#1 | |
![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
Most of the banjo feed kits do have built in restrictors, but they typically are offered in separate choices of 1.5mm for journal bearings and 1.0mm for ball bearings.
Do you think I'm safe with mine? another question, what's wrong with running the return line to the oil pan?
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin Last edited by Ryze268; 11-11-2014 at 01:00 PM. |
Just check the size of the hole in it. If it is too large then you maintain pressure through the turbo, which can cause oil seepage through the bearing and hence smoke out the exhaust. The return oil line can also cause the same problem if the oil exiting meets resistance (like pumping up through a puddle of oil). That and frothing of the oil are why you want the return above the level of the oil in the pan.
Mine backed up and smoked with the restrictor. Ran perfectly without it. Depends on your set up I think.
Thanks Garm, I'll try it will just the banjo fitting. I'm using -8 AN for the return, since my turbo will be above the engine I'm hoping that gravity will be on my side.
This is the fitting: http://www.ebay.com/itm/Turbo-Oil-Fe...03d73e&vxp=mtr I made it to work tonight (there's where I'm writing this from lol). Since the car runs fine with the bypass harness connected, does that mean I wired it correctly?
The bypass connector just jumps the intercepted wires together. It basically verifies that your in and out pairs are correct for any of the intercepted wires.
Awww so that means I'm not in the clear yet huh?
Connected the F/IC today with the AEM supplied base map, at first the car wouldn't start then when it did, it struggled to idle and would not rev past 3000rpm.
Am I missing something?
Is this the first start up? Is your car still stock? If it is you should have all zeros in all the maps so that it doesn't make any changes to the factory tune.
Yes, still stock except 1ZZ injectors, all the maps are zero'd
Also, make sure on the AEM software that you go into "Setup" "System" and set the injector response time to 810 us.
You should go to injector size change put in original size then change to 1zz. I think stock is 200cc and 1zz is 250cc if I remember correctly.
#14 |
I will look at my old maps to make sure.
#15 | |
I read this forum post
#16 |
The resistors are not a bad idea to add. As long as you tie the other end of the resistor to a good ground it doesn't matter where you do so.
#17 |
Would the best ground be straight to the negative terminal of thee battery?
#18 |
Yes, but that is not necessary. Any ground bolt or ground wire is sufficient.
| Quick question for those who know................. | NEexpat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 11-21-2012 01:38 PM |
| Quick question | StephenMenace | Third Gen Yaris General Discussion | 4 | 01-27-2012 07:20 AM |
| Just a quick Oil question | mr_miles | DIY / Maintenance / Service | 19 | 11-04-2011 11:31 PM |
| Quick Oil Question | nickhjort | Performance Modifications | 5 | 04-27-2010 08:51 AM |
| ZPI Turbo question? | localnet | Forced Induction Forum | 15 | 06-29-2007 06:06 AM |
