Old 08-07-2013, 12:28 PM   #1
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
That cold mode does a lot of weird things to the motor. I made a video a while back about how my boost behaves differently when the engine is cold.
Old 08-09-2013, 10:03 PM   #2
Viperoni
Drives: 2005 Toyota Echo
It's blue on my Canadian Echo, takes a minute or two to turn off in the summer time. Never saw it turn red, even at lower speed road courses.
2006 Saturn Ion Redline
Old 08-12-2013, 01:27 AM   #3
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Hey Will,
Has anything changed with the stock temprature thermostat?
Greg
Old 08-12-2013, 11:28 AM   #4
3cyltrbo
Originally Posted by tooter View Post
Hey Will,
Greg
Haven't swapped it yet.
Just picked up extra coolant on Friday night (some is always lost when changing a T Stat) and then was busy with other crap all weekend.
I'm booked the next few nights after work, so the first free opportunity is probably Friday night (to swap back to stock T Stat and then after that maybe also try the stock TB)
W
3cyltrbo is offline   Reply With Quote
Old 08-12-2013, 03:50 PM   #5
At 175, I can't imagine it's in cold start mode. Is the OP losing power at that full temp reading?
Old 08-12-2013, 03:54 PM   #6
175 is over the cold start mode, but he said cruising that he was seeing 140 to 175. If in motion it stays down to the 140 mode, it will run more like the cold mode.
Old 08-13-2013, 04:16 PM   #7
3cyltrbo
If I have the time tonight I'll take it out for a drive and try to get some #'s
At this point its looking like the soonest I can swap the T-Stat is Friday night or Saturday afternoon.
Will
Old 08-13-2013, 04:27 PM   #8
It's ok. We'll wait. We gave Astroman over eight months. You're good.
Old 08-13-2013, 05:19 PM   #9
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
awe, why you got to bring that up
Old 08-14-2013, 12:23 PM   #10
3cyltrbo
LOLZ
Old 08-14-2013, 12:34 PM   #11
3cyltrbo
here is my datalogging?
outside air temperature was freakishly cold outside for this time of year
(15deg c / 59deg F) (during this trip the coolant temp never went above 63, but like I said it was freakishly cold for an Ottawa Summer day)
Driving water temp ( 61 deg c / 142 deg F) (85km/h - 53mph) (flat land / zero wind)
Intake air temp(while moving) ( 21 deg c / 69 deg F)
Intake air temp (stopped in traffic) (26 deg c / 79 deg F)
Driving pic (it was freakishly cold out)
In Light traffic (stopped for 1 minute, every 2 or 3 minutes)
Old 08-14-2013, 12:51 PM   #12
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I think my "cold" coolant light goes off at 135°F so you aren't running much warmer than that.
I always thought that a performance T-stat was hotter (not colder). I know back in my dodge truck days, guys would put a 195°F T-stat in place of the 180. I honestly don't think it does much.
Old 08-14-2013, 01:08 PM   #13
^ Maybe, but if he eliminates that as a cause by swapping back to stock, we can move on to the next possibility. Or, that IS the problem.
Old 08-14-2013, 01:16 PM   #14
I would say that IS likely the problem. 142 F is still well within the pre-warmed-up temperature range.
It was 55F here this morning when I drove my kids less than 2 miles to the camp bus and by the end of mile 1 (mostly downhill) I was at 181F.
Old 08-14-2013, 01:39 PM   #15
3cyltrbo
Next step = remove the colder thermostat - take some driving impressions and datalog the info.
It won't be 8 months (or never) ala "something big is coming", but it will have to wait till Friday night or the weekend because I'm busy tonight and tomorrow night.
Then, after the thermostat, if there isn't an improvement - the next thing will be to remove the Corolla TB (swap back to Stock tb on the Tooter) / then I guess the next thing after that will be the Factory Manifold etc...etc......
Only good thing about this process is that now I've done each part so recently that they stick in memory and therefore are pretty quick and easy to swap.
Old 08-14-2013, 02:30 PM   #16
tooter
play every day
tooter's Avatar
That's the prime directive for modern vehicle engines. Super quick warm up to operating temperature so as to meet government mandated emissions requirements. In warm California, my green light goes out before I get to the end of the driveway.
Old 08-14-2013, 04:39 PM   #17
BEEF
BEEF's Avatar
Sorry, I meant that increasing the temp probably doesn't help power. I actually agree that his car may be in a limp mode state given that he is probably running open loop and thus on a predetermined fuel map (really rich).
I am curious to see if changing the T-stat back fixes it.
Old 08-15-2013, 09:24 AM   #18
3cyltrbo
Curiously on the drive home last night it was much warmer outside, and the car was running "normal"(ish) temps in the 170-180 range at times and yet it was driving the exact same.
Looks like I'm taking the day off work tomorrow to stay home and try to get to the bottom of this
Will
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 04:36 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
