Old 04-08-2014, 07:34 PM   #1
Jason@SportsCar
Originally Posted by xnamerxx View Post
Well I'll be at the Majors event in a couple of weeks, just have to beg them to add a CRB data box to the car.
Just a heads up add more weight and run less gas. I was weighed at my last race and just barely made weight even though I put several more gallons of gas in than I typically would have needed. SCCA scales aren't always accurate and nothing would suck more than to get DSQ'ed for being 5 lbs underweight.
edit:
Butch is going to work with me this weekend so I can learn the procedure they use. He is going to get me the equipment so we can pull data at BW.
Old 04-25-2014, 01:18 AM   #2
About the only "off the shelf" pad is a carbotech - typically they don't stock them, but can make them in a few days.
I typically do stock them, in three or four flavors.
Old 05-09-2014, 04:15 PM   #3
Jason@SportsCar
When the Yaris got its TRD shock and spring package it was rewarded by the CRB with 100lbs of weight. Now the Nissan Versa has picked up an equivalent kit, but only gained 60lbs.
Old 05-09-2014, 05:11 PM   #4
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Wow gearing on that car doesn't look that bad if the suspension kit isn't TRDish it might actually do well.
Old 05-09-2014, 06:17 PM   #5
Jason@SportsCar
I submitted my letter to the CRB asking them to look at the data recorded at the Buttonwillow US Majors, and to reduce the weight of the Yaris back to its 2400lb listing.
I also pointed out the inconsistency in their adjustments for kits, as the Yaris got 4% more weight, and the Nissan only got 2.4%.
Old 05-18-2014, 06:53 PM   #6
Larry@CFR
Drives: Wishing for '12 B-Spec Yaris
Cool
Jason, just checked the next few Majors entry lists for B-Spec. Mid-Ohio has SEVEN B-specs, including a 2014 Nissan Versa Note for David Daughtery. So the preliminary approval says June1 and the package is TBD?
Larry@CFR is offline   Reply With Quote
Old 05-19-2014, 12:50 PM   #7
Jason@SportsCar
Awesome. He made a great showing with a Z after coming out of retirement for the 50th Runoffs. No doubt if he is in a BS car it will be fast.
Old 05-20-2014, 08:03 PM   #8
Jason@SportsCar
Looks like David is back, running a two car effort this year.
Old 05-05-2014, 08:11 PM   #9
FHT_Racing
Drives: 2009 Toyota Yaris 3-Door
3rd Place at the SCCA Circuit de Mayo race this weekend :)
FHT_Racing is offline   Reply With Quote
Old 05-07-2014, 07:10 PM   #10
xnamerxx
0-60 in slow
xnamerxx's Avatar
Congrats on the 3rd place finish.
Out of curiosity what tires are you running? Your car also looks like it sits lower than mine did you modify the BS suspension?
Old 05-07-2014, 07:13 PM   #11
Jason@SportsCar
Video or it didn't happen.
Old 05-10-2014, 08:41 PM   #12
FHT_Racing
My car does seem to sit lower than other kits. Any info Jason? Lol
If the car weighed 2400 and used the rear sway bar as well, it would be killer!
Old 05-12-2014, 06:56 PM   #13
Jason@SportsCar
I thought your car looked a little low. It is possible that due to the very early production of those springs, and what they were used for, that they could have been modified or are not the same as the TRD springs we see today.
The shocks are easy, those part numbers match up with the current stuff. But those springs are a different color, matching the old catalog images and not what we see today. Might be worth updating at some point. Maybe you can find someone with the current springs that would swap for something lower.
Old 05-22-2014, 08:21 PM   #14
FHT_Racing
AWESOME!
I feel the stock spring felt better than these early TRD springs. We'll see how it goes at Texas World Speedway this Sunday! But yes, I do plan on buying the newest TRD springs soon.
Is anyone correcting their rear toe alignment? Here is what my current alignment settings are with factory Toyota camber bolts...
-1.6* Camber
+5.4* Caster
-1.2mm Toe-Out
-0.8* Camber
+3mm Toe-In
Thanks,
Andrew
Old 05-22-2014, 08:32 PM   #15
Jason@SportsCar
-1.6* Camber
+5.4* Caster
-1.2mm Toe-Out
-0.8* Camber
+3mm Toe-In
Thanks,
Andrew
I did my rear toe. Just cut a set of simple shims and put them under the front of the hub.
Old 05-22-2014, 08:52 PM   #16
xnamerxx
0-60 in slow
xnamerxx's Avatar
Yeah I picked up some .5mm ss shims from mcmaster. On the street car I'm very close to 0 with it being slightly toe-in
http://www.mcmaster.com/#90214a428/=s2zddt
Old 05-25-2014, 07:26 AM   #17
FHT_Racing
The shims don't need to be angled?
Old 05-25-2014, 02:42 PM   #18
xnamerxx
0-60 in slow
xnamerxx's Avatar
They probably should be but sometimes you work with what you got. Haven't seen any issues on the street car.
2011 NYR SCCA AutoX Schedule NYR Solo Tracking, Racing, Auto-X Forum 0 04-06-2011 01:57 AM
2011 NYR SCCA AutoX Schedule NYR Solo NY / NJ/ CT / PA 0 04-06-2011 01:56 AM
7/12/09 SCCA Hawaii Region results anonymous user Tracking, Racing, Auto-X Forum 7 07-27-2009 02:13 PM
