![]() ![]() Drives: 2012 Yaris TR 1.33 VVT-i Man Join Date: Nov 2014
K&N Air filter
I am going to replace standard air filter to K&N one but debating whether to go for full kit (with chrome pipe work) or just simple air filter?
http://www.ebay.co.uk/itm/UNIVERSAL-...QAAOSwVFlT9Hcq Has anyone tried this? Does it make any difference in terms of sound, fuel consumption and performance? Why there is a range of prices between £10 to £45 just for filter? |
![]() Drives: 09 hb 2nzfe m Join Date: Apr 2014
I have just a kn panel filter in the stock air box of my 1.3Lmanual
there was a little bit of a difference in acceleration from 2nd gear 60km/hr between 2marks on the road. between 4-7km/hr better speed with the k&n compared to stock. wasn't anydifference in sound IMO. Then I made the cut a couple holes in the bottom of the stock airbox. Makes it much louder almost like a pod filter sound and I haven't bothered with going back to that same road to test again. not too sure about fuel efficency difference. Might be better because if i put my foot down too far it makes to much noise. ha ha its not super science. but ehh. I did change filters back and forth after a couple runs to check the difference in speeds incase it was the direction of the wind |
You should know that the oil on the KN filter tends to end up on the MAF sensor which then throws a code or gets damaged and a new one is like $300.
Bronsin does not recommend KN filters for the Yaris.
#4 | |
I'd recommend just going with the full intake and not just the filter.
I had removed my snorkel, plugged the snorkel hole and then opened up the other 2 sides of the whole airbox. It sounded better then stock. I then installed a short ram intake and it was louder under the hood. I can't compare acceleration since I never did any hard pulls when I had the stock air box in. If you do any other mods like an exhaust header, you'll wish you had a full intake and not just the filter. I'd also recommend non oil type filters.
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
Invader approves this!
No to oiled air filters on the Yaris!
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
![]() ![]() ![]() Drives: 08Yaris2D, 88LandCruiser. Join Date: Jan 2013
My Yaris came with a K&N CAI system. I put the stock box back in and notice Zero difference . I would not waste your money, or the engine longevity on a snake oil company like K&N.
Put your money into things that make a difference, like Shock/struts, springs, sway bars, and tires.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
^ I do agree with this as in I don't think it's worth the $350 you can find the brand name ones online for. But you can easily buy an ebay kit and if it doesn't work perfectly just buy a cone filter and use a sawzall to make it work.
I was fortunate to buy a used TRD cold air intake for a great price, but I wanted a short ram due to water concerns. I cut and hacked and zip tied and now it works problem free and no vacuum leaks. The more mods you have in regards to air flow the more important the intake is. On its own it's pretty much pointless. Paired with my header, 1 ZZ throttle body and ported intake, it is awesome. The growl from the engine bay is awesome and it actually pulls enough now to put you back in your seat
For Sale:
Slightly used K&N Air Filter.
I second that. In fact any oiled filter is not recommended. You want a washable dry element filter.
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
I guess it takes along time to mess with the sensor, or is it when they are oiled too heavy?
I put a K&N air filter on at about 25k miles and am now at 94K with no issues. Not disputing what you found, just curious about it. After I clean mine, I do a very light coating of oil, as I don't want to restrict air flow,just catch dirt. That being said, I haven't seen any performance or gas mileage difference either. So is it worth it the money they ask for it? Not really, course I got mine as a low bidder so I only paid 21.00 to begin with for the whole kit. Not a CAI, just the filter kit for the stock box. |
The MAF sensor works with a hot wire inside at about 200°F. So any oil vapour carbonizes to it and slowly insulates it causing it to react slower and slower and can make the car run leaner and leaner.
hrmmmm .. my car does run lean at full throttle. i think.
its like 18.7 afr. even if i go full throttle at 2k rpm all the way to near redline, altho half throttle stays at 14.7 through out the rev range. Does the yaris have a 'learning ecu' (if thats a thing??!?) because i drive rather light footed normally might have to try stock filter again and clean the MAF senser to see if it changes the afr |
#14 |
Yes the ECU learns long term and short term fuel trims.
#15 |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Two years with a K&N air filter and I use fogging oil for open air filters on the Yaris. I have two filters, I wash one and lightly fog it then put it aside, other one is on the car in use. When it's time to do a filter clean/wash I swap. Not ever had a contaminated MAF and I clean my MAF, Throttle bodies once a year but their spotless. A/F ratio has been the same.
My winter beater a 98' Subaru Legacy GT also runs a K&N with P-flow.........zero issues. Now do I have any performance gains? Yes but only because nothing is stock from TB, intake to complete exhaust and more. Do just an open air filter and your wasting your time unless you just want to make noise. |
#16 |
![]() ![]() Drives: '11 Yaris Join Date: Feb 2015
I also have the k&n that I got from 4 wheel online. Have no problems with it. I just need to be careful when cleaning and re-oiling it so that it will not mess up the MAF. Can't tell if there's a noticeable change in power and fuel consumption but I like how it sounds.
#17 |
![]() Drives: 2010 Toyota Yaris Sedan Join Date: Oct 2015
I have a K&N in my stock box. Never had an maf issue. Light oiling is the key to keeping it clean in my opinion. Does it add more oompf to the engine? probably not but one thing a reusable filter will do for you is cut down the $10-$15 dollar out of pocket expense of having to replace the basic paper filters every time they get dirty.
#18 |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
The filtration is less, thus allowing more air and crud into your engine. Of course there will be more airflow but at what cost ? I use Toyota oil and air and cabin air filters only in both my Yotas.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
| DIY - Cabin air filter location (Belta, Vios, Yaris sedan) | Murtaza_murti | DIY / Maintenance / Service | 5 | 04-05-2012 11:03 AM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
