Old 05-21-2007, 01:54 PM   #1
NonStopTuning
Originally Posted by curik View Post
when is the pulley set coming out????????????
We need to do a bit of testing with these pieces before releasing them to the public. You guys can expect new NST pulleys sometime in July
http://www.nonstoptuning.com/pKitToyYaris.htm
MIKE @ NST
www.NonStopTuning.com
Old 05-21-2007, 01:50 PM   #2
ChinoCharles
Drives: LB
Here is a bump for you drift fans... see this RETAKS AE86?
Well, its wearing an NST supercharger pulley kit that ups the boost from the wimpy stock 8 PSI to a whopping 17 PSI! That is more than double the POWAAAA. Tack on a 50 shot and you get one punchy drift car.
http://www.youtube.com/watch?v=nWFImilgED8
You'll see her spinning about in there. Look for the car sponsored by the other guys... oh wait, there isn't one! NST'S PRODUCTS ARE TRACK TESTED! If they can hold up on a drift car, you bet your ass they'll hold up on your Yaris!
NST FTW
Old 05-21-2007, 01:55 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
what pulley are planned for the set?
Old 05-21-2007, 01:56 PM   #4
ChinoCharles
Drives: LB
Water pump and alternator to go with the crank pulley they already sell.
Old 05-21-2007, 02:01 PM   #5
Black Yaris
der Zeck
sorry... i need to learned how to read
Old 05-21-2007, 02:46 PM   #6
Shijima
Drives: 07 HB
Sweet, I should be getting my yaris around july/august. Just in time for the pulleys.
Shijima is offline   Reply With Quote
Old 05-21-2007, 05:20 PM   #7
Astroman
Modded Moderator
Astroman's Avatar
Woo-hoo! Now I know how much to save up
Old 06-04-2007, 08:09 PM   #8
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
is it going to be less expensive to buy it in a set or its the same to buy it appart;..
OxyG3nE is offline   Reply With Quote
Old 05-22-2007, 12:49 PM   #9
ChinoCharles
Drives: LB
You have to remember, it is a part that may be spinning at thousands of RPM's when it fails, turning it into a bonafide Dreidel of ultimate despair! I'll bet the side of his block is all jacked up too!
Not a part to skimp on if you ask me.
Old 05-22-2007, 02:58 PM   #10
kurokoma-kun
Drives: 2007 Yaris HB
...bonafide Dreidel of ultimate despair!
AHAAHAHAHAHAHAAAAHAA you are funny mofo chino
Old 05-22-2007, 09:31 PM   #11
MudBug
Drives: 07 Yaris
Installed mine today and the first thing I noticed was that it idles at higher RPMs than it did.
I didn't notice the idle being rough.
It does seem like the shift is smoother now (AT).
MudBug is offline   Reply With Quote
Old 05-22-2007, 02:09 PM   #12
tk-421
tk-421's Avatar
Drives: 5D-07-LB
OK... I guess I'm convinced. Now all I need to know is wether I should wait for the pulley set to come out or not. Sure, I understand that it's better to support our vendors ASAP so they can come out with products sooner and allathat, but I'm kinda wary about messing with the motor too many times.
I would much rather install the whole set once and be done with it.
Old 05-31-2007, 02:18 PM   #13
ChinoCharles
Drives: LB
NST @ SCION EXPO 2007
Old 06-02-2007, 03:46 PM   #14
ok, I'm in!
Just ordered from Dezod.... hope you have red, 'cause the website didn't say "no"....
Old 06-03-2007, 03:30 AM   #15
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
I will be definatly ordering the full set, (Crank/WP/Alt.) pulleys when they come out, Red all the way.
Do we estimate how much HP we will get with the full set?
Old 06-03-2007, 06:00 AM   #16
Nigal
Nigal's Avatar
I was looking at the pullies in my car the other day while changing oil. How hard is a pully set to install? It looked reeeeeal tight in there. I don't think I could fit my big dickbeaters in there to do it.
Old 06-03-2007, 07:51 AM   #17
tk-421
tk-421's Avatar
Drives: 5D-07-LB
A simple search in the DIY forum will turn up this:
http://www.yarisworld.com/forums/showthread.php?t=3964
Good luck!
Old 06-05-2007, 07:04 AM   #18
nigel
Drives: yaris
does the pulley work on other car with 1nz FE engine?
my dad also want to get one for his corolla with 1nz fe engine
nigel is offline   Reply With Quote
