Old 02-02-2015, 06:13 AM   #1
Originally Posted by Bluevitz-rs View Post
If there was a sensor problem, you would have an associated code. The computer won't give you ignition coil codes for a crank sensor problem.
Sent from my iPod Touch
You have to look at his other three threads and a pile of PMs. Besides the codes he is seeing now, his compression measures bad on cylinders 2 and 3.
Also, P0351-P0354 can be caused by the Oil control valve not working due to being plugged up. That is the round device mounted next the alternator. It also has a fine mesh filter mounted into the block below it.
Old 02-02-2015, 12:07 AM   #2
sebastianroher
Drives: 2009 Toyota Yaris Hatchback
Yeah but I'm telling you the wires didn't get switched around. It is damn near impossible for that to happen because of the length. They make them pretty idiot proof. Also, I don't think my coils are bad as they throw the same codes even when I switch them around. I don't understand how there would be an open or short on the coils. Can you explain what I need to look for?
sebastianroher is offline   Reply With Quote
Old 02-02-2015, 12:09 AM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
There could be damage to the wires or connectors for those coils then. Have someone crank the engine while you wiggle those connectors.
Old 02-02-2015, 12:10 AM   #4
sebastianroher
I will check it out tomorrow and see what happens. I just don't think that they would all be damaged. I can see maybe one, but multiple? What are the odds?
Old 02-02-2015, 12:12 AM   #5
Bluevitz-rs
If someone have tried pulling those connectors off by the wires the could have been damaged. Or by using some pliers to pull the connectors off and slipped. Also a good idea to examine for corrosion inside each connection.
Old 02-02-2015, 07:45 AM   #6
Bluevitz-rs
Yeah except malfunction coils will definitely cause a no start situation. You can unplug the oil control valve and the car will still run as if nothing is wrong.
Old 02-02-2015, 08:13 AM   #7
The no start started after he replaced the cam sensor though. Prior to that he just had random misfires.
Old 02-02-2015, 08:18 AM   #8
Bluevitz-rs
Cam sensor is essential for starting. So something is wrong with it still that would definitely cause it not to start.
Old 02-02-2015, 08:19 AM   #9
Bluevitz-rs
Can you see an AC singnal with a basic volt meter I wonder while cranking on that sensor?
Old 02-02-2015, 08:31 AM   #10
Yes. With a voltmeter set to AC you would be able to see that the sensor has an output. It would really just be a crude working/not working, but even that should help.
Old 02-02-2015, 09:37 AM   #11
sebastianroher
I thought the old sensor was bad because of the oil coming out of it? I'm going to check the resistance of the crank sensor today at work
Old 02-02-2015, 10:45 AM   #12
sebastianroher
Scott, I'm going to buy a cylinder head and have it put on. Any recommendations on head or gaskets?
Old 02-02-2015, 11:09 AM   #13
I think the OEM gaskets are the safest bet. For the head, just make sure that you get it from someplace that has a good reputation for remanufactured heads. I have never had to buy one that way (I have had a few reground over the years, but never actually replaced one),so I am not sure where to steer you on that one.
Old 02-02-2015, 11:11 AM   #14
sebastianroher
I was thinking advance? They sell one for $300 cams included you just gotta switch over the VVT module
Old 02-02-2015, 11:22 AM   #15
Wow! I have paid less than that for used, low mileage engines, but it is a crapshoot when you buy used. If it comes with the cams installed and the valves pre-adjusted, then you will save yourself quite a bit of time.
Old 02-02-2015, 11:48 AM   #16
sebastianroher
Lol in that case, you should find me an engine!
Old 02-02-2015, 11:48 AM   #17
sebastianroher
I'm gonna pay someone to do it.
push start vs electric start? yaris2010RS General Yaris / Vitz Discussion 18 04-07-2010 02:20 PM
Yaris 2008 does not start sberdina DIY / Maintenance / Service 8 04-06-2010 02:03 PM
Toyota Smart Start Blue Yaris General Yaris / Vitz Discussion 0 04-02-2010 07:48 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
Tip Start machine1 General Yaris / Vitz Discussion 12 02-19-2007 03:08 AM
