![]() Drives: Yaris TS 05 Join Date: Jun 2011
I'm seeing those piston on that 1nz-fe and I'm drooling. I want to see a dyno sheet
![]() ![]() ![]() Drives: Yaris sedan 10 std... Join Date: Aug 2010
Stock piston 195 to 205 compression prius 245 to 260 compress
![]() Drives: Toyota Yaris 2012 Join Date: Jul 2012
what is this mean?
Stock piston 195 to 205 compression prius 245 to 260 compress ?
#5 | |
With the 1NZ-FXE (with 13:1 compression ratio) engine compression is appanrelty 245-260psi
That's a huge jump
That is pretty high too... pumped to see the dyno results!!
Did the compresion test 240 only one 238 nice numbers everithing running great...
prius engine compression 245-260Psi, Nanoss22 compression 240, so it means the compression ratio is about 12:1 to 12.5:1? wow, if the car use VP racing fuel, i think the power and torque gain will be great. Can't wait for the dyno result.....
I wonder what kind of power just the pistons will make and then if you actually tuned for it (maybe with the aem fic).
if he use high octane number for fuel like VP racing, increasing the compression from 10.5 to 12, with proper tuning for the ecu, he should have about 10 to 15 extra HP on crank.
#12 | |
![]() ![]() Drives: Yaris '06 Join Date: Apr 2011
I would also give the same answer 10 ~ 15 hp as well =) |
![]() Drives: 2009 3rd Polar white Join Date: Apr 2011
Any Dyno numbers yet?
this thread was doing so well.... then splat
I too was hoping for a big nasty dyno graph. something to coax me into doing something foolish with my money.
ehh.. its only been a couple weeks since his last post. Probably either blew his engine and embarassed to talk about it or just simply got busy with something else and doesn't wanna waste time with us =(
patience
or he has a life outside of internet forums...
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| Save thousands and BIG MPG almost PRIUS | jay cobbs | New YARIS Purchase Forum | 6 | 08-28-2012 08:38 PM |
| Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> | jay cobbs | General Yaris / Vitz Discussion | 8 | 06-07-2012 01:44 PM |
| SEDAN LOVE CHILD OF CAMRY& PRIUS | jay cobbs | Fuel Economy Forum | 0 | 05-23-2012 12:42 PM |
| Toyota says don't call them Priuses -- call 'em the Prii | Kal-El | Off-topic / Other Cars / Everything else Discussions | 7 | 02-22-2011 10:30 AM |
