Old 11-11-2006, 02:30 PM   #1
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
On my liftback with cold weather package, the washer tank is so large, there is no space between the headlight and the tank - so no.
Old 11-11-2006, 03:14 PM   #2
Violin
Violin's Avatar
OK - here we go. Here are some photos from my install of the EaglEye high/low kit.
First of all, the Yaris has a switching ground system - one the three terminals are always powered, even with the lights off and the high and low beams are controlled by switching on the ground at one of the other two terminals. This is not the more common switching positives system found on most cars. Fortunately this kit makes it easy to handle this. On their web page, this is referred to as the 'special type':
http://www.namyung.co.kr/english/hotproduct/hidh4.asp
You simply disconnect the blue and black wires and reverse them. There is a diode with a little arrow drawn on it. You pull it out and turn it 180 degrees.
Disconnect the battery negative before you start.
It makes it a whole lot easier if you remove the five little black pop clips on the top of the bumper and the one in each wheel well to pop the top of the bumper out.
Remove the three bolts on each headlight.
It’s a good idea to mask each one so they don't get scratched.
Disconnect the wiring harness from each light and remove the rubber boot. Wearing latex gloves, remove the old light bulbs and install the new ones. Carefully cut off the rubber boots supplied with the kit, they won't fit our headlights. Pull the wires through the factory boot and put it back in place.
This seemed like a good place to ground the new wiring harnesses.
The power wires on the new harnesses go to the positive terminal on the battery. I removed the fuses first.
I got some M6 - 1.00 x 10 hex screws and lock washers to attach the relays on the top of the struts.
These spots worked for the ballasts.
I put a cable tie around each boot.
...and followed it up with some self sealing rubber tape - the kind electricians use on electrical services. This stuff is expensive, but I had some already and I really wanted to keep dust and moisture out of the headlight housing. You might safely omit this.
Finally, reinstall the 20 amp fuses in the new harnesses, reattach the battery ground, unmask the headlights and reattach them and the bumper.
Go grab a beer and wait till dark to aim the lights.
Old 11-11-2006, 06:13 PM   #3
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Nice work! Glad to see you got everything going correctly, your post will be a BIG headache saver for anyone doing the Eagleye High/Low kits.
Be sure to make a new post once you have them installed.
On a side note, the Eagleye single (low beam only) kits are cake to install, but thats because its just that,... a SINGLE beam kit! No relays to mount and wire, no need to remove headlights, just remove old, install new, and mount the ballasts.
Here's another option for mounting the ballasts, without having to drill anything.
Old 11-11-2006, 08:48 PM   #4
Yaris-TJ
Yaris-TJ's Avatar
Drives: Yaris Sedan ST Barcelona Red
hi guys! gotta question! it looks like if you have dual...do you need a relay?
also..wheres the diode that has to be reversed??
Yaris-TJ is offline   Reply With Quote
Old 11-11-2006, 09:39 PM   #5
Violin
Violin's Avatar
You only need a relay if you have another wiring harness which is really a good idea because the current draw when you first turn on your ballasts will fry your wires over time. My ballasts get powered directly from the battery - the factory wiring only serves to tell the relays on the new harness when the lights are on/off or high/low. The diode is on the new harness - if your kit doesn't have another harness, you won't have a diode.
I'm a little disappointed in the cutoff on the lighting. There is some reflection off the little doohickeys that control the high beams but overall, not bad. What isn't so good is I have to be really careful switching from high to low beams - if it bumps through the low beam position to the flash to pass position; one or both lights go off! Also, the high beam indicator doesn't work because there is no feedback from the bulb. I can live with both, I just have to be very careful when switching from high to low.
Low beam:
High beam:
Low beam on road:
Color (5,000k):
Old 03-27-2007, 06:48 PM   #6
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
question!!
do you have to take ur bumper out to install the hid conversion kit.??
Low beam:
High beam:
Low beam on road:
Color (5,000k):
Old 11-12-2006, 01:59 AM   #7
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Ok,let me get this straight before I order,with the single beam seat the boots supplied will fit right.
eco is offline   Reply With Quote
Old 11-12-2006, 03:21 AM   #8
Chris07LB
Chris07LB's Avatar
Whats included in BOTH kits is a rubber gromet... the gromet (size of a quater) is simply cut off, as its used only if you were to drill a hole in the housing (not needed) to route the wires, while making a weather tight seal..
Old 11-12-2006, 02:00 AM   #9
eco
eco's Avatar
And Violin,couldnt you skipe the mounting of the relays,by using a zip tie,and tie it to a wire from the engine.
Old 11-12-2006, 07:52 AM   #10
Violin
Violin's Avatar
True, but it looks much better the way I did it. There's certainly some flexibility in installation. Feel free to get creative.
Old 11-13-2006, 10:50 AM   #11
Yaris-TJ
Yaris-TJ's Avatar
Correct.I had to take mine to a shop...
The guys didn't have a clue at first.
Then he figured out that the way the light worked was that it changed grounds when doing the light change..
Then he made some inverts in cables, and it worked..
Not very satisified with ligh though...
I'll try to post pictures later on..
Low HID, looks like HIGH, since it shots the light above the space where regular low was..
High Halogen shots the light where the old LOW was..
Is there a chance that when I placed the bulbs they were reversed? I now that bulbs have some kind of 3-rivets, that make it fit only in one direcction..
any ideas?
Old 11-13-2006, 10:59 AM   #12
Chris07LB
Chris07LB's Avatar
H4 bulb base, either halogen or HID, will only fit one way.
With an EAGLEYE high/low HID setup, it will be the same light brightness for the high beams, but re-directed upwards. The stock factory H4 high/low halogen bulb, will be a brighter high beam light and directed upwards.
Correct me if I'm wrong, but doesnt your setup use a halogen for the highs?
Old 11-13-2006, 11:10 AM   #13
Yaris-TJ
Yaris-TJ's Avatar
With an EAGLEYE high/low HID setup, it will be the same light brightness for the high beams, but re-directed upwards. An H4 high/low halogen, will be a brighter light and directed upwards.
Yes Chris07LB...it has high-Halogen / Low HID..
mine is not as you mentioned..
It's actually opposite..
I don't have the EAGLEYET, but it should work similar..
Old 11-12-2006, 07:50 AM   #14
Violin
Violin's Avatar
But if I understand correctly, the factory boot seals the low beam only bulb like the standard H4 bulb.
I'm wondering if a resistor across the high beam ground and power on the factory plug will return functionality of the high beam indicator. I'll probably write the manufacturer regarding my two issues.
Old 11-12-2006, 07:53 AM   #15
Violin
Violin's Avatar
Oh yeah... the DRL's need to be disabled even with this kit... Sorry Canadians.
Old 11-13-2006, 12:41 PM   #16
Violin
Violin's Avatar
Can you tell which bulb is lit when you turn the high beams on? I guess it's possible that your installer wired it wrong.
Old 11-13-2006, 12:53 PM   #17
Yaris-TJ
Yaris-TJ's Avatar
When High Beams are turned on, Halogen are turned on, but the light aim as if it were low, but even much dimmer than stock low.
BTW..thanks for the support guys..
Old 11-13-2006, 12:48 PM   #18
Violin
Violin's Avatar
Looking at the car side of the connector you have three slots.
The vertical one on the right is always positive, the horizontal one in the middle-top is your low beam ground and the vertical one on the left is your high beam ground.
