Old 06-27-2016, 11:18 AM   #1
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
You've forgotten about the chip swap. Not sure though if the swap is required for the 0D030 TB version.
Sent from my LG-D801 using Tapatalk
tarkus is offline   Reply With Quote
Old 06-27-2016, 08:30 PM   #2
codemonkey23
Drives: 2015 Toyota Vios
oh.. right.. i have to re read about that chip swap.. i don't think it was discussed here in detail
codemonkey23 is offline   Reply With Quote
Old 06-28-2016, 08:06 AM   #3
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
I bought the 0D030 and did not require a chip swap
Fluxtasy is offline   Reply With Quote
Old 06-29-2016, 01:22 AM   #4
codemonkey23
hello everyone,
what is the chip swap for?
i mean every throttle body has a wiring socket right? so i will just unplug the wire socket from the 2nzfe TB then snap it into 1zzfe TB? then check if the butterfly opens when accelerator is depressed?
i am confused.. if the TB works why do i have to swap the chip?
and what is the chip? can sombody post a picture of the chip? :D :D i only know potato chips :D :D
Old 06-29-2016, 05:40 AM   #5
Fluxtasy
feed my pet
Fluxtasy's Avatar
I believe you will have idling issues if you don't do the chip swap. Try to source a 0D030 TB and save yourself the hassle on the chip swap. There's a thread somewhere on it.
Old 06-29-2016, 11:22 PM   #6
codemonkey23
oh i thought that i can fix idling issues by removing the epoxy on the allen screw of the TB? turn it 1 round counter clockwise?
thanks for replying
Old 06-30-2016, 01:48 PM   #7
tarkus
tarkus's Avatar
You will need to adjust that screw as well. This is all explained in previous posts in this thread.
Old 06-30-2016, 10:16 PM   #8
codemonkey23
yep.. but i guess the chip swap was not discussed
Old 11-29-2016, 11:01 AM   #9
JessMess
Drives: 08 Yaris hatch back
Does anybody know what years and models have the 1zz motor?? I do alot of junkyard shopping lol what car would i find the correct TB??
JessMess is offline   Reply With Quote
Old 12-01-2016, 10:18 PM   #10
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
any 60mm should fit...you should look for steel intake manifold for corolla 1zz...this one is really hard to come by...you have to modify the adapter a little bit but out comes pretty crazy..
Sent from my SM-J710F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 05-25-2017, 03:37 PM   #11
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
Uuuu
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 05-25-2017, 03:42 PM   #12
NJP440
2010EGGHATCH
NJP440's Avatar
Drives: White 2010 Yaris Hatch
Are we reviving this thread? Lol
Sent from my LG-H918 using Tapatalk
IG: 2010EGGHATCH
NJP440 is offline   Reply With Quote
Old 05-25-2017, 04:02 PM   #13
Yaris874
Yaris874's Avatar
I was just thinking of putting the 1zz throttle body lol I wanna to read the thread later wat u think
Old 05-25-2017, 04:05 PM   #14
NJP440
2010EGGHATCH
NJP440's Avatar
I think its a good idea. I still haven't installed mine yet its just sitting in a box in my closet but I'm installing my header and cold air intake this Saturday so the throttle body will be the next install on my list. Ill post up pics and reviews once its installed. If you're on Facebook my name is Nicholas Prendergast and on Instagram I'm 2010egghatch I always post updates on both as well
IG: 2010EGGHATCH
Old 05-25-2017, 04:03 PM   #15
Yaris874
Yaris874's Avatar
And any 1zz fit ??
Old 05-25-2017, 04:10 PM   #16
Yaris874
Yaris874's Avatar
I got u on Instagram I just ored a weapon r throttle control the u see those ?
Old 05-25-2017, 04:10 PM   #17
Yaris874
Yaris874's Avatar
The u know Wat throttle body
Old 05-25-2017, 04:34 PM   #18
NJP440
2010EGGHATCH
NJP440's Avatar
Pics?
IG: 2010EGGHATCH
TPS reading at WOT with 1ZZ throttle body? 4/20 NEVER FORGET Performance Modifications 14 07-02-2023 04:20 AM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
FS: 1ZZ throttle body and Fujita intake mrbond Items for Sale by private party 25 09-08-2009 10:21 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
