Old 11-20-2013, 07:58 AM   #1
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Thanks man. Yea this new lip I ordered will be my first time with something larger and more aggressive. Let's see how it looks lol
Old 11-20-2013, 11:55 AM   #2
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
can't wait! love ur stance man!!!
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 11-20-2013, 01:01 PM   #3
1.5
Form>Function
1.5's Avatar
Thanks man! Same to you!
Old 11-22-2013, 08:55 AM   #4
1.5
Form>Function
1.5's Avatar
Update:
-Lowered the front slightly and I am a few turns away from maxed out now
-Installed 3mm spacers back in the rear
-ordered my front hood bolts so hood spacers should be out this week
-Garm was able to get my front lip ordered so I should have that within a couple weeks
Looking into lowering the rear a little more and going stiffer but I am maxed out on 130mm springs. I am going to try running one collar and removing one but that wont be any stiffer. Removing all collars and the perch means I have a 130mm spring sitting in there alone and that is too low and still will not get me any stiffer.
So in the long run my only true solution is to pickup a new set of rear springs. I can either pickup a spring that is stiif/tall enough that I can run it alone with no collars and perches and it will still be only a few mm lower under load than my current 130mm spring with collars and perches. Or I can pickup an even shorter spring and keep the collars/perches in there. I will still get a stiffer spring but I can keep adjusting height. My only worry with that route is going to such a tiny spring makes me afraid its going to pop out on large bumps.
There is this spring from Swift that is 127mm and 10kg but Im afraid being only 3mm shorter than my current spring and 4kg stiffer, it will actually make me higher than I am now.
Z60-127-100
Z65-127-100
I also found these swift springs but at 102mm tall and 8kg I wonder if these are just going to become projecticles
http://www.frsport.com/Swift-040-250...e_p_61802.html
Old 11-22-2013, 11:42 PM   #5
coheed
Drives: 08 BB LB
Call up Eibach. They should be able to make you springs to height and spring rate you want.
Edit: Here's a link to Eibach saying they will. Don't know what their pricing would be though. http://performance-suspension.eibach.com/motorsport/products/custom_spec_race_springs
Old 11-23-2013, 08:05 AM   #6
1.5
Form>Function
1.5's Avatar
Finding the shorter/stiffer spring isnt my problem. I just dont know if I can run springs any shorter or if i am going to have problems with the spring popping out.
Old 11-23-2013, 04:32 PM   #7
I know it's big time ghetto, but I've seen a few pics on here showing the use of cable ties to 'secure' the springs to the perch.
Old 11-23-2013, 01:58 PM   #8
coheed
Drives: 08 BB LB
I've been running my rears with just the spring, no collar. I've had no issue with it coming out. I've heard it pop in and out of the seat a few times going in steep drives, but it's never come out.
I've been trying to find something about 1.5"-2" shorter though so I can get my adjustability back with the collar.
Old 11-23-2013, 02:02 PM   #9
1.5
Form>Function
1.5's Avatar
Are you on coilovers? What size is your rear spring?
Old 11-23-2013, 02:17 PM   #10
coheed
Drives: 08 BB LB
I'm on Megans. It's the spring that came with them, but I'm wanting an 8k/6k f/r set up cause I have my dampening turned all the way up and it still has to much travel.
Old 11-23-2013, 02:29 PM   #11
1.5
Form>Function
1.5's Avatar
Yea see i already am running a 130/6kg spring the stock megan spring is 190/3kg
Old 11-25-2013, 03:10 PM   #12
1.5
Form>Function
1.5's Avatar
Hey I finally found Yaris sedan S side skirts that come painted. After shipping it comes out to about $770 USD... sounds worth it lol
http://www.japanparts.com/db/parts_d...=58&submit.y=1
Old 11-26-2013, 07:49 AM   #13
1.5
Form>Function
1.5's Avatar
Hood Spacers Gone!!!
Old 11-26-2013, 07:55 AM   #14
1.5
Form>Function
1.5's Avatar
Found a direct model of where im going with the new direction. Ive been shopping around for lip kits and have picked out the pieces i want from various kits. Garm is already ordering my front and ill hopefully pick up the sides and rear soon. Here are some stolen IG shots. Love both of these so much
Old 12-10-2013, 07:18 AM   #15
1.5
Form>Function
1.5's Avatar
Bored last night, my cruise ended with this pic
Name:  2013-12-10 01.59.58.jpg
Old 12-10-2013, 08:38 AM   #16
G-Ammo
G-Ammo's Avatar
I love doing that in the summer man... When I'm bored... I just drive around somewhere I don't know... and then I use the GPS to get back, haha :)
Speedbumps suck...!
Old 12-10-2013, 08:41 AM   #17
1.5
Form>Function
1.5's Avatar
Im lucky to live in FL where it's like 80 mid december. Summer cruises never end here lol
Old 12-10-2013, 11:30 AM   #18
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Lucky bastard,
Here is our weather report for a week:
mon: 40*
tue: 80*
wed: 70*
thur: 50*
fri: 75*
sat: 40*
sun: 50*
Rain is completely random also. Almost impossible to predict..
I hate you and your perfect weather phil
-Derrick-
Build thread! '08 Yaris Hatch nimuntak Photo-Video-Media Gallery 105 01-28-2014 02:28 PM
PETERPOOP's Turbo Build Thread. PETERPOOP Forced Induction Forum 114 02-08-2011 10:21 PM
XBG's Total Build and Update Thread xbgod Performance Modifications 10 11-18-2010 11:19 PM
