator to the battery? ( if so how big should it be?)
09sedan is offline   Reply With Quote
Old 04-28-2012, 04:41 PM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Plan the fuse holder in a smart area. The argument is that you have a hot wire coming off the positive of the battery...which is true. If it grounds you'd want to fuse the hot wire.
That being said, think about it...Why are you going to put a fuse on it? In case the wire comes out or you get into a wreck. The first necessitates a smack to the back of the head if you can't secure a wire in the vehicle correctly. The second necessitates a big scratch of the head.
Why? Because if you indeed crunch up the engine compartment that fuse better be VERY close to the battery positive to really work as it is intended. Don't leave much if any wire lead before the fuse off the positive for it to potentially catch on metal.
"There are 2 connections which must be intact or upgraded when adding any components that draw significant amounts of current. The first is the short ground wire which connects the negative battery terminal to the vehicle's chassis. The other connection is the braided ground strap that connects the engine block to the chassis." -BCAE1
"Realize that the "absolute ground" of the electrical system is not the battery negative terminal or the vehicle chassis, but is the case of the alternator itself. This is why perhaps the most important cable among the Big 3 is the engine ground strap, as this is what connects the alternator ground to the vehicle's chassis." - the12Volt.com
― Thomas Paine
Old 04-28-2012, 08:19 PM   #3
09sedan
so fuse alternator to battery positive wire as close as possible to battery, got it.
how big should the fuse be? (120-150 amps?)
as for the engine block to chassis ground strap, do i replace it, or run the 0 gauge ground right beside it ?( ie just remove nut from bolt and slide on the new wire right beside the factory one)
Old 04-28-2012, 09:25 PM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Never replace the OEM run. Just add.
Why don't I have mine fused? Because I'm a disagreeable cus who has actually tied the wire more securely after these pics were taken. If the wreck I get into is big enough to dislodge the tie and the connection from the battery, I've got much bigger issues than a fuse which would most likely be disintegrated anyway.
― Thomas Paine
Old 04-28-2012, 09:55 PM   #5
09sedan
ok, well if i can run it , ill just secure the power wire along the firewall somewhere, away from the front of the car, as for the engine block to chassis ground, where is it located ,any pics? i will be ordering the wire from knukonceptz either tonight or tommorow, along with ring terminals.. i dont think i need to replace the battery terminals?
Old 04-29-2012, 12:23 AM   #6
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Okay if you decide to use a fuse you want it about 6-8 inches from your battery anything outside of that is useless. If you got into a wreck and your engine compartment was compromised you'd want your fuse to be as close to your battery as possible. If you're going to put that fuse further it's useless due to the fact if the wire grounds anywhere outside of the circled area it will cause a short and a fire.
Sq can you please show the picture of how you grounded your alternator ?
Old 04-29-2012, 12:53 AM   #7
09sedan
cool , thanks for the info, i think i will fuse the power wire, better safe then sorry, what amp rating should i use, my current amplifier has one 30 amp fuse, the 4 channel i plan on putting in has two 30 amp fuses, so all 3 shouldnt draw more then 90 amps at peak, i was thinking a 100 amp fuse on the power wire should be enough?
Old 04-29-2012, 01:21 AM   #8
_S7V7N_
_S7V7N_'s Avatar
You are going to have a 90 amp fuse on your alt to battery run and some people fuse the wire for the amperage it can support and run a fused distro block in the trunk or do it the way you're saying with a 90 amp fuse.
Old 04-29-2012, 01:45 AM   #9
09sedan
Ok, ill check my current 4 gauge tommorow and see what brand it is and what kind of fuse it has, ill probably just do a 100 amp fuse on alt-battery wire and put a distro block in the trunk. Hopefully ill be ordering my 0 gauge on sunday as well, i can use ring terminals(crimp type, but i will solder as well) on the stock battery terminals correct?
