Old 06-04-2006, 08:03 PM   #1
Bones
Bones's Avatar
Drives: 07 Yaris S Type
Rear 6X9s are straight forward. After taking off the rear deck, four 10mm bolts hold each factory speaker. You'll have to drill your own bolt holes, the factory speaker bolt pattern are wider. Depth is not an issue at all.
Bones is offline   Reply With Quote
Old 07-03-2006, 01:30 AM   #2
Alexandre2k3
Drives: Yaris liftback
Sup all, Just put in a pair of alpine type s in my white HB, it was easy and I didn't need any speaker adapters. I just gutted the inside of the stock ones and used the top of the stock speaker to mount new ones on, just used small screws and screwed them on to top.
Alexandre2k3 is offline   Reply With Quote
Old 07-06-2006, 01:50 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Do you recall the depth on the 6.5"'s? What model are they?
Old 07-17-2006, 09:22 PM   #4
IZAMUPR
BioHazard
IZAMUPR's Avatar
Drives: Yaris Sedan Blazing Blue
ppl, i am new here, i just have 1 moth w my Sedan yaris,
i have an question , i am seeing all bout the center console( great stuff) and the doors spk, but what about the rear spk, they come w speaker bracket integrated,w/ the spk, plz post some pics, and instrucions to how, upgrade this part. thx and I LOVE MY YARIS.
IZAMUPR is offline   Reply With Quote
Old 07-17-2006, 09:27 PM   #5
fnkngrv
fnkngrv's Avatar
I have a hard copy of how to install the rear speakers and the front...I am going to scan them in at work tomorrow and then figure out a way to place them here...can someone host the doc for us if I email it?
Old 07-18-2006, 02:18 PM   #6
ChinoCharles
Drives: LB
Yeah, I can host it. Just e-mail it to me. charlesluzar@hotmail.com
I'll put it up when I get home from work tonight if its in my box at http://www.luxlightandland.com/yarisworld.
Old 07-18-2006, 02:28 PM   #7
fnkngrv
fnkngrv's Avatar
I woke up late this morning and was not able to pack the docs...I am sorry...I will have to see about taking care of it tomorrow...I am having driver issues with my scanner at home.
Old 07-19-2006, 01:17 PM   #8
fnkngrv
fnkngrv's Avatar
I have just emailed the docs to Chino....it has a lot more than just the speaker stuff too....it might not be what you are truly looking for, but hopefully it helps ya.
Old 07-19-2006, 01:45 PM   #9
ChinoCharles
Drives: LB
Just uploaded the file... it is in TIF format just so you know.
http://www.luxlightandland.com/yaris...ERFORMANCE.tif
Old 07-19-2006, 02:15 PM   #10
ChinoCharles
Drives: LB
A side note... I have Windows XP and when I went to open this file it wanted to use Adobe Photoshop to do so, but when I did it was one page and the dimensions where all whacked out. If you right click on the file and go to Open with > Windows Picture and Fax Viewer you will be able to view all 14 pages of this file. By the looks of things, I had better get nice and drunk before trying to install new rear speakers. Jesus.
Old 07-20-2006, 07:25 AM   #11
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
When I changed the speakers in my hatchback, I used the frame of the stock speakers as a mounting bracket like Alexandre2k3 did.
The front was pretty simple – I just used longer screws to attach the new speakers into the old speaker housing (after gutting it). I had to break off the edge of the plastic rim all around for the 6½” speaker to fit inside.
The rear was a little trickier. I put 5¼” speaker in but the stock speakers were a little larger – maybe 5½” or 5¾” so the new speakers slid through the opening. I just used the mounting bracket that came with the MB Quarts and glued it upside down on the stock bracket using construction adhesive. Then I attached the new speaker to the bracket using screws.
I also put Dynamat Xtreme inside the door panels and the hatchback lid and some closed cell foam over the rear wheel wells. It really cut down road noise and eliminated that cheap sounding *ting* when closing the doors.
[MB Quart RCE-216's up front and RCE-213's in the back]
Old 07-20-2006, 08:21 AM   #12
fnkngrv
fnkngrv's Avatar
Well unfortunately for some people the docs that I had to post I believe were only associated with the Sedan.
Old 07-27-2006, 08:46 AM   #13
MacMaster761
Five-Star General
Drives: 07 Silver Streak Mica
Send a message via AIM to MacMaster761
speaker sizes???
how did you open up your dash like that, just curious?
how do you mount the speakers back on after you drill out the rivets?
did you need to buy another faceplate? how much and where did you get it?
is that enough questions?
thanks
MacMaster761 is offline   Reply With Quote
Old 08-03-2006, 01:57 PM   #14
fnkngrv
fnkngrv's Avatar
Yeah...I really need to know what the max depth would be that we can accept in the doors before I order mine. I am ready as soon as I have some good solid info.
Old 08-04-2006, 09:12 AM   #15
fnkngrv
fnkngrv's Avatar
Try Crutchfield.com
Old 08-04-2006, 11:04 AM   #16
seriousfun
Drives: 2007 Yaris Liftback Black
Here's that .tif as a PDF.
seriousfun is offline   Reply With Quote
Old 08-15-2006, 09:45 PM   #17
MacMaster761
Five-Star General
hey guys, are all aftermarket headunits the same size if they are single din? Will a pioneer headunit work the same way?
what is the antenna thing for?? i found a 40-vw21 on circuit city.com, will that adapter work the same?
JWU '09 Baking and Pastry
Stereo Upgrades....what to do!? gravylegs In Car Entertainment + Electronics (audio / video / alarm) 39 02-28-2010 12:58 PM
Security upgrade Ryu General Yaris / Vitz Discussion 7 05-09-2006 09:00 PM
security upgrade? got615 General Yaris / Vitz Discussion 4 04-27-2006 09:50 AM
aftermarket stereo kit? xCookiE General Yaris / Vitz Discussion 4 02-16-2006 10:33 PM
Factory Stereo and Audio kralmrax In Car Entertainment + Electronics (audio / video / alarm) 2 01-14-2006 01:06 AM
