#1 | |
![]() ![]() Drives: 07 Yaris Join Date: Sep 2012
Did you do a 2zr swap at one point?
How was it? And what did you do for mounts? Quote:
#2 | |
09 Yaris S 85 Corolla GTS |
#3 | |
iQ innovator & researcher
Drives: 2012 iQ Join Date: Mar 2016
Which Whiteline Control Arm bushings are you using in the Yaris control arms? Are you using the CASTER + or just the normal? |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Correct, we did perform a 2ZR swap in a fellow NCVC members car. We used a Scion Xd as a donor car, and everything fit perfectly. We then put the 1NZ in the Xd, and that's his daily driver. Scott was a major help with the wiring!
The power increase is noticeable in the lighter Yaris chassis, and even with no mods on the 2ZR it's a blast. |
#5 | |
2ZR swap. DO IT! Ask how!
#6 | |
Always was curious about similar platform swaps but unfortunately there doesn't seem to be enough write-ups. So would you say it was mostly plug and play? Was it a fairly expensive swap? And what mounts were used? Last edited by 7:34pm; 05-21-2015 at 08:51 PM. |
Data doesn't lie
We used the radiator from the Xd, it's the same size core with a slightly different upper hose outlet. Fits perfectly in the Yaris core support. No cooling issues.
Data doesn't lie
Mostly plug and play, everything from the XD was moved over to the Yaris. Just a few wiring differences.
I remember that thread. I had that thread subscribed and was one day put together a write up for that swap. Now that website is gone, so is that information. Any chance one day you guys could get a small write up on the swap. I do remember having to swap some wires inside a fuse box or connectors for something, ABS maybe? You didn't use all the same mounts either right?
Data doesn't lie
We are currently doing a write-up for SubCompact Culture, then we can re-build a thread here!
Data doesn't lie
I don't know what the part number is, I got these from MicroImage(CaliYaris) years ago. You only need 2 for the front strut tops. Cusco offers a mount also....I think.
Cusco IICR is a solid mount... wouldn't recommend that for daily driving.
Data doesn't lie
Custom aero
Here is a shot of the 2" vertical trunk spoiler I made from Aluminum from HomeDepot. $25 an 1.5 hours labor.
This is completely removable, I only want to use it on Track days and not bump myself into another class. |
Thats cool. How about getting a long Piano Hinge and rivet it that 2 piece and then tie in a few adjustable anchors to the bottom and you got yourself an adjustable spoiler.....
Data doesn't lie
That was my original plan... But due to the dual inward and downward curvature of the trunk, it was a stretch to get the angled base flush.
OH yea, I see what you are talking about
| 1NZ-FE All Motor Build | burned | Performance Modifications | 19 | 10-24-2014 10:56 AM |
| Carbon build up in the throttle body | Sedan | DIY / Maintenance / Service | 18 | 11-15-2013 11:44 PM |
| fnkngrv's custom trailer build log | fnkngrv | Off-topic / Other Cars / Everything else Discussions | 5 | 10-12-2012 01:24 PM |
| Build Your Yaris, toyota.com | artyin | General Yaris / Vitz Discussion | 3 | 05-03-2006 04:52 PM |
