Old 08-30-2013, 12:02 PM   #1
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Please, don't make the same mistake I made. Your head gasket is almost certainly fine. Some bubbles and metal shavings in your coolant/reservoir is also completely acceptable. Can you check compression?
I also had some serious overheating problems back when I first installed everything. At one point I had to drive almost 5 minutes with it on before I could pull over, so I can't imagine you did any damage.
Focus_Sh1ft is offline   Reply With Quote
Old 08-30-2013, 05:47 PM   #2
thatbryanguy
Drives: Yaris 3dr hatch
Just took it to the shop and they say no leaky gasket or anything. Just got a bunch of misfire codes popping up again...ugh. Did a really quick idle test with the FIC bypassed and it idled fine. I just don't understand how it does fine for a month then suddenly decides to have issues. I'm currently sitting in my car right now and all of a sudden cant get it to die out like its been doing. What in the world is up with this car!
thatbryanguy is offline   Reply With Quote
Old 08-30-2013, 08:18 PM   #3
mario98c
mario98c's Avatar
Get rid of the Fic and buy an standalone ecu. Boomslang make the pulg and play harness for the aem ems-4.
http://www.boomslang.us/aem-ems-4.ph...id=2&trans=all
Old 08-30-2013, 09:46 PM   #4
thatbryanguy
Yea if I had a couple thousand bucks laying around I woulda done that already :/ on my current budget I kinda have to work with what I've got at the moment. Maybe one day I'll save up to get something like that but that's not a possibility in the near future
Old 08-30-2013, 10:26 PM   #5
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Standaoone wont pass emissions either
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-31-2013, 12:36 AM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Hopefully you will get it hammered out soon bud. Just curious...do you have emissions testing in SC?
Old 08-31-2013, 01:22 AM   #7
thatbryanguy
Nah no emissions in SC luckily. I'm gonna rework some of my sloppy wiring and tidy a bunch of stuff up and then go from there tomorrow. I've got some bad wiring habits that left my work needing to be redone so if anything strange dealing with electrical issues is going on I may be able to find it this way. By the way...my climate control knob lights are all out. Anyone know which fuse that is off hand?
Old 09-05-2013, 06:15 PM   #8
thatbryanguy
Well I'm about to get it smoked for a vacuum leak first then try messing with the FIC. Problem being all I have are Macs and no PC's so I can't readily use the AEM software at my house. I'm hoping its a small vacuum leak now just so I can fix that and be done with this mess. I just realized last night one big reason I think it may also be a vacuum leak is all this started almost immediately after installing my boost gauge so maybe I have a tiny hole in the gauge line or I messed something up while splicing it into the FIC's hose line. We'll see after the smoke test in the morning though
Old 09-06-2013, 04:02 PM   #9
Focus_Sh1ft
It has to be a pretty large vacuum leak to be causing misfires. If nothing shows up, make sure you check the bov while the engine is running (hold your hand over the outlet and/or kink the manifold reference line).
Old 09-07-2013, 04:24 PM   #10
thatbryanguy
It hasn't been misfiring since I replaced the plugs except for that one time I started it up and all those codes just popped up but haven't seen them again since. I sprayed some carb cleaner all around any areas in the intake system with the engine running and no change or reaction in idle. I haven't had the chance to take my a-pillar off and check the whole boost gauge line yet though and I haven't checked the actual BOV yet either. After that CTScott suggested possibly the alternator dying under voltage load or something along those lines but I've been to 4 places to get the battery and alternator tested and they all say its good.
Old 09-12-2013, 12:22 PM   #11
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Any of those places an actual alternator/engine electrical specialty shop?
-Type 07 FFL-
My odometer 03/11
Old 09-07-2013, 08:14 PM   #12
DKN-YARIS
DKN-YARIS's Avatar
Drives: YARIS HB
I can pretty much say that i tried pretty much all of what you are trying as i'm at a shop all the time. For those of us that have or had stalling issues with the FIC is that when its bypassed, EVERYTHING runs fine. has nothing to do with any leaks related to the install. If the car runs fine when FIC is bypassed, safe to say its related to the FIC unit itself and possibly other items when tuning at WOT.
When trying to figure out where to start i looked at all the options possible and put it down on pen and paper and started to eliminate factors one at a time. As i have corrected the stall issue now and after months of driving and even going on track, no issues at all...
