Old 11-04-2014, 04:36 PM   #1
thebeaglebeagle
Drives: 2015 Yaris L
1. Is this updated for 2015? My Yaris has 175/65HR15s.
2. Is it safe/a good idea to put on 185s or 195s for snow tires? It is sometimes difficult to find a 175s.
thebeaglebeagle is offline   Reply With Quote
Old 11-11-2014, 06:22 PM   #2
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
I will post pics when I get em on, I just ordered through Ford ,Michelin Premier A/S 205/50/16 V rated, to replace bone stock T rated cooper slide in rain tires....
Also, Konig Feather Black, 13.8 pound rims, woo hoo....Getting the tires for 142 and change each with a 70 dollar rebate and got the feathers for 426 on discount tire direct....they have some smoking deals, as I was having trouble between the DR 41 and the DR 16 and DR 31, or the feathers. Had my eye on the feathers for some time now. sold the wife's camry rims, which help offset, the cost, sold them for 370, so it's like 50 some bucks for my rims I tell her....nice, cannot wait....
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires
TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
JimKellyfan is offline   Reply With Quote
Old 11-13-2014, 10:17 AM   #3
WasabiAngel
Drives: 2010 Yaris 5DR Hatch LE
Need Help Please...
I know there's some very inclusive details on the first page with all the numbers, but I'm not too familiar with this stuff.. so, was wondering if I can get some help.
I have a 2010 Yaris 5 Dr Hatch LE. No mods.
Looking to put winter's on and I see Costco has a sale for Michelin - X-Ice® Xi3.
Tire Size: 175/65R14/XL 86T
Including taxes (Cdn) and installation per tire it's $137.28.
Good choice? Good price? Correct size?
Thank you for all your help!
WasabiAngel is offline   Reply With Quote
Old 12-15-2014, 09:20 PM   #4
JimKellyfan
Cool pics
Here are the pics from just after install.
To report, the tires do rub a bit (11 am position LF -- 1 pm position RF) up front when driving severely (40-50 mph around a sharp turn)...
A friend was saying I could have a body shop roll the fenders....
I was wantin to get high performance or heavier sprung springs.
Currently, I think coil overs are the only option, as I definitely not lowering it.
(an example, on old Caprice, I could put regular front or rear, or the ones I went with, cargo coils in rear - no HP available, and in front HP springs) Then, coil over shocks...
I was hopin someone made HP coils for us...anyone know of any, PM me pls.
Someone earlier asked about Michelin X-Ice (awesome and should fit no issues on a 14 inch rim)
Old 12-17-2014, 08:09 PM   #5
Ben_
Drives: 2010 Yaris Hatch
Lol! If I ever get enough money together for a set of dedicated auto x tires I want to get my moneys worth. 15x7 rims and 225 tires are the fattest tires that are legal for stf class which is what I would plan on running. Go big or go home!
Ben_ is offline   Reply With Quote
Old 01-27-2015, 01:36 PM   #6
markcuban
universal 4 bolt pattern
I'm looking at a set of ICW racing rims from a craigslist ad the are 15" universal 4 lug pattern. Will they fit my 07 Yaris?
markcuban is offline   Reply With Quote
Old 01-27-2015, 02:29 PM   #7
Ben_
The easiest way to check is to go down there and try them. If they bolt upa and don't scrape the brakes or the fender/body you are good
Old 03-05-2015, 09:17 AM   #8
MJZ
Drives: 2008 Yaris 3 Door Manual
Anyone running 195/65R15 ET 38 ?
The one tire website that allows you to do a compareson between the 2 tires sizes reports that I should have no issues outside of the tires being 16mm larger overall, which with a stock suspension *SHOULD* be fine... anyone have any inputs or personal experience with this size? Got a 2008 2door HB.
MJZ is offline   Reply With Quote
Old 03-05-2015, 09:47 AM   #9
^ There will be no issues.
Old 03-05-2015, 09:58 AM   #10
MJZ
Coolness! Thanks man!
Old 05-30-2015, 08:39 PM   #11
mouvoi
Drives: toyota echo 05 hatch
Hey Guys !
I have a question about tire rubing on my toyota echo hatch 05
I have 205/45r17 rims. I bought those rims used and the owner didnt know the offset....
I am presently running them on stock suspension , I rarely rub in front when I am maxed out.
my question is if I install Tein S.tech springs will it rub ? the springs are 1.7 inch drop in front and back .
Thanks guys
mouvoi is offline   Reply With Quote
Old 07-09-2015, 05:17 PM   #12
Ben_
Look at the room you have in your fenders. If you have 3" clearance I'd say go for it. On a one off setup there is no "yes or no" since probably nobody has ran that tire size those rims those springs and whatever alignment you have. The only sure fire way to find out is to buy them and try it on. Other than that get out your measuring tape. You will need clearance for suspension travel
Old 02-18-2016, 05:17 PM   #13
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Figured I would post a link to my favorite tire size calculator. I use it all the time at work. It lets you compare the measurements of two given size tires. Really great tool. The wheel one that what posted in this thread is awesome also.
Tire size Calc
brushforhire is offline   Reply With Quote
Old 04-29-2016, 07:59 PM   #14
texascolt45
Drives: 2015 yaris
new shoes
205/50-15 toyo's.Konig Helium 15X6.5 bronze.
texascolt45 is offline   Reply With Quote
Old 10-31-2016, 06:58 PM   #15
curtishunter
curtishunter's Avatar
Drives: 2008 Toyota Yaris Hatchback
I didn't find an answer for my question...
What is the OEM size for the spare wheel on a 2008 Yaris 2dr hatchback with 15" factory steel wheels?
I bought the car for my wife but the spare wheel is missing.
I've asked the local Toyota dealership and they wanted to sell me a full size wheel and I told them, that won't fit in the trunk...
Then they sent me an email with these numbers: T125/70D15
I went to the local junk yard (I don't want to spend 180USD on the rim +155USD tire + tax) and find one for 20USD.
When my wife came home I tried the spare next to the full size wheel and it was much smaller! (The diameter). Is it normal? Or that car needs the T125/70D16?
Help me please! I am so confused...
curtishunter is offline   Reply With Quote
Old 10-31-2016, 08:11 PM   #16
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
T125/70D15 is correct.
Yes, it is smaller and looks even smaller when on the car. It is normal.
Hence the words on the spare "Temporary Use Only".
It's only meant to take you to the nearest town to fix your flat tire.
Old 10-31-2016, 09:14 PM   #17
curtishunter
"yarisugi"
Thank you so much. And thanks for the picture. :)
I was an id1ot! I found all the info on the driver side door frame....
Old 11-29-2016, 02:11 PM   #18
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
Official YARIS Wheel & Tire Guide
Winter tires now ...
wheels are Sparco Drift 6.5x15 et37 with Nokian Hakkapeliitta R2 studless 185/55-15 !
KimmoKekki is offline   Reply With Quote
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
