Old 10-31-2013, 08:36 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Visit Monkeywrenchracing.com they have tons of transmission parts. Mostly for the 6 speed but they might have others too.
Old 12-11-2013, 06:26 PM   #2
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
found time to take the transmission out and apart to remove the LSD. This picture shows 3rd gear with no teeth. Going to order some new seals for my original transmission, and transfer the LSD. Going back to the shorter gears since rev limit is 8k now.
File Type: jpg 1476057_10202279275156014_447761288_n.jpg (61.1 KB, 303 views)
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 12-02-2014, 08:47 PM   #3
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
It"s been a while, here are some updates... Springtime I attended a time trial, at that time trial I was sitting in second place ioverall after a few sessions so I decided to run full boost. My motor finally had enough. The piston which was scored a long time ago (cylinder 4) detonated and I melted a piston. I did grab second place though, so that day was still a success lol. I since built another motor and had it running in time for the fall Gripfest ( time trial). I did not get my injectors flow tested in time so I ran low boost, around 260whp but with great success. I edged out the previous winner, and did so in the rain. This was awesome because he was in an STI, so no more excuses that awd is dominant in the rain . I was only beat by our own shop time attack tC ( 2008-2009 mod fwd Redline Time Attack champ), and a Formula Ford. Yes, Gripfest doesn't have classes, it's run what you brung.
I also squeezed in a few autocrosses before the race season ended, with great results. Ive been dominating SMF SCCA class, and almost grabbed FTD overall in a couple events. Im still getting used to the massive grip over 275 width Hossiers up front. Here are a few pictures
Ptuning.com
Old 12-03-2014, 08:59 AM   #4
BoostedTRD
Drives: 09 Yaris Hatchback
Damn Justin that's so sick.
BoostedTRD is offline   Reply With Quote
Old 12-11-2013, 06:30 PM   #5
Bluevitz-rs
Wow! I've never seen that before. Measure the width of the gears in both transmissions. Curious if one has wider gears than the other. I'm pretty sure my C160's gears are wider than the C150 stock gears. I'd have to check my old build thread.
Old 12-13-2013, 07:47 AM   #6
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
widths are the same, in fact, they are the same as the Scion tC as well .
Ptuning.com
Old 12-13-2013, 06:47 PM   #7
Bluevitz-rs
That's crazy you managed to strip the teeth of then. Maybe I'm thinking of a C54 from the celica. I know one of the C series transmissions has wider gears in it.
Old 12-13-2013, 08:38 PM   #8
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I took a picture comparing the yaris output gear shaft (right) to a tC output gear shaft (left) . Ignore the top/4th gear on the tC shaft, it is a prototype gear we are testing and is odviously beefier. Look how similar the gears are. tC transmissions are known to shear 4th gear at / above 400whp.
File Type: jpg 1453331_10202279321037161_1928500566_n.jpg (50.4 KB, 285 views)
Ptuning.com
Old 12-30-2013, 09:05 PM   #9
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
any further updates? I sent you a PM Justin btw if you missed it.
Old 01-21-2014, 04:08 PM   #10
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I PM'd you. Car is back to 100%, improvements being made before this upcoming season... Check out my latest update under wheel and tire threads.
Ptuning.com
Old 01-01-2014, 09:51 PM   #11
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Next week I requested off to get the car back together, Im glad because I just want it up and running again.
Ptuning.com
Old 01-01-2014, 10:37 PM   #12
Bluevitz-rs
So are you just going to put the stock gearbox back in?
Old 01-02-2014, 06:02 PM   #13
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
yes. I contacted Kaaz about their gear set, and there is no guarantee that they will hold the power. That isn't a $2000 gamble Im willing to take. I am doing a cooler setup however.
This year Im focusing more on overall performance and reliability. Just got a new set of wheels in, fitting 275's up front. Then Im doing an oil cooler setup and koyo radiator along with the trans cooler.
Ptuning.com
Old 01-02-2014, 06:44 PM   #14
Bluevitz-rs
Are you going to detune the power a bit for a flatter power band too?
Old 01-21-2014, 04:11 PM   #15
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Im going to run on wastegate pressure (230-250whp) unless Im being edged off the podium in a time trial
Ptuning.com
Old 12-03-2014, 04:34 AM   #16
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Thats fucking awesome... I will be moving to smf also soonish.. You are an amazing tuner/mechanic. good luck next year..
-Derrick-
Old 12-26-2014, 03:51 AM   #17
catliektheif
catliektheif's Avatar
Drives: 2010 5 Door
That pic of you entering the slalom gives me chills lol
lol okay
