Old 02-08-2010, 01:29 AM   #1
*MAD DOG*
*MAD DOG*'s Avatar
Just had the NST CR Lite Crank pulley installed at a mechanic. They quoted me $90 labour an hour. They did the job in just under 30 minutes and charged me $45 woot.
First thing I noticed was when I put my foot on the gas pedal the car responded quicker and appeared to take off from a stop start faster and easier.
Then I drove around for a while with a big grin on my face and was very happy when a set of lights turned red (another chance for a take off test). I'm very happy with the NST product and would recommend it to anyone and everyone with a Yaris.
My wife has a 1.3 litre Yaris, I think the biggest gain would be on her engine. Maybe I’ll talk her into one of these and then get the 10% underdrive for myself.
NST FTW!
Old 02-08-2010, 01:35 AM   #2
Astroman
Modded Moderator
Astroman's Avatar
The bodyshop at the dealership noticed my NST pulleys and asked me all sorts of questions about them and were quite impressed. I think my Yaris is the only one they've seen that has just more than aftermarket wheels on it. Over 50k miles so far on my pulleys and I couldn't be happier.
Old 02-08-2010, 01:37 PM   #3
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
11K miles on my NST Underdrive pulley. 15 autocross events, 3 time trials. Zero problems, dyno-proven HP gains (see dyno thread), completely satisfied with the quality, aesthetics and performance of the product.
Old 02-08-2010, 02:00 PM   #4
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
I'm not sure if this is normal, but I was checking the pulleys I installed, well the waterpump nst pulley is starting to get engraved into. Meaning the belt is digging into the pulley so that theres an engravment from the belt in it is this normal if anyone knows what i am talking about?
Aothachos is offline   Reply With Quote
Old 02-08-2010, 02:13 PM   #5
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Yes, that is normal, everything will wear off eventually, even the strongest materials, just give it enough time and friction. The OEM water pulley is painted black, but when I took mine off it had a shiny strip where the belt makes contact.
Think of it almost as an infinite polishing machine
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 02-08-2010, 02:15 PM   #6
Aothachos
so eventually overtime I will have to replace the pulley? Is there a set certain amount of miles that NST recommends to replace it if so? It has been about 25-30 thousand miles since I installed these. I think it is also why my belt is squeaking everytime i start up because it is loose due to friction engraving its place in it lol
Old 02-08-2010, 02:26 PM   #7
fmicle
fmicle's Avatar
Hmm, honestly, I don't know, but then aluminum is lighter and softer than steel, so I wouldn't be surprised at all if it wears off much quicker. Can you really see/feel a groove where the belt sits? If it's just polished shiny I wouldn't worry too much. It would be interested to compare with an older OEM water pulley, see if you get the same wear after a while.
My belt is squeaking too, 1 in 10 starts I'd say, because I couldn't get it as tight as it should be. But I'm working on adapting the Scion xD belt tensioner to the Yaris and if I can make it work, I'll post the DIY
Old 02-08-2010, 02:42 PM   #8
Aothachos
no the groove is pretty deep i say about 1-2mm, u can feel the edges perfectly where the belt sits on the pulley
Old 02-09-2010, 06:30 PM   #9
jouna
jouna's Avatar
Drives: jdm yaris sedan
is there a big difference installing the power pulley set versus the underdrive pulley alone? i mean is it worth it?
vvti bregao!
jouna is offline   Reply With Quote
Old 02-15-2010, 02:44 PM   #10
NonStopTuning
Yes, there is a difference and it is worth it.
MIKE @ NST
www.NonStopTuning.com
Old 02-25-2010, 04:22 PM   #11
NonStopTuning
We just shipped out a few packages to the members on the MI GB. I hope to see a few new reviews in this thread soon.
Pics, reviews, thoughts, and comments are always much appreciated!
MIKE @ NST
Old 02-28-2010, 04:28 PM   #12
lammy29
Drives: Yaris
how much to uk for the 1.8 version?
lammy29 is offline   Reply With Quote
Old 02-28-2010, 06:36 PM   #13
NonStopTuning
http://www.nonstoptuning.com/pKitToyYaris.htm
Shipping fees, as always, are calculated by our online shopping cart at time of each order.
Thank you!
MIKE @ NST
Old 03-01-2010, 09:36 AM   #14
lammy29
Drives: Yaris
Thank you!
thanks... i think i might order it off garm as i am interested in buyiny aFe intake and perhaps little cheaper for shipping..... btw does garm get his orders from you?
Old 03-01-2010, 12:01 PM   #15
NonStopTuning
Yes, Garm (MicroImage) is the largest Authorized NST Retailer of products for the Toyota Yaris. He places orders with us frequently.
MIKE @ NST
Old 03-02-2010, 10:38 AM   #16
yarstar
Drives: 2008 Absolute Red HB
40K/2 years now on my Underdrive Pulley Set. Still Lovin' every take off! Really, really helps. Great, high quality upgrade. Thanks again, NST.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 03-18-2010, 04:02 AM   #17
Schizoprenia
Drives: Toyota Yaris 1.5 M/T '06
Hi NST,
i just want to enquire something. ur parts here in this side of the world isn't so common(Indonesia) i needed more information, if i have the Thai's built yaris, would i need a different set that is intended for the asian built ones? i know that waterpump doesn't fit right away but requires some sort of spacer if im not wrong, correct? can you please elaborate and maybe provide more information on the other crank underdrive as well as the alternator. thanks.
Schizoprenia is offline   Reply With Quote
Old 04-06-2010, 06:23 PM   #18
NonStopTuning
Originally Posted by Schizoprenia View Post
Hi NST,
Thank you for your interest in our site and products, we appreciate it.
I have posted this info several times in this thread, but will post for you again...
IFFF your 1.3 or 1.5 Yaris has a single-row (one belt) crank pulley, then you can order pulleys from our Yaris page on our website.
IFFF your Yaris has a two-row (two belt) crank pulley, then you will need to order pulleys from our Scion xA/xB page on our website.
Yaris 1.8L pulleys are also listed on our website on the Yaris and Scion xD page.
Thanks again, good luck and have fun with all your projects!
MIKE @ NST
