Old 11-28-2012, 09:26 PM   #1
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Chinese tires are sketchy at best
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 11-29-2012, 05:28 AM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
17 will fit just watch width and offset. With springs you might get minor rubbing on turns but should be fine.
Old 12-06-2012, 12:51 AM   #3
phaznet
phaznet's Avatar
Drives: '07 Yaris Sdn
I'm interested in some wheels on sale by one of the forum members.
Would 205/40 tires on 16x7 wheels work on yaris with tein s tech springs?
phaznet is offline   Reply With Quote
Old 01-30-2013, 06:59 PM   #4
FHT_Racing
Drives: 2009 Toyota Yaris 3-Door
Just in case it hasn't been brought up before, the factory 15x5.5" steel wheels weigh in at 14.8lbs :)
My 15x7" WORK Emotion CR Kai's weigh in at 15.6lbs, so I'll be switching to Team Dynamics 15x7" which I hear weigh in at just over 13lbs...
FHT_Racing is offline   Reply With Quote
Old 02-17-2013, 06:46 PM   #5
JoćoMendes
Drives: Toyota Yaris D4-D
Hello I have a 2010 5-door HB..and i'm looking for some pretty good wheels. Will I have any problem fitting 16" Speedline Chrono with +35 ET? The tyres will be 195/50 and the car isn't lowered rigth now..it will be, with H&R about 1,2''..no more than that. Can anyone help me please?
Thanks
JoćoMendes is offline   Reply With Quote
Old 02-17-2013, 11:05 PM   #6
33OH
Drives: '08 Yaris
Joao, how wide are the wheels? If they are 16x7's, you won't have any issues at all with that offset and tire size.
Old 02-18-2013, 06:43 PM   #7
JoćoMendes
Thanks for the quick response 33OH.
Yes, they are 16x7''. Another doubt..my yaris is a diesel engine, a 1.4cc 90hp, will it run 17x7'' ET 40 with 205/45..or it will be to much ?
Thanks a lot!
Old 04-23-2013, 10:23 AM   #8
Mikkelsen_7
Drives: ToyotaYaris Hybrid H2
Hello, i hope there is someone who can help me,
i am trying to figure this out..
I have a:
Toyota Yaris Hybrid.
right now i am driving on 15" standard weels and 175/65/r15 tires...
I want to go to 16" MAK Iguan Matt White.
(195/50r16 tirers)
But i dont know about the ET and the others thing...
I dont now what my 15" are in ET.....
What i can read, this might be the right one for 16"?
16" x 6 mm x4x100 mm ET43 57 mm
(thats the MAK Iguan)
Would these work?
Regards
Peter
Mikkelsen_7 is offline   Reply With Quote
Old 04-23-2013, 11:06 AM   #9
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
16x6" ET43.
pcd 4x100
It will work.
16x7" would be ideal.
But the MAK Website says "not available". You may have to contact them first.
Old 04-23-2013, 12:12 PM   #10
Mikkelsen_7
why would a wider rim, be better on a hybrid? ... then you got a bigger surface, that uses more BHP ?
Old 09-18-2013, 03:45 PM   #11
speedysilver
Drives: pocket rocket
help
help choosing tires for two different sets. My car 3dr hatch would be lowered more +1
15x7 +32 looking at 195/50
16x7 +35 looking at 205/40
thank you in advance
speedysilver is offline   Reply With Quote
Old 09-18-2013, 04:08 PM   #12
Those tire sizes are too short. 50 series should be on 16s and 40 series should be on 17s.
Old 09-18-2013, 04:12 PM   #13
speedysilver
what do you mean help? I dont see a question?
Are you asking which of those two you should go with? That would be a personal preference. If you like the way 15s look go with that, if you like the way 16s look go with that. I would not go wider than 195 on a 7, not saying you CANT go wider, that is only my preference
Sorry to clarify...I would like to know what size tires would fit best on a lowered yaris considering the wheel specs I posted?
so you're saying 50 series on both?
Old 09-19-2013, 08:31 AM   #14
33OH
Drives: '08 Yaris
He's saying 205/50/15 (or 195/55/15) on the 15", and 195/50/16 (or 205/45/16) on the 16".
Old 02-18-2013, 07:10 PM   #15
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
16x7 is probably pushing it weight wise, but at least you will have the torque of the diesel to help.
Colin Chapman disciple
Old 02-19-2013, 05:27 PM   #16
LOKink
Drives: 2007 3dr Lift Back
I have an 07 Hatch lowered with springs, I am looking at putting on 17x7 Sparco Asetto Gara with 195/40/17 will I have any problems with rubbing or anything?
LOKink is offline   Reply With Quote
Old 02-19-2013, 05:40 PM   #17
vten
I'm running similar setup , with +37 offset . No rub at all ..... But after I added a 10mm spacer on the rear, it rub a little on a large dip .
Old 02-19-2013, 05:53 PM   #18
LOKink
thank you! wheels and tires ordered.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
