![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Hey guys remember, boost doesn't bend rods. Power and detonation does. I built my roomies xB and with a 3.5psi wastegate spring it is making more power than the stock motor should handle because it has a t3 60 trim coupled with an efficient setup. When I had my Greddy kit I needed to run 15 psi to make the same power.
Ptuning.com |
#2 | ||
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
![]() ![]() ![]() Drives: 2010 Yaris 3 door, manual tran Join Date: Jul 2013
I don't know poop about turbos, as I'm just starting to learn about it.
But, isn't this a well documented thread? Link: http://www.yarisworld.com/forums/showthread.php?t=30813 |
^ GREAT link.
Thanks for the link i have added it to the information.
after talking to the wife and figuring up the numbers, i'm just going to keep it going and reliable and possibly sale it to go buy me a Hemi (Challenger SRT8).
^ I knew that was coming.
Roadrunner Jr.
Detonation...reduce it by using higher octane gas (premium at least)/e85...
With e85 you're talking about redoing the fuel pump to keep up with demand. IIRC you can use C16 with a stock fuel pump because of the weight (?) of the fluid versus e85*. Garm, your former Yaris's engine was fully built wasn't it? What did you have for compression? *=I'm not sure on the Yaris's fuel system. On my other car, that's a yes. Being as cheap as possible usually doesn't lend itself well. If you're going to play around with this stuff, don't get yourself stuck on the side of the road, especially if the car is your DD.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
Mr. 155 and climbing
Unless I am totally mistaken the biggest and ppossibly only issue with going with racing fuel over the VP100 level would be possible plugging of your cat would it not?
| Post minimum for PM? | 2mtech | Suggestions - Feedback - Questions | 2 | 09-12-2011 08:05 PM |
| The factory radio circuit needs to be a minimum of 15A. | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 06-07-2011 10:41 AM |
| Highway minimum speed limit | bentjazz | Fuel Economy Forum | 33 | 04-12-2011 05:38 PM |
| ACEITES Y MANTENIMIENTOS | Yaris PTY-507 | Central and South America | 22 | 10-01-2007 10:57 AM |
