Ask them to check for other yaris years. They are the same.
Even the Toyota echo have the same battery. Group 35 it is. |
Same size yes, but terminals reversed.
When mine died while on vacation last year in Moncton NB., I was forced to buy the only thing available on a Sunday out there. For $87 plus tax, I bought a store branded battery from The Battery House, a local outfit. I have no idea what the hell it really is, but it has more CCA and greater reserve than my OEM. Carries same warranty as the best of them so time will tell. So far so good, but it is only a year old.
![]() ![]() Drives: 2008 5 Speed Sedan Join Date: Jan 2011
I've still got the original Toyota battery in mine, I've accidentally killed it twice, charged it back up and still going. Canadian Tire told me it needed to be replaced the second time I killed it and that was 2 years ago.
266,000km on an 08 sedan |
![]() ![]() Drives: Yaris Sedan Join Date: Apr 2012
Just replaced mine a couple day ago with Costco battery. Group Size 35. Great performance rating! Should be more than enough to start the yaris right up.
Modded Moderator
I use a Walmart Everstart. Works just fine. Picked it up after my original battery died in a Walmart parking lot.
still on my original 07 ....will see how it does this winter .
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
soon
The battery is like 6 years old and starting to swell a little. Going to replace it next month when it cools a little. Going with the Napa, it has good stats.
I would rather be proactive and NOT get stranded. |
![]() ![]() Drives: 07 Yaris Liftback Join Date: Nov 2010
I'm still on my stock Toyota battery. It felt a bit weaker last year so I popped open each tab to access the cells and topped it off with some distilled water, put the tabs back on, shook it up, and put it on a slow charger for a few days. Seems to be running stronger so far but then again I live in an area where the weather doesn't get too extreme.
#10 | ||
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
#11 | |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Oct 2012
I always put new red and green felt washers on the battery terminals when I replace my batteries plus dielectric grease. Have had little or no corrosion on the battery terminals for the life of the battery.
Roy |
Earlier tonight I decided to start my 2007 Yaris (in the garage, with the door open) for the first time in 2 weeks (since driving home after the fender bender on 10/7/14). I crossed my fingers before turning the key. I needn't have. It started up as if the last time I'd driven it was a few minutes ago
#14 | |
but at around 4 weeks, now it should be a little harder to start. At least, under extreme cold (-30c/-22f) |
When the #2 and #3 batteries in that car were almost new, the car did hesitate to start after two weeks of non use...at least once with each of them. However, that might not be a fair comparison as those were both series 26R batteries, rather than series 35.
#16 | |
#17 | |
My duaghter drives her Camry 40,000 miles a year. She has massive problems with battery terminal corrosion. Theres two inches thick corrosion on top of the battery and corrosion on a nearby computer and the fuse box. Unfortunately I didnt put wheel bearing grease on her battery when she got it. My wife drives her Camry about 12,000 milesa year and has moderate corrision problems. About every two years the terminals need to be cleaned and flushed with baking soda solution if you dont grease them up good. But its only a tenth as bad as my daughters car. My Yaris gets ~5000 miles a year and has zero problens with corrosion even if the terminals arent greased.
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Apr 2009
Hey all, quick question. I've read here on the forum about quite a few people getting 4+ years out of their OEM Yaris battery. Isn't that really good? Why not just buy another OEM battery from Toyota if they last so long? Is there something I'm missing?
My 2008 Yaris' car battery finally died on me after 6 years (61k) and I'm thinking if it lasted that long, shouldn't I just get another OEM battery from the dealer so I can get a lot of years out of it? My local dealership has a coupon for a Toyota True Start 84 month battery for $129, installed. Is that a good price? I'm assuming that's the same OEM battery that comes with the Yaris, right? Is there any specific reason why I should avoid the OEM/Toyota True Start battery and instead go with a name brand like the Napa Legend that's been mentioned here? |
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
| CtrlAltDefeat - Photo-Scavenger Hunt | CtrlAltDefeat | Photo-Video-Media Gallery | 0 | 03-04-2009 02:14 AM |
| Custom Lftback - Photo-Scavenger Hunt | custom Lftback | Photo-Video-Media Gallery | 2 | 03-01-2009 11:12 PM |
