play every day
Modded Moderator
I wanted to update that now my Yaris has a cracked NST water pump! I put mine on more than 90k miles ago and my car has been unused for the past 9 months. After a rough start and replacing a dead battery and what I thought was a bad thermostat I noticed that after a few hundred feet my water temps were so high I threw a CEL and my hot light came on. After hearing clacking I looked thinking of this thread and sure enough in one spot it's cracked! Not happy with NST and I KNOW FOR A FACT MINE WASN'T OVER-TORQUED because I've had it problem free for 90k miles!
#3 | |
play every day
Modded Moderator
I'm running the full NST-lite pulley set problem free until yesterday. The wp pulley had a wear groove of about 1/16" and I wouldn't have known it was cracked if I hadn't been having overheating issues. My overheating turned out to be no coolant in the radiator.
![]() ![]() ![]() Drives: Prius C Join Date: Feb 2013
sounds like it simply wore out.
90k miles is pretty good usage for an aftermarket part if you ask me. |
I think their "hard anodizing" may have weakened the metal or made it brittle. It's pretty thin where is bolts to the motor.
Sounds like they designed it too thin or didn't machine it right.
Where'd the coolant go?
I need more stars
Drives: Liftback Join Date: Jun 2009
We all know the moral of the story here..
![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
I'm very surprised at the responses this thread has gotten.
I think i'm more surprised I haven't heard of this happening before. Definitely sounds like a design flaw in NST's pulley's, something is making them brittle and weak. I was going to try and get another one from NST, but since everyone else seems to be having the same responses...it might be best to stick to OEM. |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
makes me want to check my w/p pulley.....i hope it's ok! it's been on for quite some time.
Toyota Newb!!
Drives: Yaris S Sedan w/ Aero Package! Join Date: Jun 2006
I had a similar experience in that there was a lot of belt squealing and vibration....and then the belt eventually snapped. Turns out it was the NST WP pulley as well...after reading the problems you had I was going to switch back to OEM and this happened.
#13 | |
play every day
Greg |
I've been running my Perrin crank pulley for 8 years and have 140000 km on it with absolutely no issues. I've seen the stock pulleys fail too where the rubber rots and the outer part falls off, so six of one half dozen of the other.
play every day
Fair enough, Blue. There will always be different opinions drawn from each of our own personal experiences.
Greg |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
^ (pics above)
Wow (( |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
I have heard too many downs and not enough ups for any pulley changing. Stock for me.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
#18 | |
| WTB: NST Pulleys | *MAD DOG* | Willing to Buy by private party | 3 | 08-27-2011 03:37 AM |
| NST (NonStopTuning) Ebay Feedback & Rating | NonStopTuning | NonStopTuning | 0 | 07-19-2009 10:11 PM |
| Greddy TI-C, NST Pulleys, etc. | drkmcc | Items for Sale by private party | 12 | 02-12-2009 06:05 PM |
| NST Pulleys + Automatic Transmission | WeeYari | Performance Modifications | 17 | 01-31-2009 12:29 PM |
| Drift Yaris + NST Pulleys = :) | thefoth | Performance Modifications | 20 | 11-20-2008 09:03 PM |
