11-27-2015, 06:31 PM | #1 |
2016 yaris sedan Cruise control
A friend bought a 2016 yaris sedan with automatic transmission.
I tell him, buy this oem parts 84632-08021 switch Speed control 84633-02020 Cruise control wire 90080-15079 screw w/washer A few minutes ago, i installed but no work. any help i will appreciated Installation pics uploadfromtaptalk1448666277224.jpghttp://<a href="http://[ATTACH]56198...1;/ATTACH]</a> Last edited by Eduardo_mty; 11-27-2015 at 06:42 PM. |
11-27-2015, 07:15 PM | #2 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Is it a US market Yaris or one from another market?
11-27-2015, 07:16 PM | #3 |
I live in México and VIN start with J
11-27-2015, 07:33 PM | #4 |
OK. I thought that was the case.
Check for the presence of the connector D3 wires on the steering column connector. My 06-11 cruise control DIY shows the wire locations: http://www.yarisworld.com/forums/showthread.php?t=33750
11-27-2015, 07:52 PM | #5 |
I found this
11-27-2015, 07:55 PM | #6 |
11-27-2015, 08:00 PM | #7 |
OK. I see the blue and brown under the black, which should mean that it is wired for cruise. It also looks like it is wired for steering wheel audio controls. Do you see the cruise control indicators in the instrument cluster?
11-27-2015, 08:03 PM | #8 |
yes, the cruise control icon i can see it with flash light
11-27-2015, 08:31 PM | #9 |
OK. I am not sure about differences in features for the Mexican market Yaris, but it sounds like everything necessary is in place.
The only other thing I can think of to check is the presence of the ECM connector pin.
11-27-2015, 08:58 PM | #10 |
thank you i will check tomorrow the ECM connector pin
11-28-2015, 05:25 PM | #11 |
I Checked, And i will need to buy ECM Comnector A21 Pin (82998-24240)
See pictures |
11-28-2015, 05:30 PM | #12 |
CTScott do you think... Traction control will be install it, with "simple" /easy wiring and switch
See pictures |
11-28-2015, 09:36 PM | #13 |
The A21 pin being missing on the 2016 may mean that the Mexico market ECM does not support cruise control.
Traction control requires support of both the ECM and the ABS ECU, so it can not be added without changing those (and making sure that all of the supporting sensors are present).
11-28-2015, 10:11 PM | #14 |
11-28-2015, 10:20 PM | #15 | |
To test it, you can remove the rubber plug from that pin hole and stick a small piece of wire in from the back of the connector. If you measure the voltage on that wire with the ignition switch in the ON position you will see +12 V on that pin, if your car supports cruise control.
11-28-2015, 10:23 PM | #16 |
Thank you, i will do tomorrow
I will do.... 1. Remove the negative wire from battery. 2. Remove the EMC Connector. 2.1 remove the waterproof Rubber plug 2. 2 install a wire 3. Reconnect the EMC connector 4. Reconnect negative wire to battery 5. Turn on the key 5.1 check wire voltage , if show 12v, it will work This is the steps that i will do, its ok |
08-08-2017, 01:45 AM | #17 | |
Drives: yaris sedan 2011 Join Date: Oct 2016
Hi friend. Did you have? Review your final
Can you show me. which is number pin of ECM ( ECU) for signal ccs ? my car is 2014-2017 year Last edited by laobo; 08-12-2017 at 02:32 AM. |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
I want to add cruise control on my 2009 yaris | doorslammer | DIY / Maintenance / Service | 1 | 08-20-2015 12:28 PM |
06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
This is pretty frikken stupid - Yaris '07 LB auto cruise control | firemachine69 | DIY / Maintenance / Service | 10 | 07-20-2010 08:09 AM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
