![]() Drives: 2007 Yaris Join Date: Jan 2016
Check the trunk and around the taillights, that's where water was entering my yaris.
Sent from my iPhone using Tapatalk |
Also, if anyone could offer up or send me in the right direction to replace or clean these matts.
![]() Sent from my iPhone using Tapatalk |
![]() Drives: 2008 Yaris Hatchback Join Date: Sep 2015
I am currently dealing with multiple leaks on my 2008 2 door hatchback.
Today the lights come off and we shall see if that is the culprit. Ive already fixed one significant leak on the left side just above the windshield. |
2ZR swap. DO IT! Ask how!
I was under my 09 HB the other day and noticed that my rear passenger plug was missing. Here's a list of the plugs used on our car and a diagram for where they go.
Drives: Toyota Verso-S (bigger yaris) Join Date: Sep 2021
Hi,
I'm struggling to find where the water gets in to my 2006 yaris. I pulled out both of my taillights and put new seals under them. But still the water somehow gets in. I went to the car wash, washed my car and quickly got back to my garage and striped the rear panels and found that the water is coming somewhere from the upper part of the car (marked on the picture). Any ideas? |
3 Yaris and counting..
Ongoing issue. Mine leaks too. I've removed the interior panels permanently in my car. What I did to keep the rear carpets dry was to lay a berm of silicone toward the front of your red markings in the pic. The water drips down, hits the berm and has no choice to go into the spare tire well. I then put a hole in the rubber plug at the bottom of the well allowing the water to drain. Not a solution to the leak but it will keep your carpets dry and free of mould.
| DIY - Sparco Race Seat Install | Idjiit | DIY / Maintenance / Service | 16 | 08-14-2017 09:15 PM |
| Drivers Side Seat Belt Won't Retract | redyaris | DIY / Maintenance / Service | 8 | 08-07-2014 10:37 AM |
| WTB: Drivers Side Headlight LiftBack | Saggio | Willing to Buy by private party | 7 | 03-10-2009 02:21 PM |
| Drivers Side Wiper Blade???? | 07YarisOwner | DIY / Maintenance / Service | 6 | 05-11-2007 07:10 PM |
| Back seat folding | Chaad32 | General Yaris / Vitz Discussion | 7 | 07-17-2006 01:44 PM |
