Old 04-30-2013, 06:37 PM   #1
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
Ask and you shall receive :)
yariSB86 is offline   Reply With Quote
Old 05-01-2013, 04:50 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Wow...I really forgot how much it looks wide open front top to down on the backside when you are running an internal WG. I would get the heat wrap ASAP. Makes a big difference both performance and safety wise.
Old 04-30-2013, 06:44 PM   #3
TOLMACH
Drives: soarer
Pls, do not be shy, post more pics )) Any pics of the tepped block from the below?
Do you plan heat wrapping anything?
The oxigen sensor (stock?) wire seems kinda "stressed".. You mught think extending it and running it in a less stressed way.
The top metallic hose at the turbo is the oil return, I guess?
Old 04-30-2013, 06:55 PM   #4
yariSB86
yariSB86's Avatar
I do plan on heat wrapping, there is a DEI just up the street.
The stock O2 sensor wire isnt stressed at all, infact i have it hanging with a zip tie to keep it off the exhaust manifold.
That steel braided hose is the oil in line. It is coming from my oil filter sandwich adapter.
Old 04-30-2013, 07:05 PM   #5
yariSB86
yariSB86's Avatar
would this work in a 2.25" custom pipe?
http://www.mandrelbendingsolutions.c...High%2C/Detail
Old 04-30-2013, 09:59 PM   #6
yariSB86
yariSB86's Avatar
Whats this knob on the end of the BOV for? What is its function? I can screw it/unscrew it.
Edit: so that's the actuator control housing knob?
Old 05-01-2013, 07:09 PM   #7
yariSB86
yariSB86's Avatar
Yeahs, thanks man. I'm picking some up Friday.
Think I got car to run pretty good. Still having issues with it stalling after lifting off throttle after a load. It's like when I lift off the rpms should go to 950-1100 like they do at idle but they keep falling until stall. My buddy was thinking adjusting the throttle position or changing the VE table. Any suggestions?
Old 05-02-2013, 11:15 AM   #8
kou
Drives: 08 lb
^^ my suggestion is you check that blow off valve and make sure its closing.
Old 05-02-2013, 11:26 AM   #9
yariSB86
yariSB86's Avatar
@kou - am i correct in thinking that if the BOV needs to be adjusted, it is done by removing that screw cap on the end?
Old 05-02-2013, 11:28 AM   #10
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
^ Yes. I actually had to loosen mine to get it working better, but try tightening it and see if that solves any of your problems.
Focus_Sh1ft is offline   Reply With Quote
Old 05-02-2013, 11:29 AM   #11
yariSB86
yariSB86's Avatar
Thanks guys, ill give it a shot.
Old 05-02-2013, 08:57 PM   #12
yariSB86
yariSB86's Avatar
Update: As mentioned earlier I checked my BOV, I checked the spring and messed with it a bit, I didn't really change anything. I hooked it up to a cummins radiator cap pressure tester. it actually worked well. I plan on upgraded the BOV later down the line anyway.
I decided to start a fresh tune to see if I can get it to idle like stock. think I got pretty close. I don't know why my rpms are still kinda surging, not nearly as much as before but they do like 250ish. you'll see in the videos im about to post. with this tune I test drove it down the street (not included in the video) and I had a bunch of misfires. My buddy sitting next to me with my computer hooked up the the fic was able to retard the timing live and we fixed all misfires. over all im pretty happy that I got it running well. I'm still going to get it professionally tuned here next week. it will be interesting to see what happens and what the dyno reads :)
so with out further a due.
Before I leaned it out:
https://www.youtube.com/watch?v=EETj1jC8MIA
After I leaned it:
https://www.youtube.com/watch?v=SDIYLWHa3pk
Little bit o boost:
https://www.youtube.com/watch?v=70fq_fzEbZc
Old 05-05-2013, 12:09 PM   #13
yariSB86
yariSB86's Avatar
so the local temp got warmer than when I originally tuned. so im misfiring and stalling again. time to adjust the maf map and retard some timing I think.
Old 05-23-2013, 08:46 AM   #14
yariSB86
yariSB86's Avatar
Update time:
I have an 08 ecu en route to replace my old 07.
I had a custom exhaust made. I'll show video of my old setup, then of the new.
Old setup
New setup
_______________________________________________
Old 05-23-2013, 08:48 AM   #15
yariSB86
yariSB86's Avatar
A few pics of the install.
List of Boosted Yarisworld Members - Redux CTScott Forced Induction Forum 40 06-29-2025 08:42 PM
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Boosted Yaris Quarter Mile Times 1.5 Forced Induction Forum 0 01-03-2010 05:49 PM
Going Boosted FryGuy Forced Induction Forum 53 03-01-2009 10:01 PM
PE Boosted Yaris Video jinxor Forced Induction Forum 16 02-06-2009 02:33 AM
