Old 05-13-2013, 02:45 AM   #1
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
CVT drain / refill - Yaris 2007
Hi,
My Yaris sedan has completed about 47,000 kms and I'm planning to replace the CVT fluid in the near future. Do I need to also clean up the filter inside or should a simple drain / refill suffice with removing the drain bolt and the drain tube?
Frankly, speaking I do not want to open up the sump but if it has to be done then will do it as that would entail replacing the gasket, drain tube o-ring etc.
Would appreciate some suggestions/advice from those who have done this.
Thanks
Tyrone
tyrone_yaris is offline   Reply With Quote
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
