Old 08-12-2012, 12:00 AM   #1
Billiam
Drives: '10 White Yaris 4D LB
Old school swamp cooler baby!!
http://www.busandcamper.com/shop/vin...-electric.html
If you want to enjoy your car, stay off of the internet.
Old 08-18-2012, 04:36 AM   #2
henrylee
henrylee's Avatar
Drives: 2011 Yaris Sedan Red Power pkg
This thread is awesome!! She's a beauty~
SOLD: 2011 Yaris Sedan ll Barcelona Red ll Auto ll Power Pkg ll Scion 7 spoke Wheels ll Llumar tint ll "S" Body Kit
http://www.yarisworld.com/forums/showthread.php?t=38682
henrylee is offline   Reply With Quote
Old 08-19-2012, 04:50 AM   #3
mr_miles
Drives: 2013 Yaris
kinda late to the punch here - but Scott, could you PM me about the core supports? i cant seem to figure out a few things about them - like if the sedan and HB share the same pieces or not. i can find all 4 pieces for the sedan, but not for the HB.
Old 08-19-2012, 07:47 AM   #4
Funny story on that - I was scrambling to get the parts ordered before vacation and I did a buy it now on an ebay listing for all 4 of the parts for the radiator support structure for $100 (which is about 1/3 the price of buying the 4 from an online Toyota parts retailer). When I got back from vacation and opened the box I noticed that something looked a little different with the new ones. I went ahead an mounted them and everything fit OK. Then, when I went to put the headlight on, I realized that the headlight brackets on the radiator supports were in the wrong place (making the radiator tab of the headlight sit almost 1" too high. I went back to check my ebay purchase and noticed that in the listing it should compatibility with the 06-11 liftback and sedan, but the title of the listing was "2006-2011 Yaris Sedan Radiator Support". Somehow I missed that and didn't check the part numbers versus the EPC.
As it turns out the LB and Sedan share the bottom part. The sides, if purchased complete with the headlight brackets attached, are different, but if you purchase them without the headlight brackets, then they are the same. In that case you buy the headlight brackets separately. So, for that part I cut off the wrong headlight brackets and fabricated my own (since they are a simple L-shaped piece). The top is also different, but the primary difference is two extra support tabs (that have to be removed for the liftback) and two bumper clip holes in the wrong place (which can easily be redrilled for the liftback).
So, the bottom line is they top 3 parts are different, but can be easily made to work to save some serious coin. When I have a chance I will post the correct part numbers for the 4 liftback parts for you, in case you want to save the modification work to make the cheaper Sedan ones work.
Old 08-19-2012, 03:09 PM   #5
mr_miles
Drives: 2013 Yaris
oh dang, I almost hit the "buy now" button one one of those bids. i knew the bottom piece was the same, but wasn't sure about the sides, and was pretty sure the top was different.
That would explain why the drivers side side mount on mine is cut. i bet the guy who fixed it before me did the same thing.
Old 08-19-2012, 10:27 PM   #6
Old 08-20-2012, 03:03 AM   #7
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
May we send our cars to your home for servicing? :)
You sure get work done fast and right!
Old 08-20-2012, 06:55 AM   #8
Sure. Now that I have the A/C equipment, I might as well get my money's worth out of it.
Old 08-20-2012, 05:37 PM   #9
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
Crashy2 - Now 33% Safer, 50% Brighter, and 100% Cooler...
I like the light and shadow of the picture.
Killchain is offline   Reply With Quote
Old 08-20-2012, 11:04 AM   #10
Hershey
Well done . How'd you like to purchase our Barcelona Red sedan and turn it into a El Camino or Ranchero ?
Old 08-20-2012, 11:10 AM   #11
Hershey
Maybe you should open your own shop that specializes in the Yaris on the east coast . Like a walk in clinic for damaged or sick Yarii .
Old 08-26-2012, 11:05 PM   #12
So, after a week with working AC, I decided that she needs the rest of the creature comforts that my 09 has, so this weekend I ordered everything needed to upgrade her to having power mirrors, power windows, power locks with remote entry, and my Scion IQ hatch opening switch mod.
Old 08-26-2012, 11:33 PM   #13
Hershey
CT , what do you look for in the window of the AC line to tell of a possible leak ? Would you loose it all at once or over a period of time if a slow leak . Seems fine for now . Thanks again and very nice work .
Old 08-26-2012, 11:36 PM   #14
Originally Posted by Hershey View Post
Ct , what do look for in the window of the AC line ? What tells of a possible leak . Thanks again . Seems fine for now .
The sight glass is pretty limited. seeing liquid with bubbles running through there says that the system has at least some Freon in it. To really check it you want to check the pressure of the system, which can be done with an AC gauge set or with the Techstream tool.
Old 08-26-2012, 11:40 PM   #15
Hershey
Looks to have a bubble like that of a level . Did notice the plastic prongs that snap in place at the top of the radiator on the passenger side has slight play in it . They're not broke off . Should that be a concern ? Or be o.k.?
Old 08-26-2012, 11:45 PM   #16
That's where the condenser snaps on the radiator. They typically snap on pretty tightly, so I would check to see if the condenser is bent or if it is simply not snapped all the way on.
Old 08-27-2012, 12:17 AM   #17
Hershey
Quite sure it's snapped all the way on . Will look into it .
Old 08-27-2012, 12:33 PM   #18
Hershey
Pics of plastic snap is here , http://www.yarisworld.com/forums/sho...d=1#post663659 . Post #35 .
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
What Car Mechanics Don't Want You to Know!! daddz07 DIY / Maintenance / Service 16 04-17-2011 10:10 PM