As stalling shouldn't (and didn't happen for me) when the FIC is bypassed, it lead me to believe that during feedback mode, the stock ECM was having a hard time with the readings from what i could see on my AFR gauge as it was running pig rich. After i knocked all the maps back to 0, i ONLY adjusted the areas in boost and left everything outside of boost and during idle to 0 so the stock ECM can do what it needs as the ratio can't be too far off from what the stock ECM is programmed for.
Keep in mind, I was adjusting my injector response timing to 810us and left it at that. Firmware is the other buggy thing you will have to play with along the way. Thanks to CTScott who did help me along the way with a lot of answers based on what he had seen with this type of setup.
If i use z104, car runs fine but still stalls EVEN at right after start up at idle.
If i use z107, car doesn't run at all, starts, engine has CEL and misfire like crazy.
z110 has been the only working option i have considering the other 2 give me issue right off the bat.
the only issues i still have are:
hard cranking (2-3 cranks) this is clearly a noted problem with AEM and noise in the lines not giving off the right signal (even with the Boomslang harness)
White smoke at cold start up (smokes does go away after the cat is heated up)
CELs only come on after a series of attempts to start the vehicle, i'll get a cam position sensor error.
I've gotten maybe once a misfire code on my way to track but that is partial throttle the entire way and i've changed my plugs, i suspect the gap may need to be adjusted to hopefully correct that...
Even after a good month of running with no problems, i changed out the radiator with a Mishimoto rad, slim fan (puller) AND a pusher fan in front as the shroud from Mishimoto gave me some overheating issues when i had the A/C and even with a full load on the car, no stalling.
I hope you figure out what the stalling problem is as i know what it feels like and hope to save you as much time as possible!!!
DKN-YARIS is offline   Reply With Quote
Old 09-07-2013, 09:11 PM   #13
thatbryanguy
Yea I haven't been able to mess with the FIC because of only having Mac's in my house. If have to get some time to borrow my brothers PC to make adjustments. And I haven't done a real test to see if bypassing the FIC alleviates the stalling issue, I bypassed it for a few mins in the driveway and it didn't stall but I didn't take it for a drive yet. I'll definitely be trying many of these things tomorrow though if I can. Thanks a bunch for the advice though! I'm running out of possible solutions haha
Old 09-11-2013, 06:43 PM   #14
DKN-YARIS
DKN-YARIS's Avatar
Drives: YARIS HB
Ya, i'm hoping I can figure out what the root cause of the white smoke is as well. if its the injector setup there isn't much I can do as my tune is already at 90% duty cycle on larger injectors so the stock ones won't keep up for sure.
Did you also swap our your injectors?
Old 09-11-2013, 07:08 PM   #15
white smoke *could be oil backing up in the return line.
Old 09-12-2013, 10:42 AM   #16
DKN-YARIS
DKN-YARIS's Avatar
Drives: YARIS HB
Would shortening the return line make any difference?
I tapped my block and got lazy during install and decided to not cut the line that came with the Zage kit but rather I just made it loop and everything fits haha.
Old 09-12-2013, 11:22 AM   #17
fnkngrv
fnkngrv's Avatar
At the risk of sounding like a jerk the words "lazy" and "turbo" or "supercharger" should never be in the same conversation. That return line really needs to be a direct shot from point A to point B with no loops, etc.
Old 09-12-2013, 01:09 PM   #18
DKN-YARIS
DKN-YARIS's Avatar
Drives: YARIS HB
ya, considering I've gotten the car to run now its time to clean up the areas I left as when I was putting in the motor getting some of the fittings and lines was a pain as no one stocked what I needed and was back ordered and my car was just sitting on the hoist.
Making a new line as we speak so hopefully that will fix the white smoke Issue.
FS: AEM FIC + Wiring Harness Boomslang djgab101 Items for Sale by private party 18 12-06-2013 04:36 AM
FS: Zage Turbo kit, AEM FIC with Pnp Harness djgab101 Items for Sale by private party 32 04-11-2013 11:42 AM
AEM FIC tuning experience thatbryanguy Performance Modifications 0 09-03-2012 02:29 PM
AEM FIC to replace CamCon cc101 ?? vten Forced Induction Forum 26 08-04-2012 08:38 AM
AEM FIC works perfectly cdydjded Performance Modifications 58 08-03-2009 07:20 AM