Old 04-29-2012, 01:46 AM   #10
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
SQ!! Where did you bought the red thing around you cable ?:D
Interior:ALL red, black roof
Old 04-29-2012, 11:31 AM   #11
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Tolm,
Why the fuse placement on the other side of the engine bay?
@packetrace - you mean the heat shrink? :)
Alty ground:
^and yes, it is grounded properly. I used a brush attachment on a drill to scrape the paint away from the body.
― Thomas Paine
Old 04-29-2012, 11:38 AM   #12
_S7V7N_
_S7V7N_'s Avatar
Lol @ Sq I thought his battery was on the opposite side of his car ! That thing is like 4 feet from the battery. I thought at the most 12 inches from the battery for any fuse is the max ?
Old 04-29-2012, 12:07 PM   #13
09sedan
Tolm,
Alty ground:
would this suffice as a engine - chassis ground?
Old 04-29-2012, 12:37 PM   #14
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Tolm,
I just didn't see a fuse near the battery, that's why I asked.
@ 09 - that point would not serve as a good engine to chassis since it's not actually a connection ON the engine block. Take a look under the engine...hint hint.
― Thomas Paine
Old 04-29-2012, 02:18 PM   #15
_S7V7N_
_S7V7N_'s Avatar
Tolm that fuse is too far from the battery. If that wire were ever to come out of that holder it would be flopping around and has the potential to ground off and cause a short. If you look at the two red lines l Right of circle l you have about 3 feet of wire that can get punctured that the fuse will not protect.
Pretty much all of the wire to the right of the circled area is not protected (fused)
Old 04-29-2012, 02:40 PM   #16
09sedan
ok after inspecting the current amp kit i have, i decided to scratch a part of the exposed strands to see if its pure copper or CCA, it seems to me that it looks like CCA, here is the amp kit i believe i have
http://www.sonicelectronix.com/item_...y-Scosche.html
Old 04-29-2012, 02:54 PM   #17
sqcomp
Roadrunner Jr.
sqcomp's Avatar
You'll be fine with the CCA. You've already purchased it and it will work.
What I did for my big 3 was to go to the owner of the shop and ask if I could root through his scrap wire bin. I found some good stuff in there. With all the wire, techflex, terminals and heat shrink...it only cost me $13 to make it all myself.
On the thought of the fusing, one could make a point to say you'd need TWO fuses. One after the alty positive and one at the battery positive. At some point that wire is going to be live. This is another reason why I simply secured my wire along the OEM routing. If it wants to come undone...it'll be in a serious, if not fatal, wreck. At that point I have other things I need to worry about as any fusing will have been completely obliterated.
― Thomas Paine
Old 04-29-2012, 03:01 PM   #18
09sedan
that amp kit i have contains a 50 amp fuse, im a bit sketchy as to why it only has a 50 amp fuse if its rated for "1000 watts" , with my 4 channel im looking at 90 amps ( 30A from mono amp, 60A from 4chan amp), i can easily swap out the 50 amp fuse for a 100 amp?, instead of running 0 gauge, can i run 4 gauge? (knukonceptz). ( smaller and easier to route behind the engine), if thats the case then all i need is a few more feet of 4 gauge and a distribution bock in the trunk..)
the engine heat doesnt affect the exterior coating?
edit: was doing some research for the past few hours ,reading up on gauge sizes and amperage capabilities.
http://www.bcae1.com/wire.htm
from what i understand i can easily swap out the 50amp fuse near my battery and put in a 100 amp ANL fuse, and then run new Knu.K 4 gauge for my big 3, and throw in a fused distribution block with 1 4 gauge in and 2 4 gauge out for my amps( with matching fuse ratings for each amp), im pretty sure i understand this now right? :|
A Hankook RS3 question... stevethegimp Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 04-27-2011 05:16 PM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
Yaris Pricing Question minervamoon New YARIS Purchase Forum 32 06-21-2009 05:26 PM
So how do you like the BIG SMILE on the 07 Sedan???? Ziv General Yaris / Vitz Discussion 3 02-03-2006 11:12 AM
