Old 02-28-2015, 07:34 AM   #19
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
any progress?
Old 03-15-2015, 12:55 AM   #20
ipwnr
Drives: 2003 toyota echo 1.5l manual
yes i just recently did a compression test and here are the numbers
1:195psi
2:210psi
3:220psi
4:220psi
reason i did the compression test was to confirm a bent valve (there was a very noticeable tapping afterwards) due to a miss shift on the highway from 3->2 instead of 3->4. i would like to hear opinions if its worth rebuilding this engine or just buying a junk yard engine or maybe just a new head if the pistons and walls look good.
ipwnr is offline   Reply With Quote
Old 03-15-2015, 09:26 AM   #21
Bluevitz-rs
I'm kinda in the same boat. Only that happened to the engine when it only had 30k km on it. Dealer replaced 3 valves in cyl 2 and 3 and now with 160k km it has lower compression on those cylinders. So I got a used head and am rebuilding it. Only difference is I have a brand new short block to put it on. So I'm building a mild turbo system to run on it too.
Old 03-21-2015, 03:57 AM   #22
ipwnr
well i settled on getting a cylinder head from the junk yard when its $50 parts day, other then the head gasket what else would i need? and also how difficult is it to remove the head while the engine is still in the car?
Old 03-21-2015, 07:39 AM   #23
Bluevitz-rs
It is VERY involved. I worked on one out of the car and it took me an hour and a quarter with my portable impact gun.
Old 03-25-2015, 10:34 PM   #24
ipwnr
I do realize how involved it is and it would be a great learning experience as this car to me is a project car.
Old 07-06-2015, 10:45 PM   #25
ipwnr
the fic just arrived in the mail and its time to install :)
it came with a pnp harness for a 91-94 nsx that i will not be using lol.
Old 07-12-2015, 07:19 PM   #26
ipwnr
little update i got the fic installed but im having issues with it. one of the issues is when i intercept the maf the fic reads and sends too high of a voltage and makes the car run super rich so for now i just have the maf taped and the car runs ok. the second issue im having is the throttle position sensor shows 0% all the time on the fic. and one more the map sensor is reading 10 psia instead of around 2-3 psia wich was what i was expecting.
Old 07-14-2015, 10:09 AM   #27
Bluevitz-rs
I think you have to make sure all the maf maps are zeroed out. The other issues I don't know. Sounds like a wiring issue.
I don't have an FIC. I'm just basing my knowledge from what I've read over the years.
Sent from my iPod Touch
Tags
custom, echo, td03, turbo
Want to build costom turbo kit. Need advice from boosted guys! pimp my yaris Forced Induction Forum 639 09-28-2013 11:26 AM
XB HKS turbo kit, on an echo taKuto Forced Induction Forum 28 01-14-2013 09:39 PM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
build Log : take 2... FcukThis In Car Entertainment + Electronics (audio / video / alarm) 62 09-15-2010 03:00 AM
