#1 | |
![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
A quick diagram would b helpful. I'm really disappointed that the F/IC is turning out to be such a headache. It would feel great if we could finally get it working right
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
#3 | |
![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
Yea the battery negative will be a good ground. I had that problem with noise before and the resistors fixed it after adding many resistors. U should try with your stock injectors first and see if u have the same problem. Only try to change one thing at a time so u can keep check of how it responds.
#5 | |
I had to do that on a 5efte starlet engine so I know that it can work once it is the problem. Add resistors until you get a clean signal as different situations will require different amounts of resistors and it also depends on the amount of interference you are experiencing. I had to add about 4 resistors per signal but that was a much older car (1991)
#7 | |
Tried the resistor mod, the car idled a lot smoother but still refused to rev past 3000rpm.
Vid here: https://www.youtube.com/watch?v=FtVrqai0icc What settings would affect the RPM in the fic? I'm just about ready to give up..
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin Last edited by Ryze268; 11-14-2014 at 04:42 PM. |
Don't give up. you will definitely enjoy it in the end when it is working great. Trial and error is all part of it. all settings for fuel and ignition should be at zero but in your case with the larger injectors try setting fuel at 3k rpm a little negative. How many resistors you added?
#10 | |
If the ecu can rev just fine with the bypass harness, shouldn't it rev just fine with the fic zero'd? Now I'm starting to think I have a bad fic
try adding a second resistor....then a third and see if it improves.
Just saying from past experiences with another vehicle I got no improvement after one resistor, nor two, nor three, it was successful after 4four resistors. Its worth a try for you too. the resistors are cheap and easy to connect. |
I'm waiting on CTScott to reply. i believe it's wired in wrong.
Wiring is correct, disconnected the CAM and CRK wires same issue occurs, would flooding the engine with fuel cause it to not rev?
![]() ![]() Drives: 09 Yaris Hatchback Join Date: Oct 2014
| Quick question for those who know................. | NEexpat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 11-21-2012 01:38 PM |
| Quick question | StephenMenace | Third Gen Yaris General Discussion | 4 | 01-27-2012 07:20 AM |
| Just a quick Oil question | mr_miles | DIY / Maintenance / Service | 19 | 11-04-2011 11:31 PM |
| Quick Oil Question | nickhjort | Performance Modifications | 5 | 04-27-2010 08:51 AM |
| ZPI Turbo question? | localnet | Forced Induction Forum | 15 | 06-29-2007 06:06 AM |
